Jdmasfuck Posted March 11, 2013 Posted March 11, 2013 as above guys i forget i have one sometimes does it really make a difference , does it turn the boost higher ? what does it do ? how does it do what it does ? or is it a gimmicky button that does fuck all !! thanks in advance starleteers !! Quote
Lawless Posted March 11, 2013 Posted March 11, 2013 Press it while driving and you will find out ;) Quote
Beastmode panda Posted March 11, 2013 Posted March 11, 2013 Are you seriously asking what a 'high' and 'low' boost button does? Why would it be on the car if it doesn't work? I don't even..... Quote
H_D Posted March 11, 2013 Posted March 11, 2013 It does have a use if it is still plumbed in. IIRC high boost is 0.7bar and low boost is 0.45bar. According to my manual Low bosst is for wet and icy conditions. Quote
Socks Posted March 11, 2013 Posted March 11, 2013 If the system hasnt been removed... On Low Boost you will get 0.35barOn High Boost you will get 0.65barin a GT Turbo If its a Glanza you will be in Low Boost Mode in 1st and 2nd gear regardless of the switch... Quote
russ78 Posted March 11, 2013 Posted March 11, 2013 ^^lol a settled in member with 112 posts it is a little bit of a newbie post, of course it works Quote
Danb Posted March 11, 2013 Posted March 11, 2013 It's for built in air rideLow drops it 30mm from stock Quote
Jdmasfuck Posted March 11, 2013 Author Posted March 11, 2013 Lol at the replies , not used to pressing hi lo boost buttons tend to forget ill use it from now on Thanks for clearing that up for me Sorry for the retarded question but does it work when the boost is turned up to say 1.1 bar does it seperate it by the factory programmed ratio as per figures posted above by yourselves ? Quote
Matt1878 Posted March 11, 2013 Posted March 11, 2013 It won't work if you have bypassed the boost solenoid (glanza) .. The low feature will no longer work. Same for if you have taken out the stock efi pipe and have a front mounted filter Quote
Jdmasfuck Posted March 11, 2013 Author Posted March 11, 2013 Oh well I guess mine doesn't work In my case Fucking gimmicky shit lolTake it easy on me starleteers I'm a newbie you were there once upon a time by the way any one got any oem mats for sale ? Quote
Beastmode panda Posted March 11, 2013 Posted March 11, 2013 It's not a gimmick at all lol.. It's just most people with a starlet run more than factory power, there for they bypass/loop the hi/low boost, that's all. If you want to run more than hi boost from factory then you get a boost controller or as said, loop the hi/lo and adjust your actuator (if its adjustable). Quote
Socks Posted March 11, 2013 Posted March 11, 2013 Oh well I guess mine doesn't work In my caseFucking gimmicky shit lolTake it easy on me starleteers I'm a newbie you were there once upon a timeBtw any one got any oem mats for sale ? The minute you start tuning the car... Your going to loose this feature and you will be in hi boost all the time ignore the "legends" there all a bunch of know it alls Give them some shit back Quote
Jdmasfuck Posted March 11, 2013 Author Posted March 11, 2013 This is my first turbo performance petrol car ! Got a lot to learn I've been mostly vtec before I understand now thanks for clearing that upIt's one less thing to worry about now !! Quote
Socks Posted March 11, 2013 Posted March 11, 2013 This is my first turbo performance petrol car !Got a lot to learn I've been mostly vtec beforeI understand now thanks for clearing that upIt's one less thing to worry about now !! Nice to have noise and power...? and not just noise ? Quote
corofin12345 Posted March 11, 2013 Posted March 11, 2013 can also be used as a cut off for a blow off valve.. dump or flutter Quote
Jdmasfuck Posted March 12, 2013 Author Posted March 12, 2013 The reason why asked the question was because I didn't feel any difference in power !Corofin what do u mean cut off for a blow off Quote
maddox710 Posted March 12, 2013 Posted March 12, 2013 Its supposed to aid grip in wet conditions, less boost less wheel spin Quote
corofin12345 Posted March 12, 2013 Posted March 12, 2013 (edited) The reason why asked the question was because I didn't feel any difference in power !Corofin what do u mean cut off for a blow off the high/low solenoid is basically a valve... so i used it for the the blow off valve (dumpvalve).. when you cut the vacuum source from a blow off valve, the blow off valve wont operate, so you get turbo flutter.. using the high/low solenoid and switch in the cabin, you can alternate between the blow off valve dumping the air "high mode", and turbo flutter in "low mode" nothing to do with boost, just another way to use the high/low solenoid thats all.. this was the result when i did it Edited March 12, 2013 by corofin12345 Quote
Jdmasfuck Posted March 12, 2013 Author Posted March 12, 2013 the high/low solenoid is basically a valve... so i used it for the the blow off valve (dumpvalve).. when you cut the vacuum source from a blow off valve, the blow off valve wont operate, so you get turbo flutter.. using the high/low solenoid and switch in the cabin, you can alternate between the blow off valve dumping the air "high mode", and turbo flutter in "low mode" nothing to do with boost, just another way to use the high/low solenoid thats all.. this was the result when i did it mate thats fucking awesome mine just dumps theres no flutter i need to look into this bud Quote
Neo Gold Posted March 12, 2013 Posted March 12, 2013 He already posted it!!..., great idea there Corofin... Quote
Beastmode panda Posted March 12, 2013 Posted March 12, 2013 He already posted it!!..., great idea there Corofin... No, he didn't. Corofin posted a picture, not the OP. Quote
Neo Gold Posted March 12, 2013 Posted March 12, 2013 No, he didn't. Corofin posted a picture, not the OP. No worries! ....great idea though, flutter or dump. Mine was bypassed, until tonight...just altered it back to std & i'll check it out next time i drive it. Quote
StuDoc 72 Posted March 13, 2013 Posted March 13, 2013 It won't work if you have bypassed the boost solenoid (glanza) .. The low feature will no longer work.Same for if you have taken out the stock efi pipe and have a front mounted filterYou can still use it with a front mounted filter. All it does is alters the vaccum on the actuator pretty much like an ebc. It will work as long as you have the factory actuator fitted with 2 nipples on it rather than 1 you get on an adjustable one. Quote
wikiz Posted March 14, 2013 Posted March 14, 2013 I run standard boost on my GT and you notice low boost, when you run in high all the time switching to low is pants. can also be used as a cut off for a blow off valve.. dump or flutter This is awesome I wonder how it would work on the GT i.e where the hoses go etc. Im going to have to try this. Quote
