  • Replies 469
  • Created
  • Last Reply
Top Posters In This Topic
Thats shit mate, hope you get it sorted. Pretty sure you can get black braided pipes too :)
Yeah sorted it straight after work, just some standard efi hose on there atm for now and il order some braided when i get a chance
You can get braided hose with a black plastic coating we use them at work.. pirtek sell them I believe, nice v by the way
Nice one buddy :)
  • 1 month later...
  • 2 weeks later...
UPDATE!
Been busy the last few weekends since i last updated this, managed to get a few bits done on it
Fitted a new alloy radiator
New toyota coolant
Oem thermostat
Oem thermostat housing seal
Also been tucking some wires and hiding vacumn lines in the engine bay.
Relocated fuel pressure regulator and fuel lines.
Oem valve cover stud
Oem valve cover seal washers
Oem dizzy dhaft seal(basterd oil leak)
Took amber courners off and cleaned clear leans up and put them back in.
Got and crack old snapped stud out and put new one in along with washers from id-works
Old indicators came up just like new wish a soapy was inside and out, chrome bulbs helped with the look too
New full size rad and toyota coolajnt inn
Made a bracket for fpr like its position there fuel lines now take a nice route through the bay :) and all vacumn lines are cable tied neat and put out the way
Got some plans for this :)
  • 2 weeks later...
just a little update of whats come in the post today :)
tbh the box isnt a good clue too what it is or for. but here it is, have a guess
hope to be running this in the near future :)
next too a tatty old one
c+c welcome
Oh shit, any more info on it? Is it going in your td04??
Td05 big16g thats the new turbine shaft as the others tht i had were shagged.. might go billet compressor wheel :)
Well robert its proving to be costly, I've been talking to the guys at blouch to see what its gunna take to rebuild it at their spec. Wonder if anyone has run a blouch td05 on a starlet before ???????
  • 1 month later...
brought this little beaut of spoontuned
it has wossner piston and scat rods
Not really sure on the rest of the spec of the engine but will be stripping it down soon to inspect and clean.
will be putting new head arp bolts and athena head gasket. And verious new gaskets+seals on
Had a littlw strip down today took the sump,valve cover and plugs out to have a look see whats what. Aiden already whipped the sump of when I went to view the engine.
Eveything looks really clean underneath.
looking down the plug wells you can see the stampping ontop of the wossner pistons( camera phone pictures )
and scat rods ?...
How can you tell if I have ARP head bolts in??do they have an ARP stamp on the top of the bolts?
Tomorrows job will be to clean up and clear all the shity old silicone that was used to seal the sump
