anyone ever fitted a mr2 /mrs roadster 6 speed lsd box?
im just looking at these 6 speed boxes as they came with lsd in them from the factory. The spec of them is below.
C65/C65M
Gear ratios for this transmission.
1st
2nd
3rd
4th
5th
6th
Reverse
Final
3.166
1.904
1.392
1.031
0.815
0.725
3.250
4.312
Differential Options:
  • C65-01A: Open Differential
  • C65-01B: Helical Limited Slip Differential (LSD)
Applications:
C66/C66M
1st
2nd
3rd
4th
5th
6th
Reverse
Final
3.166
1.904
1.310
0.969
0.815
0.725
3.250
3.941
Applications:
  • 2003–2005 Toyota MR2 Spyder with Helical LSD (Europe) (manual mid-engine application)
Any idea if they will fit our 4e engines if the belhousing and shifter linkages are swapped?
Thanks for the replies guys. I wouldn't be running big power only ct9 hybrid on my 4e or the 5e i have. So shredding gears shouldn't be any issue for me.
It sounds like it's a no go though for the size of them and the shafts not fitting.
Cheers
Cheers
bean, my advice is dont put a ct9 or ct9 hybrid on a 5e....not a good set up
