well as we all know starbos are 1.3
but suzuki, honda cbr etc bikes are 800/ 1000cc plus,
well my thinking is could we use a stock bike oil cooler for everyday use on a gt/glanza as mocal etc oil coolers are designed for more track day use rather than daily
just a thought ????
something simular to this it was taken from a suzuki GSXR 750
KGrHqFqMFGBW3-LMBRjP0gg60_12_zps8d691b86
Edited by russ78
a dont see y not tbh mate, same principle aint it
thats what im thinking just on a smaller scale so would suite a smaller engined car
you shouldn't run a oil cooler on the road without a temperature valve on it. [sorry dont know the technical name] reason being if you constantly cool the oil it'll run too cold and your oil wont get to its correct running temp. can actually cause more damage than good.
just a quick question, why do you actually want to run one if its not for track use?
I will be running a fully forged TD05 16G at about 1.5bar 300BHP+ in the next couple of weeks so just platying it safe really buddy 8)
nice build :) but i still would recommend getting a temperature sensed cooler. even more reason to worry about running it cold if you are running that power.
Should work fine. Here is something to think about. guys over on TGTT, are running 4a-fe oil coolers.
As long as you run a thermostat so the oil gets to the correct temp before it goes in the cooler I don't see why not. Does tge lines have to be a certain siza?
I would personally run a temp sensor first and see what it gets too. If the oil temp doesn't get to 115 degree's it would be a waste really, and I doubt you'll ever get to that kinda figure unless you were tracking the car where the throttle is constantly on and off. Feathering the throttle round town and a quick blip here and there will not cause you any trouble.
You can buy oil cooler or transmission coolers in lots of sizes so just get a small one ie 10row and definitely get a thermostat, inline stats seem to be better though, with a thermostatic sandwich plate my oil still takes ages to heat up and needs provoking to run at a proper temperature. I've not even got the cooler connected now.
