Reptagon
    38
About Reptagon
  • Birthday 09/04/2001
    Isle of wight
8398 profile views
Reptagon's Achievements
  1. So it's been a long while but I still have my starlet. I am in the process of doing a 5efhe swap with it (still using the 6 speed). I got sidetracked since 2021 on mx5s. I've had 2 of them since then, a MK2.5 vvt and that rusted out so I've swapped everything from that into a MK1 shell (vvt engine, 6 speed gearbox, 4.1 ratio diff, brakes, full subframes and arms from the MK2.5, interior, wiring loom) and then it has had some non standard bits like the Subaru brakes, aftermarket front upper and lower arms, custom exhaust manifold, 4age black itbs on a billet hummerlink adapter, half rad, big injectors and fuel pump. I then painted the mx5 myself which went okay but it was a learning experience. Hopefully the starlet should be back on the road within the next month as I'm just waiting on the flywheel to arrive
  2. Hey are these still available?
  3. I have a c161 gearbox (corolla G6R) fitted into my EP91 NA Starlet and I am potentially going to be working far away from home in the not too far future so I will be commuting long distances. Does anyone know what diff final drive ratios are compatible to make the 6 speed into a longer ratio fuel economy gearbox. Is it a 6 bolt or an 8 bolt diff in a c161?
  4. Oh yeah also I've got a g6r gear boot fitted which I removed from the g6r when I pulled my gearbox out of it. All I want now interior is the glanza door cards and new carpets to match my glanza rear bench
  5. so a bit of an update, not much has been done on my starlet for a while. I fitted some MR2 seats which I got for free from a mate and now I've just gone and got some top spec fully adjustable MR2 seats and fitted them to my modified rails. I've ordered a gizfab adjustable panhard rod as it's cheaper then the best and from the looks of it it can be adjusted on the car unlike most of them. I've not really been putting money into my starlet as I've been putting all the money into my MK3 supra
  6. I've sent you a message about the door cards and the radio surround
  7. Im thinking of making a 4efe NA track car for the toyota sprint cup (E street class) but the thing I was wondering if the added chassis regidety was worth the added weight to the ep91 chassis over the ep81 chassis also could i buy a cheap 91 and cut some of the additional safety parts out to get the weight down?
  8. This is a custom made short shifter that was just cut and then a bit of bar added onto the bottom to extended it, will need to be pushed into the stock shifter and it should work for an NA or Turbo gearbox but Im not 100% as Ive never tested it properly as I went 6 speed before I used it Open to offers Also have a Hypersport HS-001 short shifter avaliable again open to offers Collection from portsmouth
  9. open to offers but i know these are rare
  10. Quite a rare part to find very good for NA tuning. Collection from Portsmouth
  11. Red glanza at the shell petrol station on goldsmith avenue I was walking past
  12. Reptagon
    5efe/5efhe
    Wanted a 5e engine to make a high comp NA engine with for my starlet
  13. so it fits on mine but be warned any speed bump if youre lowered at all at will scrape on and dent it up so i had to cut it slightly to get my socket in to undo a bolt
  14. So yes I do have an update, I have now fitted some new white 3 spoke meshindo wheels which cost me £40, an ultra racing 4 point lower bar, front lip and I've not had a passenger seat now for the past few weeks due to removing it to fit the mr2 seats and my welder packed up as I was about to do it, so I just bolted the tabs onto the seats and I can confirm SW20 (mk2 mr2) seats fit a passenger side at least. I also fit an anti lift kit which was a fun one, so the captive nuts that the anti lift kit mounts too tend to snap and I had this happen one on either side so there's slight cuts in both footwells now.
  15. Anyone got a spare rear light or a blanking plate I could buy?
