Rob H@RCH Engineering Posted June 20, 2012 Author Posted June 20, 2012 (edited) Its I have ever done mate I have lived at the garage since I was 4 and its been in the family almost 100 years lol so between me and my dad there aint much we carnt do! I draw the line at tuning and the more complex wiring stuff tho, spanners and hammers all the way for me lolIm 32 this year!! Edited June 20, 2012 by Rob H Quote
Asad Posted June 20, 2012 Posted June 20, 2012 quick q, how are you getting the oil to the turbo? i see no holes tapped into the block and a oil filter relocator...... Quote
Rob H@RCH Engineering Posted June 20, 2012 Author Posted June 20, 2012 with this! the oil feed is taken from the sandwich plate I welded a lump onto the side and drilled and taped it out to take a oil pipe. Quote
Socks Posted June 21, 2012 Posted June 21, 2012 Clever. I cant help but think tho, why not just use a fte oil filter housing...Then I think well why not just use a 4E-FTE engine?Well done for being unique tho dude, loving it Quote
Rob H@RCH Engineering Posted June 21, 2012 Author Posted June 21, 2012 I could of gone down the FTE path but I been there done that lol I was one of the first to do it!! I have 2 or 3 FTE blocks I could have used and a full engine but I dint want to do that as every one and the grany is at it!! I like to be different so why not! Quote
Rob H@RCH Engineering Posted July 14, 2012 Author Posted July 14, 2012 Well I gave the car its first wash for over a year!! this is how it looks still more to do and the body work needs some tidying up in places.What ya think?? Quote
LukeSR Posted July 15, 2012 Posted July 15, 2012 Looks sweet mate, loving that engine! Also, is that mat on top of the dash an optional extra?? Quote
Nanglebadger Posted July 15, 2012 Posted July 15, 2012 looks insane rob!!!!! fantastic, inspirational work sir!!!@Luke - no, those are not a factory item.Phil. Quote
Rob H@RCH Engineering Posted July 15, 2012 Author Posted July 15, 2012 Thats my second dash cosy I have had they come from Australia they have them to stop the sun fading and cracking the dash I like them because they stop the glare from the dash too. Quote
_shaun_ Posted July 15, 2012 Posted July 15, 2012 love this only thing am not so keen on is the seats think they need a refurb! dont supose u would let slip what the ecu set up cost you? Quote
Rob H@RCH Engineering Posted July 15, 2012 Author Posted July 15, 2012 The ECU on its own was just shy of 900 quid I did most of the wiring loom and fitted all the AEM sensors, I also made all the custom bits like the trigger wheel set up and the mountings for the coil packs. To put a price on it with the mapping I think it would be over the 3000 mark for the full set up. It cost me a lot less as I did most of the work involved and I did a lot of hours work for RDT in exchange for his time on my car so I saved a small fortune lol Quote
_shaun_ Posted July 15, 2012 Posted July 15, 2012 ahh thats handy when u can do it urself id be fine with wiring but when it comes to fabracating i just dont have the tools to even try. trying to find a good standalone but there appears to be just to many choices Quote
Rob H@RCH Engineering Posted July 15, 2012 Author Posted July 15, 2012 I went with this one as it was recommended by the the mapper its always a good idea to go with a ECU there familiar with there is ECUs out there that are a lot more straight forward to fit than this one too but it does every thing I needed and a hell of a lot more! Quote
Rob H@RCH Engineering Posted July 16, 2012 Author Posted July 16, 2012 Got a bit more done this week end and today, Welded the silencer into the exhaust also made a jig so I can make different pipes lol that just bolt in, fitted the pacet 13" fan that is a awsome thing compared to the cheep Ebay special it shifts some air lol. I made all custom brackets for mounting the fan on as its front mounted will take picks of them later on as I dint have the camera at hand.I made this today for the idle control valve I am using a FORD one lol It needs to be a 2 wire one unlike the Toyota 3 wire one plus the toyota one was poo lol.TB with stock ICV4mm ALU plate I started withCut out and drilled I made the holes the odd shapes to make them as big as poss and still match the valve and the TBFitted and valve bolted on!Quick polish before I fit it to the car at the week end! Quote
Rob H@RCH Engineering Posted July 22, 2012 Author Posted July 22, 2012 Got the idle control valve fitted today it just needs wiring into the ecu now.Also fitted the 98spec glanza steering wheel it looks so much better than the old one! Quote
Rob H@RCH Engineering Posted July 31, 2012 Author Posted July 31, 2012 small update! The boss was not happy with the Cusco Diff so I decided that this was the way to go!So I got the spare Gearbox out and had it checked over and a full strip down to make sure every thing was good and yes I got my ££££ out this time lol. once I got it back 3 day turn around! I could not have done it in that time with work, I gave it a good cleaning ready for the new shaft seals coming from Toyota tomora and fitting. Quote
Flaminsam Posted July 31, 2012 Posted July 31, 2012 saw these pics on facebook rob. looking nice and clean! Quote
Rob H@RCH Engineering Posted August 17, 2012 Author Posted August 17, 2012 Well I best put these on! still got hi boost to sort out once the fuel pump controller comes we can get it mapped and all the other bits set up like the traction control, launch control, anti lag and boost by gear, dont really need the anti lag as the TD05 is hitting full boost under 4000rpm but its there so may as well have it!!! Quote
Rob H@RCH Engineering Posted September 28, 2012 Author Posted September 28, 2012 Well I was going to get a welder at one of the bus garages I work at to weld me 2 -10an fittings onto the rocker cover but he was too busy to do it for me but he did say the TIG is over there go have a play with it lol, I have never welded ally with the TIG I have weld stainless before but thats completely different! After about half an hour of plying I thought stuff it lets have a go! This is how it turned out not the neatest but its something els I can say I did that!! lol Just need to sort a better catch can now! Quote
markostarletturbo Posted September 29, 2012 Posted September 29, 2012 Amazing work I've been in this and even at low boost it's quick and is in no way laggy? will be insane when running high boost very tidy too especially the bay Quote
