  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Popular Days
condensation?
hot air and oil going into a cold alley catch can?
put your old rocker back on and run standard setup just to make sure its not that
Looking at the lines and inlet on the can that looks like hg to me dude. could just be bad luck. What boost you running? What headbolts are on the recipt for fitting? Is a weekends work to fix but idealy get the head skimmed and crack/preasure tested.
Tbh mate compression test just shows its not blowing by on a cylinder. could just be a slight lift between an oil/water way. is all it would take tbh :(
condensation?
THIS!!!
I had a catch can setup on mine and it did exactly the same its just normal as its hot air condensating mixed with oil
My headgasket wasnt gone and neither is yours by the look of the results
Would of thought its just condensation mate. if your worried just do a compression test but i cant see it being a h/g.
only started tweeting since i put the new inlet on, all bolts are tight , everything in place,
its only on idol it tweets even when warm, i can see it getting annoying lol
but yeh im so glad its not HG!
i didnt think it could be as tuning developments give the engine a full rebuild about 3 years ago and the head gasket was only done a year ago by them too, looks like i cant use a race spec rocker cover for my style of driving :( as i only go a couple of miles the condensation builds up.. probs be for sale soon....
