Shan Singh Posted July 8, 2017 Share Posted July 8, 2017 hey my glanza is literally drinking fuel my o2 sensor is plugged out. i recently bought it so havent done much. it has a tdo4 turbo running around 10psi with custom manifold, ported intake, 4age gearbox, copper clutch along with other small mods. i need any help i can get to solve this awful mpg. Quote Link to post Share on other sites
wakeabby14 Posted July 8, 2017 Share Posted July 8, 2017 hey my glanza is literally drinking fuel my o2 sensor is plugged out. i recently bought it so havent done much. it has a tdo4 turbo running around 10psi with custom manifold, ported intake, 4age gearbox, copper clutch along with other small mods. i need any help i can get to solve this awful mpg. Sounds about right to me, i run a TF035 turbo and i only get about 200 miles out of a tank and i dont even drive it hard Quote Link to post Share on other sites
5e colin Posted July 8, 2017 Share Posted July 8, 2017 you need to be more precice full tank drive it till its empty then come back with the accurate km done on full tank as these gauges are way of when mine reads empty i still have 160km to go before i need jerrycan !!!! Quote Link to post Share on other sites
Shan Singh Posted July 8, 2017 Author Share Posted July 8, 2017 you need to be more precice full tank drive it till its empty then come back with the accurate km done on full tank as these gauges are way of when mine reads empty i still have 160km to go before i need jerrycan !!!! my tank was exactly half way filled when i check and i only drove 139kms Quote Link to post Share on other sites
Shan Singh Posted July 8, 2017 Author Share Posted July 8, 2017 Sounds about right to me, i run a TF035 turbo and i only get about 200 miles out of a tank and i dont even driv you got 200 "miles" out of a tank i got 140km out of half of a tank Quote Link to post Share on other sites
Shan Singh Posted July 8, 2017 Author Share Posted July 8, 2017 also guys i need help with rewiring the 02 sensors since glanza's have 2 wire o2 sensors i cant pick that up where i live but i have single wire ones, i was looking at the ep91 ecu pinout and was wondering if i can run a wire directly from the ecu to the 02 sensor? will this work? check link http://1.bp.blogspot.com/-rosKml3sFaQ/TtA4VNXh7bI/AAAAAAAAATg/jW-wiYdSmIo/s1600/EP91+ECU+PINOUT.jpg%C2%A0 Quote Link to post Share on other sites
5e colin Posted July 8, 2017 Share Posted July 8, 2017 That means shit to us gauges very inaccurate do tank vs km Quote Link to post Share on other sites
morgey Posted July 8, 2017 Share Posted July 8, 2017 Best to fill up till the pump clicks off, do a good amount of kms 150-200 or so. Fill back up to the 1st click on the pump and make a note of the amount of liters you put in and the distance travelled. From that point you can then work out a fairly accurate mpg reading. (or ltrs/100kms if youd prefer) mpg is worked out ltrs/4.5 = approx gallons used. Then divide kms diven by gallons used. So for example 30ltrs/4.5=6.6gl 200kms/6.6 =30kpg (or 18mpg) As colin said the gauge can read miles out. Park on a hill, throw it around a corner accelerate or brake heavily and the gauge moves. Sent from my SM-G903F using Tapatalk Quote Link to post Share on other sites
Shan Singh Posted July 8, 2017 Author Share Posted July 8, 2017 i got yah Quote Link to post Share on other sites
maddox710 Posted July 8, 2017 Share Posted July 8, 2017 Would if thought 550+km (full tank) from stock ish glanza would be achievable with no drama Quote Link to post Share on other sites
5e colin Posted July 8, 2017 Share Posted July 8, 2017 I got 480/500km tfo 11 psi o.8 bar on stock ecu c52 turbo box. That's + - @few miles Quote Link to post Share on other sites
Calum122 Posted July 9, 2017 Share Posted July 9, 2017 I got around 300 miles to a tank. Only filled it up once but the car is just a CT9.My brothers TD04 is better on fuel since he can drive it off boost. Quote Link to post Share on other sites
Shan Singh Posted July 9, 2017 Author Share Posted July 9, 2017 oh guys i filled 19 liter in the tank plus i had a bit more in the tank so i'll say around 22 liters total i did the math im getting around 15mpg Quote Link to post Share on other sites
Shan Singh Posted July 9, 2017 Author Share Posted July 9, 2017 yesterday i also discovered that my car had no thermostat in, so i installed one now so far just the o2 is not plugged in. Any other advice? Quote Link to post Share on other sites
maddox710 Posted July 9, 2017 Share Posted July 9, 2017 Having no lambda probably ain't helping Quote Link to post Share on other sites
morgey Posted July 9, 2017 Share Posted July 9, 2017 is your tank rusted and leaking or even the filler neck allowing fuel to spill out. This happened to mine. Quote Link to post Share on other sites
Shan Singh Posted July 10, 2017 Author Share Posted July 10, 2017 i will inspect all these today but i highly doubt it Quote Link to post Share on other sites
Shan Singh Posted July 10, 2017 Author Share Posted July 10, 2017 oh i also smell petrol in the exhaust fumes not heavy though but i still think its not alot for it drinking that much fuel. i had a look at the fuel pump yesterday took it out and the tank was a bit pressurized, so i think it rules out a leakage in the gas tank. I just turned 17 so I have limited cash to spend on fuel so all advice will be much appreciated. Quote Link to post Share on other sites
morgey Posted July 10, 2017 Share Posted July 10, 2017 Sort the o2 sensor out, then id look at your intake temp sensor and coolant temp sensor if it thinks things are at different temperatures it can cause over fueling. Not sure on the proper procedure for testing the temp sensor but im sure someone will Quote Link to post Share on other sites
Calum122 Posted July 10, 2017 Share Posted July 10, 2017 17! FML, I couldn't even afford insurance for this car at 21 let alone 17! Quote Link to post Share on other sites
Shan Singh Posted July 11, 2017 Author Share Posted July 11, 2017 Sort the o2 sensor out, then id look at your intake temp sensor and coolant temp sensor if it thinks things are at different temperatures it can cause over fueling.Not sure on the proper procedure for testing the temp sensor but im sure someon i took a look at those, everything seems ok but i will have to figure out a way to test them out tomorrow. Quote Link to post Share on other sites
Shan Singh Posted July 11, 2017 Author Share Posted July 11, 2017 17! FML, I couldn't even afford insurance for this car at 21 let alone 17! hahaha insurance isnt a pain because i live in south america, Guyana to be exact only english speaking country here in south america :D Quote Link to post Share on other sites
federalman Posted October 13, 2017 Share Posted October 13, 2017 That is quite bad, and I don't run a lambda on mine! In all seriousness they aren't that economical with a TD04 or bigger. Quote Link to post Share on other sites
lukEp Posted October 13, 2017 Share Posted October 13, 2017 (edited) Hybrid CT9 with spirited/motorway runs 280-300mile to a tank. N/A gearbox so high revs at cruising speeds as well. Edited October 13, 2017 by lukEp Quote Link to post Share on other sites
5e colin Posted October 13, 2017 Share Posted October 13, 2017 15 minutes ago, federalman said: That is quite bad, and I don't run a lambda on mine! In all seriousness they aren't that economical with a TD04 or bigger. 15 minutes ago, federalman said: That is quite bad, and I don't run a lambda on mine! In all seriousness they aren't that economical with a TD04 or bigger. You are way of with that answer its 1 of the most feul efficient out there Quote Link to post Share on other sites
