Looking good mate what ITBS are those?
TT600 itb's mate
Are you planning on tapering the runners of the old inlet manifold so theres not a big restriction for the air to hit?
Yes Morgey, need a grinding attachment for my drill first :) my biggest headache atm is the TPS, don't know if the toyota one fits the throttle shaft on the ITB's...
  • Replies 224
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Figured you would but was just checking 👍
As for the TPS, im sure when one of the other lads did his with tt600 throttles, he just needed to file off the lug on the tps connector and it plugged straight in.
Me too, can't wait to get the parts xD
still need to source a PCV valve grommet aswell as sorting out the TPS... don't know which one to use, the Triumph one or the TOYOTA...
I think that was it, the TPS gave up later though I think...
Let's smooth some runners now! :D
The mani + 90 degree joiners, the setup will be adjusted over time, thinking about getting the manifold and ITB's welded in one piece this summer, need to find a shop that welds alloy...
As for fuel side of things, don't know if I should get an AFC Neo or emanage blue so I have more flexibility
Edited by EP70-PT
Ecumaster det3. Would be best. Has a road dyno to so while numbers aren't accurate you can see changes to the power curve.
I would definitely advise you make them solid. That's something I wish I did with mine. Try and get the overall length to about 400mm. If you have to use trumpets to achieve this then so be it.
I could get some trumpets welded too yeah, or find some way of fitting some on the triumph tb's, my priority now is to make them work :)
Now that's seriously nice.
Do you reckon it will make more power as well in addition to the better response? I kind of want to do that now, got an corolla intake in it right now and a 98' starlet one as spare.
Edited by MoBro
Sounds like a heavily tuned engine when you rev it. Really amazing. Next thing to do is install the FTE valve springs so to make use of even higher revs and piggy back/stand alone ECU
