Matt1878 Posted February 17, 2013 Posted February 17, 2013 This is doing me in now lol!! I want to get my seats fitted but can't sort out my seatbelt issue..The seats did not come with the seatbelt clips and I've been told that Glanza clips don't attach to the MK1 seats? Also MK1 clips... Don't work with glanza seatbelts eugh!! Anyone know for sure that this is the case?My other option is to use harnesses. I don't know anything at all about harnesses tbh. There obviously legal? But are there different types? How do they feel? Where do they attach?.I would rather use the seatbelt but will always go to harnesses If need be.Cheers, Matt. Quote
_shaun_ Posted February 17, 2013 Posted February 17, 2013 cant u just make a custom bracket for the glanza clips to go on the seats? thats what i done for my recaros while i waited on my harnesses to arrive. there's loads of options on harnesses main question is do u want to keep your back seats. i prefer the harnesses if am honest its all hard tight corners round me so the harness kinda holds you in place Quote
Matt1878 Posted February 17, 2013 Author Posted February 17, 2013 cant u just make a custom bracket for the glanza clips to go on the seats? thats what i done for my recaros while i waited on my harnesses to arrive. there's loads of options on harnesses main question is do u want to keep your back seats. i prefer the harnesses if am honest its all hard tight corners round me so the harness kinda holds you in placeBack seats have been out for ages dude whole rear is stripped! Quote
TrisK Posted February 17, 2013 Posted February 17, 2013 Have you actually taken the seat belt to the buckle and looked if it clips in? Quote
daniel_g Posted February 17, 2013 Posted February 17, 2013 The actual mounting point is different though, even different to other GTs. If it does clip in you'll still need to fabricate up a bracket to mount it to the seat. Best bet would be harnesses i reckon. Quote
Matt1878 Posted February 17, 2013 Author Posted February 17, 2013 Anyone have any info on harnesses for me? Different types?Rough price? Mounting points? Quote
rmsnoel Posted February 17, 2013 Posted February 17, 2013 I took the seatbelt off the glanza seat, straightened the bracket alittle and fitted them where the rear inner subframe bolts to the floor of the car. It past mot each year no problem Quote
Matt1878 Posted February 17, 2013 Author Posted February 17, 2013 I took the seatbelt off the glanza seat, straightened the bracket alittle and fitted them where the rear inner subframe bolts to the floor of the car. It past mot each year no problemAnd this is with MK1 GT seats dude? Quote
rmsnoel Posted February 26, 2013 Posted February 26, 2013 Yes dude the same zebra stripe seat as in my profile photo Quote
Matt1878 Posted February 26, 2013 Author Posted February 26, 2013 What have you done with regards to seatbelts? .. Also which bits did you have to cut down to fit them? Quote
Rob H@RCH Engineering Posted February 27, 2013 Posted February 27, 2013 I took the seatbelt off the glanza seat, straightened the bracket alittle and fitted them where the rear inner subframe bolts to the floor of the car. It past mot each year no problemThis is how I did mine too, works a treet just get some longer bolts as the stock ones are a bit short I thought when I did mine. Quote
