yea it sounds like a mounts failed and the metal outer ring that the rubber would sit in is hitting straight to the metal of the bolt its mounted through/on
or
you have polybushed engine mounts,my car vibrates like mad at certain revs and i love it !! lol
Believe its pretty common for Starlets to do this when they have hardcore engine mounts. Not too sure if worn mounts would cause this aswell?
I have noticed on mine when I put my lights on and stereo this happens at night when my car is using more voltage so I upgraded my battery and terminal clamps using a high amp battery it's stopped shaking on idle and as a whole. Starts and runs better too.
Might be the same issue as the standard batteries with the microscopic terminals are completely pants!
Edited by Ep'd
