RobSR Posted March 10, 2008 Posted March 10, 2008 (edited) Hi Guys, it has been thought that a 1/4 mile times section would be a good idea...so basically, everyone reply to this thread in the format shown below...when 10 times have been recieved that will go into a table for the Top10....then if times are between, i will edit the table accordingly...Please dont just make results up, this needs to be as accurate as possible...ThanksRobName : Fishy89Model : 1995 GTSubstantial Mods : FMIC, HKS Silent Hi-Power, Decat, Power Enterprise Filter, Exeedy Stage 2 Racing Paddle Clutch + Cracked Ring, was smoking very badly.Full weight or stripped : Half StrippedTires : Bridgestone something...BHP : Unkown - estitmate 140bhpQuarter Mile : 14.9Terminal Speed : will have to check Edited July 14, 2013 by RobSR
Guest Enzo Posted March 11, 2008 Posted March 11, 2008 Name : EnzoModel : 1998 ep91 srSubstantial Mods : 4branch inletFull weight or stripped : stripped 920kgs on weigh bridge with half a tank of fual.Tires : michelain pilot exaltosBHP : 83 at the flyQuarter Mile : 17.1Terminal Speed : n/a
-Harry- Posted March 11, 2008 Posted March 11, 2008 Ahh good idea. Name : HarryModel : 1990 ep82Substantial Mods : GT2540, 5e conversion, custom inlet, 55hp shot of nitrous.Full weight or stripped : strippedTires : MT 22x15x8 (on 6" rims so are only 7" wide max.BHP : 270 at the wheels for this run. Now 300Quarter Mile : 11.7 Terminal Speed : 121mph.Evidence
Bean Posted March 11, 2008 Posted March 11, 2008 My first go at Crail, too much wheel spin though.Name : PaulModel : 1994 ep82Substantial Mods : TD05H 16G turbo 14psi, 6 speed box fmic ectFull weight or stripped : Full weight with almost full tank of juiceTires : toyo proxy t1s 195/45/15BHP : 210 at flyQuarter Mile : 15.228 Terminal Speed : 97.4mph.
dan_ep82 Posted March 11, 2008 Posted March 11, 2008 my time at santa pod was but it was wet and had full tank and interior!Name : DanModel : 1995 ep82Substantial Mods : blitz k24 turbo at 14psi ecu, fmic, etcFull weight or stripped : Full weight with full tank Tires : yoko prada spec 2's 195/50/r15BHP : 205 at flyQuarter Mile : 14.6 Terminal Speed : 101.4mph.was wet day so not too bad!
paulgtt Posted March 11, 2008 Posted March 11, 2008 When I had my old GT. Santa Pod in blistering heat 90 odd degrees.Name : paulgttModel : 1993 ep82Substantial Mods : £20 Bleed valve. Set to 12psi.Full weight or stripped : No rear seats, half tank Tires : Firestones 185/55 14. Fronts @ 20psiBHP : 140 ish??Quarter Mile : 15.4 Terminal Speed : 90 mph
Idrees Posted March 28, 2008 Posted March 28, 2008 My brothers Sportif at York raceway in the wetName : TayyibModel : 1997 Starlet Sportif N/ASubstantial Mods : Blitz filter, universal backbox, 4 branch inlet manifold.Full weight or stripped : Full weightTires : Some budget rubbish.BHP : 90 ish?Quarter Mile : 17.7Terminal Speed : 89 mph
B19YUL Posted March 28, 2008 Posted March 28, 2008 Name : StewartModel : 1996 ep91Substantial Mods : full stainless system, front mount intercooler, running 1.0bar boost, hks induction kitFull weight or stripped : full weight, full tank of petrol + roll cageTires : Nexus 14inch jdm alloys.BHP : 180 at the wheels Quarter Mile : 13.35Terminal Speed : 116mph.
turbomax Posted May 11, 2008 Posted May 11, 2008 i went today got a 13.90 @103mph car is ep82 with td04. i had it on the rolling road up there and it made 201bhp at 1 bar peak then holding at 13psi. i was happy the fueling was ok as well which proves you can use 330cc injectors on standard ecu.
RobSR Posted May 11, 2008 Author Posted May 11, 2008 mate could you please put it in the format, like everyone else has!Thanks!
Starbus Posted July 7, 2008 Posted July 7, 2008 Ahh good idea. Name : HarryModel : 1990 ep82Substantial Mods : GT2540, 5e conversion, custom inlet, 55hp shot of nitrous.Full weight or stripped : strippedTires : MT 22x15x8 (on 6" rims so are only 7" wide max.BHP : 270 at the wheels for this run. Now 300Quarter Mile : 11.7 Terminal Speed : 121mph.EvidenceAwesome time mate, well done.Where about's are you from?Name : StewartModel : 1996 ep91Substantial Mods : full stainless system, front mount intercooler, running 1.0bar boost, hks induction kitFull weight or stripped : full weight, full tank of petrol + roll cageTires : Nexus 14inch jdm alloys.BHP : 180 at the wheels Quarter Mile : 13.35Terminal Speed : 116mph.Sorry but you didn't do 116 on a standard turbo or with only 180bhp. Unless your car is 500kg's.
RobSR Posted July 24, 2008 Author Posted July 24, 2008 ^ i also thought his was a little ambicious aswell...
59bhp Posted July 24, 2008 Posted July 24, 2008 Name : MichaelModel : 1995 ep82Substantial Mods : K and N panel filter, magnecor leadsFull weight or stripped : full weight, 1/2 tank of petrol Tires : 195/45/15 Toyo Proxy 4 on the front and 195/45/15 toyo proxy t1-R on the back.BHP : 129.9 at the flyQuarter Mile : 15.5Terminal Speed : -.
glanza87 Posted January 8, 2009 Posted January 8, 2009 Name : Glanza87Model : 1996 Glanza VSubstantial Mods : None completly standard, with pipes flipped over for full boost 1st and 2ndFull weight or stripped : Full weight, empty tank lolTires : Shit Budget MarangoniBHP : Standard 133bhpQuarter Mile : 16.108Terminal Speed : 87mph
RicoW Posted March 8, 2009 Posted March 8, 2009 Name : RicoWModel : EP71 4e-fteSubstantial Mods : FMIC, exhaust manifold, downpipe, 2,5 exhaust @ 1 bar of boostFull weight or stripped : fully stripped around 700 kg'sTires : 15' shitty tiresBHP : 170/180 hp?1/8 Mile : 9.08 secondsTerminal Speed : can't rememberit was on a 1/8 mile run though, and on wet track, but I could go with the higher powered cars
Maz90 Posted May 9, 2009 Posted May 9, 2009 Name : MartinModel : 1993GTSubstantial Mods : Decat,Crap s/s mani,3inch back s/s exhaust-to big,Hks actuator set to 0.8, was smoking very badly.Full weight or stripped : Half StrippedTires : Toyo proxiesBHP : estitmate 145bhpQuarter Mile : 15.4Terminal Speed : will have to check Was my first time at crail and my boost was creeping upto 12psi and hitting fuel cut.
Russleh Posted September 6, 2009 Posted September 6, 2009 Name : Russleh ( Russell )Model : 1996 sportif with glanza engineSubstantial Mods : hks ecu , hybrid turbo @1.2 bar , roadrunner mani , decat, bailey dump valve , walbro fuel pump Full weight or stripped : full wait with a mate also so say 80kg up Tires : 4 yokohama parada spec 2's ( nitrogen inflated ) BHP : 189.9Quarter Mile : 14.299Terminal Speed : 99.6was my first time at crail. not bad result.
Spanner Posted September 28, 2009 Posted September 28, 2009 Name : Spanner (Carl)Model : 1992 ep82 gt turboSubstantial Mods : Blitz nur spec - cat back,exedy organic clutch,blitz dump valveFull weight or stripped : full weight with half tankTires : toyo proxes front,pirelli p-zero nero rearBHP : 140-145?Quarter Mile : 15.174Terminal Speed : 90.9was running low 15's the whole day at Thorney Island (concrete untreated strip very slippy) right hand lane
Jae-Glanza Posted October 5, 2009 Posted October 5, 2009 This is an awesome post! Gives people like me looking to push more bhp out of my stock glanza engine a rough idea of what bhp/performance I'll be looking with similar mods!Good work =]
wg daz Posted October 5, 2009 Posted October 5, 2009 Name : wgc dazModel : corolla e11 (1999)Substantial Mods : decat, s/s exhaust system, hks induction kitFull weight or stripped : full weight (heavy lump)Tires : budget jobbiesBHP : Unkown - est 85/90Quarter Mile : 17.2Terminal Speed : 86.9mphnot bad for a heavy 1.3 n/a lolla damp track in the colt (santa pod, usc )
ep91_glanza Posted March 10, 2010 Posted March 10, 2010 Name : ep91_glanza.....karlos!!!Model : EP91 4efteSubstantial Mods : FMIC,tenzo racing cat back exhaust,ct9 runnin 0.7 ishFull weight or stripped : no back seatsTires : 195 45 16. Toyo proxesBHP : ????????1/4 mile : best 15:36Terminal Speed : i think it was round about 90is that good or bad???
Driver Posted March 10, 2010 Posted March 10, 2010 Name : DriverModel : 1996 GlanzaSubstantial Mods : FMIC, Blueflame Exhaust, Racetech custom TD04 kit with matching fmic, Emanage blue, Lowered springs.Full weight or stripped : StrippedTires : Toyo T1r with 2-3mm leftBHP : Unkown - estitmate 210-220bhp ?Quarter Mile : 13.6Terminal Speed : 106.5Did another 13.7 with terminal of 108 but fucked start up I recon that could of been a low 13 if i didnt mess it up at the start
dEF Posted May 11, 2010 Posted May 11, 2010 Name : dEFModel : 1996 EP91Substantial Mods : 4AGE engine conversion, Garett T28 TurboFull weight or stripped : Full weightTires : Toyo R888BHP : 265 BHP / 268 NmQuarter Mile : 13.4Terminal Speed : 175 km/h (110 miles/h)
Lee_EP82 Posted May 11, 2010 Posted May 11, 2010 Name : Lee_EP82Model : 1994 GTSubstantial Mods : TD04 @ 0.4 bar, Ext Wastegate, Trust Power Extreme 1 exhaust, HDI FMICFull weight or stripped : Rear seats taken out, but still had big wheel diskloc in the back and spare wheel and camping gear.Tires : Yokohama Parada Spec 2BHP : Unkown Quarter Mile : 14.6 secTerminal Speed : 95mph
