After 120 the gtr would walk, on track the gtr would walk (with the right driver) 0-120 the gtr would walk 50-80/100 the starlet would probably have it. Right terms for the starlet and it shows.
You'll be very hard pushed to have just a starlet stand. Id like to see a marquee go in a starlet along with all your drink, food, camping gear and other shit. Just make him carry loads of shit! Support vehicles ftw!
It depends on how far forward your engine sits. I think yours is slightly further back than mine so you should be ok. But mine the lower pipe is rubbing on where the front engine mount (or 4efte downpipe brace) bolt to. I've got a sleeve on where my pipes rubbing though. Mount kits fine. Tegiwa rad is also what im running. If anything its slightly too good a my temps are a tad cold, but im going to replace my thermostat to hopefully cure that
Have you got an anti lift kit? They make the wishbones sit lower and slightly closer to the arb. Maybe parts have worn in and sagged slightly. Only other thing is Exhaust in the tunnel? Worn rubber or maybe ones even split. Engine will move quite a bit when setting off so expect that to move a fair amount. Try putting a cable tie tight around the rubbers to reduce movement.
Have you got a thicker farb? Mine sat right close at the sides of the exhaust tunnel, had to bend some bits out the way, and i say bend i mean smack the shit out of with a hammer through a block of wood, because it knocked.
Good good! Genuinely cant wait to see this thing driving again Im planning some bits to mine but not sure if they'll be in place for JAE. Will be ordering some stuff when i get my new bank card
