NO!
the GTs can do it! there must be a way of doing it on the 91s!
how did Joz do it?? JOZ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Phil.
GTs dont have airbags though :)
I'm sure there's a way of doing it! It's so annoying because when you need to horn at someone you end up looking for the button and they opportunity has passed :) lol
I made a way but the wire just gets tangled on full lock :)
I Just put a horn button in and connected the two clips and it works :)
Dont you have two wires coming out of the boss kit?
Yes i do, but was your boss kit air bag or non-air bag?
You need to get a boss kit with a contact strip on it for the horn, if you look at the back of the standard wheel there is a brass ring which contacts with a little pin on the steering column. If your boss kit doesn't have the brass ring you could stick one on then solder a connector onto it to connect with the horn button.
It isn't as easy as some might think on the EP91 there are 2 sorts of:
Dash wiring looms
Indicator stalks
Steering coulmn plastics
Steering wheels
It's not a 96 - 98 break either as i have 2 96's and they are both different. One has a contact strip for the horn the other one uses and different setup.
Simon
I have the brass ring but didn't see the little pin on the steering column :)
Mines a OMP non airbag boss kit, you could buy one of them of ebay Phil, and it should work out fine for you? There a bit cheaper than them Daikei ones too.
