TimD Posted January 13, 2017 Posted January 13, 2017 (edited) I was at Autosport International yesterday and spoke with the guy responsible for CoolerWorx shifters. Currently, he doesn't have an application for our cars, but seemed interested to work with me in producing something for the starlet. >http://www.youtube.com/watch?v=cGQrFlxPi3s&ab_channel=MusabAljboryI have a spare shifter I intend to send him, and see how things go.Is there any other interest in these, to give you an idea, they had a special offer on shifters at the show for £300, so expect to pay that for one of these. Edited January 13, 2017 by TimD Quote
Dean_mc88 Posted January 13, 2017 Posted January 13, 2017 (edited) Yes please! keep me updated !!! Edited January 13, 2017 by Dean_mc88 Quote
Socks Posted January 13, 2017 Posted January 13, 2017 I'm assuming to have full blown shifting. The box will need fancy syncros? Quote
TimD Posted January 13, 2017 Author Posted January 13, 2017 This is a normal H-Pattern shifter, it just replaces the standard plastic thing. As far as I'm aware it makes shifting shorter, and a more positive experience, never used one, but similar things from other manufactures get rave reviews. It will also allow the shifter to by longer and closer to the steering wheel too, oh, and look bad ass. Quote
Socks Posted January 13, 2017 Posted January 13, 2017 This is a normal H-Pattern shifter, it just replaces the standard plastic thing. As far as I'm aware it makes shifting shorter, and a more positive experience, never used one, but similar things from other manufactures get rave reviews. It will also allow the shifter to by longer and closer to the steering wheel too, oh, and look bad ass. Using with stock cables? Quote
Dean_mc88 Posted January 13, 2017 Posted January 13, 2017 videos on you tube show a really short throw between gears Quote
TimD Posted January 13, 2017 Author Posted January 13, 2017 (edited) Using with stock cables? Yes Edited January 13, 2017 by TimD Quote
morgey Posted January 13, 2017 Posted January 13, 2017 They have these sort of things for hondas. Some are beautiful Quote
Amjad Posted January 15, 2017 Posted January 15, 2017 That looks gorgeous! Further down the line, I'd love to get something like this Quote
Ep Starlet Alan Posted January 15, 2017 Posted January 15, 2017 (edited) If it is like this I'm in Edited January 15, 2017 by Ep Starlet Alan Quote
morgey Posted January 15, 2017 Posted January 15, 2017 The price tag on them K-tuned honda shifters is about £300 iirc. Quote
nikhilkamdar12 Posted January 17, 2017 Posted January 17, 2017 If it is like this I'm in Same here! Looks the dogs Quote
morgey Posted January 17, 2017 Posted January 17, 2017 If i wasn't quitting my job I'd be inclined to try knock something up at work. Quote
redz11 Posted January 17, 2017 Posted January 17, 2017 If i wasn't quitting my job I'd be inclined to try knock something up at work. theres always time ;) these do look awesome! Quote
morgey Posted January 17, 2017 Posted January 17, 2017 Well if someone had an old shifter they didnt want i could have a look at it lol Quote
Stu Posted January 19, 2017 Posted January 19, 2017 If i wasn't quitting my job I'd be inclined to try knock something up at work. Quitting and moving to NZ!? Quote
morgey Posted January 19, 2017 Posted January 19, 2017 Visiting, for now. Unless you knowbof any jobs haha. Quote
Stu Posted January 19, 2017 Posted January 19, 2017 I do actually... there was one going recently running the CNC gear at Precision Engineering who are the guys making quad rotor cranks. Quote
Bussey Posted January 19, 2017 Posted January 19, 2017 All over this! Only thing the starlet market is screaming out for at the minute, please keep this updated. Quote
morgey Posted January 19, 2017 Posted January 19, 2017 I do actually... there was one going recently running the CNC gear at Precision Engineering who are the guys making quad rotor cranks. Never run and cnc grinders like they'd probably use but id throw myself in at the deep end haha. Quote
morgey Posted January 19, 2017 Posted January 19, 2017 theres always time ;) these do look awesome! Well I've spent a bit of time looking at the design into making a billet ally shifter.The toyota one is a bit more complicated to the honda one but I've got the main pivot mechanism sorted, I've opted away from the ball type and gone with something different but it will allow for much greater adjustablity and will look pretty special if i get a chance to make it.This is just a mock up to see if the 2 pivots will work, the outer box would be a frame running down to a base and forward to the cable mounts. I've also Just now figured out how to allow the left right movement to work in a straight updown motion, compared to the oem which pivots on a arc controlled by the cable arm rocker.Will spend a bit of time tomorrow afternoon mocking up a rough design of how i envision it to see if it might work.P.s bare with my solidworks skills as im self taught as a mould tool designer haha Quote
morgey Posted January 20, 2017 Posted January 20, 2017 Spent a bit nore time playing with ideas, made it into something more recognisable, think the base design would work, ideally it needs bearings adding but im going off the idea of shoulder bolts that we use on mould tools at work for the time being.This is based on a corolla shifter so measurements will be slightly different but its 99% the same.One of the base mounting holes is right where the main structure is so will need to do something with that and obviously finish off all the missing parts.Left movement, there will be two shoulder bolts to allow the bearing cage to slide in and out a bit. Quote
morgey Posted January 20, 2017 Posted January 20, 2017 I might change things a bit more, i like the idea of it beig fully adjustable, hence the upper and lower arms being able to be moved in and out and locked with grub screws. I might make the rocker arm on the side ajustable as well but I've already reduced the side to side throw by about 10% by shortening the arm one way and extending the other. Quote
daniel_g Posted January 20, 2017 Posted January 20, 2017 Its about time there was an aftermarket starlet shifter in progress!The OEM one is pretty poor compared to other cars.. even with a short shifter and solid bushes in the cables.Whats the chances of that ever making it to life Morgey? Quote
