Rob H's TD05 16G 4EFE SR Inlet and 8 injectors!! 256.7hp@ Wheels
  • Replies 640
Theres no need as such but 8 smaller injectors can give a much cleaner tune than 4 big ones, my ECU can run 10 injecors siquentually so it will only use whats needed, run less pressure so the injecors are not over fueling at low loads, just a much better way IMO plus this build is all about been different!
Well I finally have 2 fuel rails not a perfect pair but close enough for me!!! after 4 attempts at the second rail I managed to get the hole down the middle! I broke the drill bit in the process too so its a good job lol
The broken drill!
1014D70E-4620-451B-9373-AD4096579D9A_zps
EBD809BE-6A85-40D2-88D3-E4DD3CC2AC12_zps
F9B4087B-4C9A-4122-B510-76661EBFB10C_zps
Machining it
6B60EBE1-CA9B-4E04-BF96-D361F1AD5919_zps
I have started making up the fuel pipes too but I will finish them once I have the fittings welded onto the rails.
BD4C44F2-6698-4D9B-A7C3-E01D8A029EB5_zps
1EE7171D-72F4-49BB-A2B6-DC7BFFF3CC7E_zps
Manifold temp fitted with the rails!
D2544EBF-9D66-48CD-94EE-025DACAE197C_zps
44F1726C-BBD9-4D56-96A8-C5BF239D2EF1_zps
2850A0FA-4334-4798-8DDA-C4CA1A67EDCC_zps
Well suck me Sally.
Just spent my first 1hr 39mins of work reading every post on this build thread.
Cannot wait to see this thing out and about, it makes my build seem so amateur.
Seriously cool build, i know the hours and cash that goes into something like this.
Made props to you bro.
Keep up the good work!
Well suck me Sally.
Cheers mate! There sure is a lot of time in this build lol money too! But thats what I enjoy about it!
Got a few more little bits done! I made a new map sensor mount as the sensor was just about hitting the strut brace with the other one so I made it fit to the side this time.
60A2DA03-3A23-49EE-BDF0-F39CD65CB468_zps
DC9D0CD1-2FE6-469D-BAB3-82D49CDBB384_zps
And I also fitted the fuel pressure sensor for the ECU to one of the rails, It used to be in the end of the feed pipe banjo bolt but I wont be running any of them now! Plus its tucked nicely out of sight now too!
9950CE0A-0109-4908-ADE9-10CDE49E93FF_zps
5D27A4DC-A953-48DB-AC9B-A407131A7236_zps
