So today I went to change my gearbox oil and both the drain plug and the level plug rounded off instantly.
Any ideas on how to get the fuckers out?
They probably havent.
Try getting a goos set of vice grips on the nut and give it a quick jab to release it.
I dont think Irwin sockets go as big as 24mm, plus theres not much to grab on those plugs.
Gonna order some new ones from Toyota and weld a bolt onto the fucked ones I think, cheers for the replies guys
Edited by dan106
seen an older mechanic use a hammer and "dot punch" to remove a broken bolt from a block before,,,just hammer on a slight/side angle in the direction to open,,,maybe try that and see if it moves
If you can get in put your single hex 24mm socket on with a strong arm/breaker bar. Then get someone to hit towards the stuck plug on the knuckle of the breaker bar. This will effectively shock the plug while you are removing it.
