  • Replies 514
  • Created
  • Last Reply
Top Posters In This Topic
  • 3 weeks later...
Just too let you know next time i see you im stealing your cage :p, looks meag dude ! If you need a hand with owt give me a shout, got me an engine too build over the next month or so myself ;)
Edited by Starbo Moorley
Does look fit!
You have the same wastegate as me :). I had a 0.8 and a 1 bar spring in together and it boosted 0.8 instead of 0.6 which was slightly better. But in the long run the best way to do it is run a boost controller in line from the signal to the bottom port to the top port. Ie t piece into the signal from the compressor housing, boost controller, then modified signal to the top port. I just used a buggered manual turbosmart one off Kurt and it worked a treat :)
