Jeff's Spec Sheet
The JDM list
Came on the car
Factory Front lip
'No Smoking' ash tray
In-dash Cup holders
Illuminated ignition barrel
Toyota mats
Clear brakelight in spoiler
Wind Deflectors for front windows
JDM Flare
UV cut glass
Added after
Recaro Interior
Centre Arm Rest (covered in Recaro fabric)
Optional Duck Spoiler
TRD engine mounts
TRD Oil filler cap
TRD short shifter and knob
Toyota handbrake cover
Full set of Toyota Starlet Glanza V brochures
Starlet manual (in Japanese & Translated version)
TRD Dial surround
TRD centre console and window switches
TRD SRS airbag steering wheel
Assorted TRD mounts
Toyota toolkit
Toyota Rescueman III
Toyota emergency triangle
Spec List
Suspension/Handling
TRD fixed shocks with RS-R Ti2000 springs
Cusco top mounts on rear, camber plates on front
Cusco front/rear and lower strut bar
Cusco panhard rod
H&R 25mm hubcentric spacers (front)
Ichiba 15mm hubcentric spacers (rear)
Rays TE37 / WedSport SA-90 alloy wheels
Toyo T1-R / Uniroyal RainSports
Volk Racing & Weds centre caps
Standard front anti-roll bar with Superflex poly bushes
Whiteline Anti-lift-plates
ZEP floor bar
El-Sport C-Pillar bar
Whiteline rear ARB
ZEP drop-link poly bushes
PRI front lower-arm poly bushes
New track Rod Ends and hub bushes
Exterior
Cruise fenders
Cruise bonnet
JAM rear bumper with black mesh
HRF sideskirts
Front bumper modded to accomodate FMIC
Reflet rear lights with fog light wired into cluster
Clear hi-level brake light
Silvatec indicators
TRD petrol cap
Philips X-treme Power headlight bulbs
PIAA H3C Super Plasma FX bulbs
PIAA satin black wipers with spoiler
Punto mk2 rear wiper
Ultra 400/480hz horns
Engine
Forged block (Ross 74.5mm pistons, Pauter forged rods, oil pump, bearings, etc)
Ported & polished head (Cruise valve springs, Athena 1.4mm headgasket , ARP head bolts, Zisco valve stem seals)
SARD K24-2460g turbo kit, SARD manifold, SARD C-II wastegate 0.8bar spring
Powder coated rocker cover (Anthracite)
Samco air filter relocator with Apexi filter
Iridium Spark plugs - Heat range 8
Speedvision 265° cams with Tuner's Edge adjustable cam gear
Ported and polished inlet manifold
Attain Hi-Throttle
Apexi air filter off turbo with Samco relocator hoses
GReddy FMIC
JAM cooling panel
SARD thermostat
Honda Civic alloy racing radiator
SARD rad cap
Torque Engine damper
TRD engine/gearbox mounts
Blue hosing in engine bay
Blitz upper and Samco lower radiator pipe
SARD RRFPR
Blitz Dual SBC Spec-R Boost Controller
Zisco custom 2.5" straight through, cat-back system with Blitz Nur-Spec backbox
Royal Purple Racing-41 10w40 engine oil
GRex Oil filter relocation kit, SARD drenplug+ and SARD Mag oil filter
5Zigen oil catch can with Earls AN10 fittings and black braided lines
Ultra power leads and king lead
Pivot grounding system
HKS circle earth kit
HKS fuel rail with Earl's fittings
Walbro uprated fuel pump
Auto throttle body and TPS
HKS F-Con V Pro Gold Ver.3.1 and 460cc injectors
Custom loom
Transmission
TRD shortshifter
TRD gear knob
TRD helical LSD
Earl's braided clutch line
TC brass gear linkage bushings
ORC ORC-309DS-14T rattle-suppressed clutch
Silkolene Gearbox fluid
Brakes
ABS
Endless Micro-6 Front brakes with Endless braided lines
Endless 2-piece discs 262x21mm
APP rear braided brake lines
Cusco Brake Cylinder Stopper
Comma 5.1 brake fluid
Interior
Mc Monster House carbon fibre binnacle surround
TRD dial surround, Centre console and window switches
Blitz fire controller/extinguisher
Recaro SR-II driver and passenger seat in fabric to match optional trim
Factory Recaro Interior
Centre armrest re-trimmed in Recaro fabric to match seats
DEFI-BF Boost, Oil temp & pressure, Water temp & EGT Gauge and Controller-II
Audio
Sony Mex-BT5000 head unit
2 x Sony Amps - 1x XM-754HX & 1x XM-D1000P5
1x Sony 12" XS-LD125P5 Hexagon sub
Nakamichi PC-100 Crossovers
Nakamichi SP-10 tweeters
Nakamichi SP-50 5.25" mid range drivers in custom door pods
Nakamichi SP-200 speakers on rear shelf
Parts received but not fitted
Blitz wristbands
Powerflex Rear trailing arms polybushes
Door speaker pods
Mitsuba Alpha horn
Ordered
Nowt
Wanted
Roof re-sprayed, overall paint tidy-up
Mapping to 250bhp ish
Roose Motorsport ancillary hoses
ABS removed
Work in Progress
Mapping
Bodywork repairs
Original pic from JapanMotors.biz
As i am sure most of you will know I have got a new later-spec Glanza V, I have had it now for the past 3 weeks, and had so far changed the seats and alloys, but said I would leave the rest standard for a month to get used to it.
Unfortunately I had a moment of weakness and with the additional bonus of being able to meet Shelly, I took my car to Sittingbourne to her cousins company - Impulse Performance, to have the D2 coilovers (that i had got from them from a previous group buy) and a Whiteline pan-hard rod fitted - the guys did a great job and were true gents, Shelly is as lovely as we all think she is too lol, she took some pics of both of our cars that I hope she will post later.
Well in true Blue Peter style here's before
and here's after:
its a far firmer ride now as the springs are bedding in but they have improved the handling incredibly and make it sit with a far more aggressive stance.
Oh this pic made me laugh too, so i'm including it for the hell of it:
<_<
  • Replies 595
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 weeks later...
got this today from the guy i bought my car off, another mod to add to my future list, already got twin pot brakes to go on, this rear bar, front under bar, bov, the list goes on n nothing gets done lol
  • 2 months later...
Done a few little mods, as they say the devil is in the details. So...
...Reflet rear lights
also got rid of that horrid SVA-passing rear fog light, its now wired into my rear cluster, it still operates as a side light and uses the second filament for foglight purposes
TRD oil cap, regards of Toby's group buys
GLS binacle surround, got this off of Rick really improves the look of the dials i think
still loadsa bits to go on but other bits need doing first, my calliper bolts have seized so theyv gotta b cut off first before anything else happens
  • 2 weeks later...
few little changes
start off with a simple equation
DSC00539.jpg + Rays_valve_stem_blue.jpg + thValves2.jpg = :)
DSC00539.jpg + Rays_valve_stem_blue.jpg + thValves2.jpg + DSC00979.jpg = :p
Because without those rings i could not fit my alloys, they werent exactly right, they sit 0.5mm proud n are 1mm to narrow but they work with a bit of electrical tape n something sticky to keep em off the ground - how bout some Toyo T1-R's?
oh and i got this little Cusco goodie fitted too
oh i also had the suspension raised 25mm too and here's the finished article
  • 3 weeks later...
Got this through the post yesterday (TRD shortdshifter and gear knob) so on it goes, accompanied by my handbrake gaiter from Toyota, nice close change you can feel the difference
  • 2 months later...
ah got a few bits to go but this is gna help toward a bit of power, just picked up a set of 256 Cruise cams off Si,
here are some other bits hidden away from my unsuspecting mother in the loft:
Whiteline anti-lift and Samco rad hoses, and (safety first) forged pistons
TRD mounts
just need some forged rods, a Cruise headgasket, ORC Clutch and a SARD RRFPR and ill be set, oh and i wanna SARD K24 turbo kit
  • 3 weeks later...
  • 4 weeks later...
Ive got most of the parts for my 2pot levin conversion now, gna go and see HiSpec after xmas to see whats gna be cheaper, cutting the discs to size of standard glanza or having a bracket made up.
Prob cutting to size, either way getting some groovage in the discs too, so here are the parts i have so far. Cusco BCS is fitted already, here we have braided lines, Levin twin pots (soon to be satin black), the disc spacer and standard pads, still waiting on Levin Endless pads that i bought in the group buy on TGTT. Just need some 5.1 fluid and some longer wheel lugs oh and some time to do it all then will be finsihed yay.
The discs themselves are mahoosive, 275mm wide, 25mm thick, The V uses 253mm wide and 22mm thick.
The lines i got from Si's breaker and also the spacers that fit inside the disc to give enough room
The callipers i scored for £150, gna have to rub em down and paint em satin black though
and the whole gang together
Yay new stereo was fitted on friday (early xmas gift),and I&#39;ve got the calliper paint i was after to paint my brakes, now all i need is the time to paint em
Sony Mex-BT5000
Thanks guys, yea its bluetooth so i can answer my phone and also stream and play music from my phone on it
As far as costing the brake parts,
Callipers - £150 from JB Motorsport
Discs - £100 from toyota
Lines - £50 from Simon
Spacers - £80 sourced form Japland with Si's help
and just got some satin black paint that im gna give em a coat of to funk em up a bit
also they came with standard pads, but I&#39;ve ordered a set of Endless SSS pads form Envy for £105, waiting on them at the mo
too weird only just typed that ring of the door bell package form envy, id only paid a deposit lol better get on the phone n send em the other £85 lol
Look a pretty funky blue tho sweet
  • 4 weeks later...
not as much as me man, ordered it on the first of Jan, i know they didnt start again til the 10th, but the thing is if u pay for ems 3-7 day postage and they pick the order up on the 10th should be here today or tomorrow at the latest, theyv said i can have my money back - but i took day off work to fit it and everything - also if they say that suggests they havent sent it yet!
As i am sure you guys have realised, the twin pots are on and sexual they are too, think im going to have to re bleed the brakes tho gone a little bit spongey, but here they are:
[img]http://i2.photobucket.com/albums/y44/SiCaln/TwinPots/Done.jpg[/img]
Pretty nice through the wheels too. Myself and Rick are fitting some other parts today so ill post some pics up later.
  • 2 weeks later...
We made some massive progress today!
Well i think so anyway, managed to fit my mystery item, try out the cooling panel and re-fit my HID lights yay.
Well here u go anyway, before
During
After, pretty swish i reckon, sucks better than Monica Lewinsky too!
All praise too Rick your a legend mate cheers for all your help mate!
  • 3 weeks later...
just got this today, much prefer the look of this Blitz dual drive bov to the earlier trumpet ones, but i need to ask what is the point of the silver tube? and where does the bracket go?
  • 2 weeks later...
not a good moment, someone hit me in the rear today - i was stationary at traffic lights, he was doing bout 30-40mph i reckon im gutted
took it to local repairers, they have said im gna at least need a new boot floor and bumper, could even be a right off, i am gutted
well we just got off the phone with the guy who hit me, what an a-hole hes saying i braked hard, erm dont think so, further than that he says he knows cars and £1000 labour is too much, the car is only worth £1500, yea he knows cars alright!
the guy who was with him at the time turns out to be his boss, not his dad and he wasnt there - so the car was company insured and he gave us all the verbal like bring it to northfleet tomorrow well get it fixed, again no, well get it fixed where i wna get it fixed
he said his boss will be there this time tomorrow and to phone him then, so im gna give them the benefit of the doubt and do that, then im gna go through insurance
yea i know, phoned him with my dad and put him on speakerphone and even my dad said what a chavvy c**t and he hates that word, he couldnt understand him either lol but its ok because the bloke 'knows about cars' and my cars not even worth £1500, what a cock lol
oh and i have contacted insurance already did it on they day, but they said id have to pay £550 excess and £50 legal cover, so try n get him to initiate first, if not come back to us, good of em i thought - so were gna phone the boss tonight and take it from there - if i do have to pay out it shouldnt affect my no claims and i will get it back - after all it was his fault, knob sack
Right, well surprise surprise im gettin the run around, phoned and he said he couldnt talk because he was driving phoned back 10 mins later was being very arsey, refused to let me talk to the boss, or even tell me the name of the company
so I&#39;ve phoned the police reported the incident and im gna go to my local station with my details and they'll help me get the information i need to hopefully process a claim
ok had a few new developments - the police werent all that helpful, and when i phoned him last night hes changed his phone number!
So i thought y pussy foot around anymore i told my insurers to see if he was insured, they checked his number plate on the system and nothing came up, but then i mentioned he said he was with Norwich Union and what do u know the little fuckers on there!
NI wouldnt give out details without starting a claim, so I have sent over some quotes and hes gonna start the ball rolling on monday! as if the little shit thought i was just gonna roll over and take it!
Lets take this cunt down lol
