JDM_MARK Posted November 13, 2017 Author Posted November 13, 2017 Thanks mate the easy part is over Quote
Mxdsnny Posted November 16, 2017 Posted November 16, 2017 Very impressed with your build so far. I have a few probably stupid questions. Are you running this on the standard ECU? If so how?? I have a set k2 throttle bodies sat in my garage and may ha e to ha e a go. I can see your using your standard TPS good mod. And the vacuum line are you running that to the ecu? Thanks Dan Quote
JDM_MARK Posted November 16, 2017 Author Posted November 16, 2017 2 hours ago, Mxdsnny said: 2 hours ago, Mxdsnny said: Very impressed with your build so far. I have a few probably stupid questions. Are you running this on the standard ECU? If so how?? I have a set k2 throttle bodies sat in my garage and may ha e to ha e a go. I can see your using your standard TPS good mod. And the vacuum line are you running that to the ecu? Thanks Dan Hi mate I was running it on the stock ecu yes for a few weeks but I had to take them off as the fuelling was terrible and it needed adjusting to suit the itb's with a aftermarket ecu but it did run and drive on the standard ECU no problem. With the vacuum I took it off the 4 runners into a vacuum block and then ran the map sensor line and brake booster vacuum to it and also the fuel regulator vacuum. Nothing to the ecu. But yeah have a go it's a good project :) Quote
Mxdsnny Posted November 17, 2017 Posted November 17, 2017 23 hours ago, JDM_MARK said: Thanks for the info. Did you notice an increase in power at all? Or just throttle response? Quote
JDM_MARK Posted November 19, 2017 Author Posted November 19, 2017 I did notice it got up in the revs a lot quicker but I think it could be a lot better with a few other supporting mods. Quote
JDM_MARK Posted December 2, 2017 Author Posted December 2, 2017 On 11/28/2017, 8:39:45, Rich-k said: fantastic mate Cheers Quote
atlex Posted December 20, 2017 Posted December 20, 2017 Also really lovely to see someone turning their own parts. Awesome. Quote
JDM_MARK Posted December 21, 2017 Author Posted December 21, 2017 16 hours ago, atlex said: Also really lovely to see someone turning their own parts. Awesome. Cheers it's amazing the parts you can bang out when you have a lathe on your side. Quote
JDM_MARK Posted January 24, 2018 Author Posted January 24, 2018 So not much of an update but I do have a few parts coming together, I made a little spacer ring for the gauge to fit the larger hole in the pod. And I finally decided to go with a ecumaster det3, seems like a few people have had good experiences with using it so I thought I'd give it a go. Not bad: Quote
JDM_MARK Posted April 24, 2018 Author Posted April 24, 2018 Right the next thing I have started is taking the spare engine out and started stripping it down. I have had the head on the work bench for the last few months porting and polishing and going rebuild this and swap the head over. I have also been collecting parts for the exhaust manifold which is on the to do list next. The head was a pain to get off managed to round a few of the bolts unfortunately anyway heres where I'm at now. And here's what 25+ hours of work and having no social life for a few months will get you. It's not perfect but I am happy with the way it is. I also port matched the exhaust to the inside of the runner tubes I also done the chambers and smoothed out the step under the valve seats. Quote
JDM_MARK Posted August 1, 2021 Author Posted August 1, 2021 (edited) Hi guys haven't been on here in a while, the starlet is still going strong but been so busy with other cars. Speaking of which my most recent buy is another starlet which is having a very unique engine swap which hasnt been done yet. Will have a blog eventually. As for the sr in this time it has had abit of work, mainly engine as it was burning too much oil so I fully rebuilt a spare engine with the addition of : Skimmed head, fully ported and polished, lightened flywheel, full rotating assembly balance ie crank, pistons, conrods, flywheel, clutch, front pulley. Apart from this I've put some recaro seats and built a full stainless exhaust system including header which was all made by myself. Once the car was back on the road I was very impressed with the work I did as the car pulled alot nicer not too mention it makes the engine bay look 10x better with the golden runners. after making the first manifold tho I made a couple more designs with the materials I had left over see which one I prefered. Next thing is too get the management wired in properly once i get abit of time. Edited August 1, 2021 by JDM_MARK Quote
Trevstar Posted August 2, 2021 Posted August 2, 2021 Good stuff Mark! I saw your manifold on Facebook, very keen to seeing how much this all makes with everything you've done Quote
Sam44 Posted August 8, 2021 Posted August 8, 2021 Nice work do you know about the higher lift 4efte turbo inlet cam. I've not been threw your build, yet, you might be running 5ehfe cams or bigger but if not it's true the 4efte has a much better inlet cam it's also run on the UK 5efe paseo engine. Good to see your running the power gen 1 inlet, how to you compare this to the itb setup you had & also what size itbs did you use. Quote
wakeabby14 Posted August 9, 2021 Posted August 9, 2021 15 hours ago, Sam44 said: Nice work do you know about the higher lift 4efte turbo inlet cam. I've not been threw your build, yet, you might be running 5ehfe cams or bigger but if not it's true the 4efte has a much better inlet cam it's also run on the UK 5efe paseo engine. Good to see your running the power gen 1 inlet, how to you compare this to the itb setup you had & also what size itbs did you use. Just a quick one sam the 4e,5e and 4efte cams are all the same. Only the 5efhe intake cam has a 1mm higher lift. Quote
Sam44 Posted August 9, 2021 Posted August 9, 2021 (edited) There not. I've measured them my self the 4efte and 5efe are the same but the UK ep91 has a different intake cam around 1mm lower lift on the 4efte and 5efe. I'm yet to measure the gen1 4efe out of the ae101 and ep80. Trust me it's true anuff. Measure them, don't just read specs and believe them. Time to embrace the truth. There are quite a few specs on that sheet that is incorrect. From power out, to injector size to cam profile. Edited August 9, 2021 by Sam44 Quote
JDM_MARK Posted August 12, 2021 Author Posted August 12, 2021 On 8/9/2021 at 10:50 AM, Sam44 said: There not. I've measured them my self the 4efte and 5efe are the same but the UK ep91 has a different intake cam around 1mm lower lift on the 4efte and 5efe. I'm yet to measure the gen1 4efe out of the ae101 and ep80. Trust me it's true anuff. Measure them, don't just read specs and believe them. Time to embrace the truth. There are quite a few specs on that sheet that is incorrect. From power out, to injector size to cam profile. Hi sam yea I have a pair of 4efte camshafts in the garage I got for cheap and yes their is a difference in lift, just abit less than 1mm I measured. So they will be going in soon hopefully as I think theres a small leak from camshaft seal. Quote
Dale SR Posted August 19, 2021 Posted August 19, 2021 Good to see shes still going strong and great work on the engine, a job well done 😃 Quote
Sam44 Posted August 22, 2021 Posted August 22, 2021 yeh good news the cam difference seems to have been overlooked and i can tell you makes a hell of a difference. Quote
Sam44 Posted August 22, 2021 Posted August 22, 2021 (edited) from what i can find there are only 3xlads (4efe ep91) that have run the different 4efte inlet camshaft, all reporting much better mid to topend torque/pull/mph (speeds), but none have had them on the dyno. i have even spoken to a lad that ran a 4efe inlet cam in a 98spec glanza v running the ct9 B turbo on the g6 gearbox. he told me the car had much faster boost delivery with seamless power delivery he was running 1bar pressure with supporting mods on a blitz access ecu. he wasn't sure on peak power but he said he beat alot of 200 to 250hp. on the streets, saying they had to launch hard to even stay next to him. a great option for bigger turbo builds. ive seen well speced uk ep91 hit 92hp, so the cams & head work should get you near if not at the 100hp mark. for a 1.3ltr engine its a very very good figure. what surprised me?, alot better information came about away from the owners web sites. Edited August 23, 2021 by Sam44 Quote
