Alright lads, thought i should join on here as I now own keirz' glanza, bought yesterday. And couldn't
be happier with it,cars ace :D
Will keep you posted later n ill throw some pics on after a lil clean :)
Cheers
Thanks everyone wernt expecting that many welcomes! Lol first thing is apexi avrc controller and some 98 spec lights for the
rear and some rotas eventually then onto management again :)
Don't think you'd NEED to change the pump as such, would be worth doing for piece of mind though. I'm upgrading to a walbro when I go td04
yeah its a shame i sold the jam ecu then you could have it full power. Will get that wastegate spring posted to you when i can that will solve the fuel cut. Enjoy
Yea sound keirz, got that manual boost controller still swear you said thaton text
Just been chatting to my dad n he reckons a cheaper way for now to get the boost holding above fuel cut is to get
A dawes device and a fcd n also a question to someone. Whats the standard map sensor on these? 1bar?
Surely if I upped the boost to 1bar on standard management, used an fcd and dawes device to set at 1bar, the fueling would be fine because the map sensor reads to 1.2bar?
