ahhhh i was gonna get a hks one just until i get an uprated ecu? wats wrong with the hks ones? im just scared of blowin it up it hits fuel cut so easy and really fast, im also only running standard actuator but was gonna get the hks one with the fuel cutr defednder in place too? would this be ok hks one is better than hitting fc all the time???
  • Replies 767
  • Created
  • Last Reply
Top Posters In This Topic
I have a HKS FCD but i haven't fitted it yet, it's cutting for a reason as a saftey device so there is obviously something wrong. You would rather have it cutting than blowing up :blink:. The HKS ones can be dangerous but if you use them sensibly then im sure you will be fine. Dub Se7en has one on his and hasn't had a problem with it.
The reason it is hitting it so fast is due to the spring in the standard actuator being considerably weaker. The spring in the HKS actuator is much stronger. Get a standard one and a HKS one and pull on them and you will see what i mean. You can also solve the fuel cut with an electronic boost controller i think. Im sure Sicaln has one with a standard actuator.
The HKS actuator solved the problem for me anyway and since we have identical engines it wil probably do the same. I even had the same fuel cutting problem as you for about two weeks until i got an actuator. It was as soon as the engine tickled boost it felt like hitting a wall.
Let me know what happens bud.
Bourkey
steer clear of the HKS FCD it is more trouble than its worth, it tricks the engine - you would be better to wait and have fuel cut that is safer than the damage u can get from running lean with the FCD
  • 1 month later...
cheers man since i did the roof ive had tons of comments and old guy from buy my work said i need shooting cuz apparently i have the japanese kamakazi sign on the roof ;) i was like shutup its one of the japanese flags ya noob ;)
so a small update ive got the whole week off work so decided to clean the engine bay. im going to try and dedicate the whole week to fixing small bits and bobs on the starlet that doesnt cost money!
heres a few pics of the bay ;)
;) Dean
  • 1 month later...
so havent really updated lately lol, so need to start updating as theres always stuff changing on the car, so as some of you may be aware i had a really bad shaking problem with the car but know 1 knew what it was.... all fixed now, thanks to my mate breaking his paseo for spares. so i desided i wanted the gearbox cups and the drive shafts, when i came to fitting them after taking apart everthing the new driveshafts fitted in the gearbox end but were thicker with different spline count so didnt fit my hubs.
so then i also had his hubs ,discs,and callipers so basically the whole gt conversion took a fair few hours to swap everything but fortunatly i kept my hubs and callipers with the 3g 10 groove discs and mintexx 1144 pads.... but now its all fixed and running fine
the old driveshaft and cup lolz
my new brakes ...
the brakes are spot on now, i wasnt planning on swapping the breaks but its all good now cuz ive got the gt hubs so i can put some 4 pots straight on now
when i get some lol, i also had a drivers side door handle cuz mine snapped in the frost... and the paseo clocks :lol:
will update more soon...
Dean
another update.
resently my decat has been a night mare ever since i fitted it i couldnt get the bolts as tight as i would have liked because the heat wrap and how everythink gets in the way, but the other week the car was seriously slow and i could hear the exhaust blowing so checked the decat to find only 1 bolt holding t on. so had to refit it again... but on friday the same thing happened again even though i had put lock tight on. :lol:
so on friday i took it to my mates house cuz he has a car pit! and decided the only way to fit it properly was to take the turbo off
now its mint and more responsive than its ever been
few pics
decided to port the wastegate abit didnt do the whole thing due to lack of dremal parts lol, hasnt hit fuel cut since
badly leaking decat as you can see
strapped back on with tons of locktight and put 2 nuts on each thread to make sure it neva bothers me again :)
all in all job well done made such a difference to the sound and performance!
been busy so more updates cumming....
comments welcome
Dean
Keep up the good work dean. I ported my waste gate when the engine was sat in the garage. I did it like you just didn't get too giddy with it :lol:
Bourkey
im just bout to go outside to start messing again but its snowing lol, im glad you said you did yours the same way bourkey. wasnt sure id done it right? just
ground it till it was smooth taken probally a mill off if that :lol:
i cant wait till its summer and i can use the gt fully lol... pallet wants to buy my wheels but im not sure
I have just sat and read right through this thread from the start, and I have to say that I am very impressed! You seem to have a knack for making free modifications, but that make all the difference to the look of the car!
I love the roof idea! And it looks really good, considering you done it yourself too from a small logo!
Its good to see the difference from what the car looked like when your first got it!
I love the car, and look forward to seeing what else is on your list of mods!!
