7 hours ago, Kingjnr2677 said:
Aye Mike e boy,
Thought you would have a build thread on here!:)
Looking good and hopefully the engines in the car soon!:thumbsup:
Cheers Bro 8)
Engine in this week I hope but been saying that since February
  • Replies 196
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Almost D-day for engine refit
Getting there definitely engine in this week
So proceeded to buy a battery box for new battery then chop it up to meet my needs :crazy:
This will bolt into place of original battery tray that was removed previously.
I also found time to refresh old steering rack with a lick of paint and renew rack ends / trackrod ends . Along with blanking off power steering pipe work
While rack was off I swapped out fuel and brake lines with my other set , while also removing complete evap setup .
So this week seems to be the week for engine fitment fingers crossed
Last of all here is a pic of it's stable mates and also one of my main competitors being my auldmans highly modded phase 1 clio 172.  Having driven this a few seasons myself I know what I'm up against :sad:
Hopefully next update will be engine in the hole
Well some picture let the picture whoring begin :drinks:
That's it back where it belongs , feels like a milestone has been reached . The works office looks empty now !!
Engine trolley worked to an extent needs a few tweaks to work better but in the whole worked very well
On 25/03/2018, 14:08:35, Kingjnr2677 said:
13 hours ago, maddox710 said:
Looks epic!
6 hours ago, jimmymac101 said:
surely that cilo wont stand a chance ?
James
Cheers , hope it goes as well
I hope not but itb , gripper diff and a sorted chassis makes it tuff , oh and a good driver (my auldman) :D
it does a lot of this
Looking Awesome Mike, I'm sure you'll give dad a run for his money once all the handling is dialled in!
Small progress this week as was on holiday happy days :yahoo:
Anyhow
Intercooler mounted properly and 99% of intercooler pipes mocked up for welding with obx racing wiggens style clamps . Intercooler is rubber mounted so hopefully there's enough movement with the clamps.
I've tried to keep intercooler pipe work as short as possible , which involved trimming the slam panel and re-drilling intercooler . Not 100% happy with sizing of pipe work into cooler but hopefully doesnt affect it too much.
Mounted fuel pressure regulator and ordered rest of fuel fittings and socketless hose. Also mounted fuel pressure sensor as well.
List slowly getting smaller!!!
  • 3 weeks later...
I have no idea why other pics have disappeared.  But anyway there has been lots of progress even with the lack of updates.
The car now starts and runs :yahoo:
I replaced all the front fuel lines with aero fittings and socketless hose . Just before the first start up I downloaded a base map and set iso output settings after much advice from Matt at Motorsport Electronics .
So nervously tried starting using the ign key I primed the pump a few times watch fuel pressure gauge slowly climbing. Then pop the return rubber pipe at the fuel tank burst!!! :sad:
Bugger the only pipe I never replaced out of the lot , should have known better. Anyway after repairing that I still had teething issues mainly the cop not wanting to spark. After more help from Matt very helpfully decided to try distributor back in and magically it ran :clapping:
On 02/05/2018, 08:40:20, Patches said:
Awesome stuff man! Glad to see it fired up
Cheers
I'm well chuffed to get it running:clapping:
Anyway last week or so the ecu was sent back to motorsport electronics to check the issues with the ign drivers for COP conversion.
I've been informed it was a simple firmware issue and should be back sorted for COP :thumbsup:
While ecu was away decided to sort a few other items to get finished off. Mainly the brakes which consisted of fitting my custom mounting brackets and custom machined front discs along with bling purple braided hoses .
Which took longer than I thought to fit as had to order high tensile bolts for calipers and mounts.
Then due to my custom rear brakes not being quite finished decided to rock the original rear setup for this year as time constraints and money . So decided to drill rear discs to lose a bit of rotating mass every little helps.
Before
During
After
Lost almost 1/2kg each side
Finally due to my class rules had to modify front strut top mounts to remove sepherical bearings. Which consisted of getting nylon bushes machined and fitted.
Before
After
9 hours ago, Ryan.Truesdale said:
Just think how much surface area you've lost with those holes.
I know but for the intended use and length of tracks coupled with minimal rear braking , I'm hoping the lack of surface area shouldn't be a problem
  • 1 month later...
Long over due update !!
Well to cut along story short it's now running coil on plug and is mapped at 1 bar of boost and making full boost by 3000rpm 8)
I've covered 500 miles now that it's on the road just suspension to tweak before first race
206bhp
3 hours ago, daniel_g said:
Did you get the me221 working with COP? Also where did you end up for mapping?
Yes
I got it sorted out and working with the cop :thumbsup:
I used Matty at MB motorsport ellon who I recommend
5 hours ago, maddox710 said:
Some really nice numbers mate well done
Cheers
Was hoping for more but don't we all !
Main thing is how quickly it comes on boost
1 hour ago, jayc-glanza17 said:
Whats the rear brake upgrade you mention mate?
I've a friend helping to make custom rear brakes using Kad mini light weight calipers
