turbo Grant
    2479
  1. get your spanners out shorty, i want my bumper bar back! guna have mine going in no time lol
  2. Can't wait for this track day. Need to get my car finished. Looking like it's guna be quite quiet. Be good to see more starlets out on track!
  3. Can get it done in a weekend. Lots to take out
  4. Zisco's kit is quality but the price is mad I think. As j said can put your own kit together for alot less. Guna need solid lifters if you want 2 rev 2 9k guna sound amasing on full chat. Be nice to have a ride in her when it's done.
  5. 9k that will be nuts. Still collecting bits for mine. Not in no real rush. Want it to be right first time.
  6. Brake hose collapsed? Undo the bleed nipple see if that frees it off. If it does changed the brake hose
  7. What boost you guna be running? Aze was running 2bar + on that beast. Think 4age studs will be needed as well.
  8. Yes mate guna be savage. Have to get on the strip together. think your guna need bigger valves tho
  9. Properly adjusted drum brakes will be fine. I think ther are some drum upgrades in the pipe line. Shortys been on the case. Can change the size of the slave cylinders pistons. Should be a real weapon when this car is done
  10. I've been pushing my finger in lol you know what I mean. Mine will be ready easy.
  11. If you can affored to keep it and rebuild it. Well worth doing. that's the bike I need for my husky 400 2-stroke conversion
  12. I'll be able to get that turbo to fit dude. Hold in there all is not lost yet.
  13. you getting a new cam belt with that as well? doesn't sound like a bad price
  14. better pull your finger out. the engines not liking sitting in my workshop. wants too be in the 85
  15. I've sold mine. He's having shortys one. We have too many starlet bits lol
  16. Wana get you self over to silverlake. They have hundreds.
  17. Have you fitted the solid bushes that go on the selected cables at the gear box?
  18. I would also take the cam cover off and check the belt timing too. Done mine a tooth out once and drove it down the yard flat as a fart till boost came in. Drove it strait back in the work shop.
  19. Try taking out the fcd. Might be fukin up your map sensor reading.
  20. You can take the worm drive out. Uv swapped them over. You have to be really carfull. Take the 10mm and the little plate out. The round plate with the treads in the middle will come out. Usuall hard to get out. Needs to be pulled strait out up ^ try cleaning it. And pulling up.
  21. Could you not put a nut and bolt in to get you back on the road. Not near my car and can't remember if you can get a nut and spanner on it. That's what I would try and do if I was you mate.
  22. Little guy. Big hart. Angry temper. Guna be at JAE hope too see you guys.
  23. Have you bolted your wastegate pipe brace on? Don't want to crack you nice manifold. But sounds like you have an exhaust blow some where now
  24. Be interesting to see how it goes with the new pipe. Should be alot more responsive. Keep us updated about the smoke. Be nice if it clears :-)
  25. Should be boosting more than that. What intercooler are you running? You checked your turbo waste gate port for cracks? It dose sound like you have an air leak if idleing that high. Try taking your pipes off and fitting the clips back with the clips nice and square to the pipes. Could also squirt brake cleaner over the pipe to look for air leaks.
