Has anyone here built a 10,000-11,000 rpm 4e-fte? Or do I have to be the first that is going to build one?
Edited by ChaseWheatley
Share this post
I’m fitting titanium pauter rods. Custom ti valves and springs. Custom dry sump. I’m running a Garrett gtx2860r gen 2 turbo atm. I’ll change and make tweaks as I go. I’ll changed the cans if needed after testing
Share this post
you going to have to get a custom cradele made to hold the crank in place or she will walk out of the block
instead of 5 caps holding the crank 1 solid custom machined unit to keep her tight  youd be max porting the head  for sure
plenty more that needs doing  tbf
Share this post
Yeah I’ll build it no mater what it takes.  Why do I want that high rpm. For a wider power band and that sound. Nothing beats that sound
Share this post
On 12/03/2018, 4:35:57, Calum122 said:
Tidy, why do you need the high RPMs?
Is there any power to make it in that region?
Well there is if I build it right.
Share this post
Interesting! How far along in the build are you?
Share this post
That setup won't make any power beyond 6500rpm.
Share this post
Yeah Adam knows because he had a 20,000rpm starlet...
Share this post
Sure it was a shell that remained a shell
Share this post
It was the best high power starlet build I ever almost seen
Share this post
Good luck if you plan on using the stock main caps.
Share this post
Lol that is the most accurate comment I have see. Some things will be different to what u have said above.
Share this post
I’m having custom ones made my friend and a one off forged crank.  But I may not use ti rods but a light rotating mass would be better just shitty about the ti fatigue life
Share this post
On 05/06/2018, 8:48:30, akyakapotter said:
Custom mains and crank that's gonna cost £££s good investment imo
Cheers nick.
Yeah I already go a quote. I could buy a full turbo kit for the same price
Share this post
Cheers nick.
Or a car actually
Share this post
Custom crank for the price of a turbo kit sounds cheap to me! Who’s doing the work?
You can already buy billet caps off the shelf in America.
What ecu are you planning to use that can cleanly trigger to 11,000-11,500 rpm?
Share this post
And engineering company in NZ.
I know I can but I might as well just get it all made at the one place.
Share this post
Create an account
Register a new account
Sign in
Sign In Now
