Flower Posted June 4, 2017 Posted June 4, 2017 Hi guys,As the title says I am on a stock 4efte but I want a fast responsive car. I seen some info that gt20s are a good size for our little engine ? Does anyone have some info on this ? Cheers Quote
maddox710 Posted June 5, 2017 Posted June 5, 2017 Hi guys,As the title says I am on a stock 4efte but I want a fast responsive car. I seen some info that gt20s are a good size for our little engine ? Does anyone have some info on this ? CheersIf you lower your target of 250bhp then you can save yourself a fair bit of money around 230bhp is perfect on the td04 and you will be maxing out your injectors around there so that's another expense to bare in mind plus engines get a bit fragile around 230-240 Quote
gorganl2000 Posted June 5, 2017 Posted June 5, 2017 for what yu said...maybe the tf035 (slightly smaller than tdo4l) is a great cheaper option for you are yuo dead set on a garret gt20? Quote
Ollieh17 Posted June 5, 2017 Posted June 5, 2017 Gt20 is a better turbo than td04 but more expensive Quote
Flower Posted June 5, 2017 Author Posted June 5, 2017 I have had a TD04 on my Glanza before. I have a few kicking around as I have two Scoobys.The Glanza is going to be my track car (to save STI from getting smahshed up lol) so I am looking for a fast responcive turbo.I will be building a forge engine in due course as I have just finished forge builds on the scoobys the pockets took a hit but I will be doing the Glanza within a few months. Just forked out on AD08Rs whiteline roll bars bcs and polybushes. And from what I'm reading about this GT20 it would be ideal. BUT what spec Gt20's do you guys use ? It seems like it's a diesel turbo what what I'm gathering ? I found a gt2052 but doesn't look like the one guys are running on here ? Quote
Gainzy Posted June 6, 2017 Posted June 6, 2017 If your going forged you wouldn't be far off that mark with the ct9 hybrid or tf035 for corner response. Quote
gorganl2000 Posted June 6, 2017 Posted June 6, 2017 (edited) I have had a TD04 on my Glanza before. I have a few kicking around as I have two Scoobys.The Glanza is going to be my track car (to save STI from getting smahshed up lol) so I am looking for a fast responcive turbo.I will be building a forge engine in due course as I have just finished forge builds on the scoobys the pockets took a hit but I will be doing the Glanza within a few months. Just forked out on AD08Rs whiteline roll bars bcs and polybushes.And from what I'm reading about this GT20 it would be ideal. BUT what spec Gt20's do you guys use ? It seems like it's a diesel turbo what what I'm gathering ?I found a gt2052 but doesn't look like the one guys are running on here ? seriously, check out the tf035, a few members on here seem to love them response wise and they seem to make just under what td04l will make power wise....so overall a really nice turbo for modest power goals and very cheap....just do some research into the tf035 before you invest in the gt20 (yes, its probably a very good turbo, but expensive) also with the tf035 you can mess about with different exhaust housings to improve power or spool http://www.ukstarletowners.com/topic/101995-tdo4l-13t-tfo35hm-hybrid/?hl=tf035#entry1182883 http://www.ukstarletowners.com/topic/102072-tdtfo-numbers-and-digits-explanation/?hl=tf035#entry1186106 http://www.ukstarletowners.com/topic/58000-kbonds-white-gt-engines-back-in/?hl=tf035#entry839966read kbond's experience,,,see pg 3 for dyno Edited June 6, 2017 by gorganl2000 Quote
TimD Posted June 6, 2017 Posted June 6, 2017 GT25R? http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Product_Code=GRT-TBO-001 That page seems to suggest around 240hp which is as near as damnit what you're looking for. I have gone TF035 on mine, which will give me about 200hp I'm hoping. Did 170 on 7psi of boost and standard management, so with more boost and a proper map I can't see it being too difficult to get the figure I'd like. My car is a track car, it is never used on the road, and even at 160hp there wasn't much on track that came past. Quote
Flower Posted June 6, 2017 Author Posted June 6, 2017 GT25 is the next step depending on budget. Hybrid GT25 would touch 300 with good response I recon. There's seems to be a few GT20's in about in different trims but it's just finding someone that knows turbos well enough what would be best suited to our engines. A/r sizing etc.Thanks for the info guys I will look at the posts/links and try make a decision. Just fancied something different aswell. Quote
wickedep Posted June 7, 2017 Posted June 7, 2017 you have two choice 52 and 56. the TF is a decent substitute. will spool 200rpms quicker. but the GT20(56) will give you more power. given the cost and ease of replacement..the TF is a good choice I think. TF looses efficiency after 1.2bar or so. if you get tired of TF..you can always move up the ladder to td04 or VF on the same manifold/downpipe. Gt20 has same T25 inlet flange. so its possible to go up to gt25/gt28 on gt20 manifold (lots of power potential),but you will need a new downpipe. hope this info helps. Quote
TimD Posted June 7, 2017 Posted June 7, 2017 Just fancied something different aswell. This is a statement I will never understand. Keep things simple and use the car, a car with half the horsepower that actually sees the track, is still 100% faster than one that sits in a shed being built to be different. Quote
gorganl2000 Posted June 7, 2017 Posted June 7, 2017 you have two choice 52 and 56. the TF is a decent substitute. will spool 200rpms quicker. but the GT20(56) will give you more power. given the cost and ease of replacement..the TF is a good choice I think. TF looses efficiency after 1.2bar or so. if you get tired of TF..you can always move up the ladder to td04 or VF on the same manifold/downpipe. Gt20 has same T25 inlet flange. so its possible to go up to gt25/gt28 on gt20 manifold (lots of power potential),but you will need a new downpipe. hope this info helps. so true, the Subaru flanges give you nearly 15/20 stock turbos to choose from depending on your needs This is a statement I will never understand.Keep things simple and use the car, a car with half the horsepower that actually sees the track, is still 100% faster than one that sits in a shed being built to be different.i agree, keep it simple and cost within reason Quote
SpikeyJp_68 Posted June 7, 2017 Posted June 7, 2017 +1 for tf035 i have one on mine. Without a boost controller full boost of .5bar with a standard actuator @3400-500 rpm and will keep pulling until redline. Easy to keep on boost. Will only be better with a boost controller im imagining Quote
wakeabby14 Posted June 12, 2017 Posted June 12, 2017 I also run TF035 and the response is fantastic, Im running 1.0 bar of boost on a jam ECU not had her dyno'd yet but probs around 200BHP, I have a Wepr TD04 ramhorn kit coming with screamer TF035 is same flange as TD04 so going to pop that on and enjoy it! You want to ask colin on this forum he never stops going on about Tf035's he is your man to ask about it! Quote
Flower Posted June 13, 2017 Author Posted June 13, 2017 you have two choice 52 and 56. the TF is a decent substitute. will spool 200rpms quicker. but the GT20(56) will give you more power. given the cost and ease of replacement..the TF is a good choice I think. TF looses efficiency after 1.2bar or so. if you get tired of TF..you can always move up the ladder to td04 or VF on the same manifold/downpipe. Gt20 has same T25 inlet flange. so its possible to go up to gt25/gt28 on gt20 manifold (lots of power potential),but you will need a new downpipe. hope this info helps.Thanks for the info! That's is the valid point i am getting at. With a t4 flange I can go from gt20-25-28 at a later date. I have had a Glanza with a td04 with a WEPR top mounted ex gate and tbh from what I remember the lag was a lot less than 3500rpm.I just wanted to try a gt20 setup and probably move up to a GT2864 at a later date.It's a shame Borge warner don't do an EFR small enough for our engines Quote
