PaulStarletSR Posted July 22, 2013 Posted July 22, 2013 (edited) just sorted the inlet manis missin bolt, fired her up and shes still huntin! any ideas as i cant see anywhere were there cud b a vac leak! help!lolhttps://www.youtube.com/watch?feature=player_detailpage&v=p-92XPWucfE Edited August 4, 2013 by PaulStarletSR Quote
iamlegend Posted July 22, 2013 Posted July 22, 2013 Vac leak would cause it to idle really high thow instead of hunting ? Idle control valve? Quote
Socks Posted July 22, 2013 Posted July 22, 2013 TPS..... Try unpugging it see if it idles smooth... Quote
PaulStarletSR Posted July 22, 2013 Author Posted July 22, 2013 TPS..... Try unpugging it see if it idles smooth... ok mate. will do it 2moz as I've finished messin around with it. if that does cure it then il need to clean the TPS or replace it? Quote
rinseep82 Posted July 23, 2013 Posted July 23, 2013 Sounds like a vac leak to me mate all pipes good no splits or anything ?? Quote
Hawwy Posted July 23, 2013 Posted July 23, 2013 If its tps you will need to set it you can find out how ontgtt theres a guide Quote
PaulStarletSR Posted July 24, 2013 Author Posted July 24, 2013 Whats it idling at ?dun because i need to reset the rev needle as its out before i switch it onIf its tps you will need to set it you can find out how ontgtt theres a guideil b fuckin about with it 2moz so il try that Quote
mech5107 Posted July 24, 2013 Posted July 24, 2013 Before everything try lowering idle from he screw in the throttle body. if it's too high the deceleration cut off is enabled, closing injectors till just above 1000rpm. Quote
PaulStarletSR Posted July 24, 2013 Author Posted July 24, 2013 Before everything try lowering idle from he screw in the throttle body.if it's too high the deceleration cut off is enabled, closing injectors till just above 1000rpm.ok bud, il try that Quote
mikey4410 Posted July 24, 2013 Posted July 24, 2013 i just watched the vid,My sportif did this when i did my conversion recently !!! Its nothing to do with any idle adjustment,do not adjust any of them on the body or main idle on throttle pulley.that is a vac leak i promise you !!! Quote
mech5107 Posted July 24, 2013 Posted July 24, 2013 Mine does this sometimes, it's due to fuel cut. Do you have a wideband on it? Quote
mikey4410 Posted July 24, 2013 Posted July 24, 2013 The issue with my high idle and leak etc was that i looped the two air feeds from the powersteering valve.this was pulling air through itself.this cant be done.instead they have to be blocked as individual lines. Quote
Chris Green Posted July 24, 2013 Posted July 24, 2013 Had this problem last night, checked all of the vac lines etc, no joy. I then adjusted the distributor and that solved the issue. Quote
PaulStarletSR Posted July 30, 2013 Author Posted July 30, 2013 ok so here we are again! I've put in the power steerin vac lines to no avail! i need help from someone or il go mental at this thing! check ALL the other vacs and it seems to me like theyr all ok,no splits etc. only now has the car started to piss me off, im not givin up tho, i never give up, its no in ma nature. the timin seems good and the dizzy has be adjusted so its not that. Gona stick fresh fuel in her soon to help things but im sure its a vac issue. Any ideas?? Quote
iamlegend Posted July 30, 2013 Posted July 30, 2013 like said have you tired icv? its not a vac leak Quote
Amjad Posted July 30, 2013 Posted July 30, 2013 I had a weird ICV once and the idle was all over the place Quote
Socks Posted July 30, 2013 Posted July 30, 2013 Leak would cause a high idle.. but it wouldnt cause the revs to go up and down like that... IMO... If it is a leak tho there is a dead easy way to find it...Take the boost pipe off and put your hand over the throttle body... It will suck. If it cuts out. Its not a leak.... If it doesn't cut out the revs will get lower, you should hear a sucking noise from where the leak is... Quote
Beastmode panda Posted July 30, 2013 Posted July 30, 2013 Have a look at the throttle cable, if it's too tight and it's pulling the butterfly open even a little bit, air will be creeping in to the inlet mani and making the sensors go funny on idle causing it to hunt. Mine does it some times cause my throttle is a bit sticky. Worth a try, just unhook the throttle cable from the pulley or loosen is right off. Quote
TrisK Posted July 30, 2013 Posted July 30, 2013 I had a weird ICV once and the idle was all over the placeWierd that a faulty Idle Control Valve, wold lead to an uncontrolled idle ;) Quote
PaulStarletSR Posted July 30, 2013 Author Posted July 30, 2013 Leak would cause a high idle.. but it wouldnt cause the revs to go up and down like that... IMO... If it is a leak tho there is a dead easy way to find it... Take the boost pipe off and put your hand over the throttle body... It will suck. If it cuts out. Its not a leak.... If it doesn't cut out the revs will get lower, you should hear a sucking noise from where the leak is... DEFO VAC LEAK SOCKS! covered the throttle body mate and i can hear roughly were the air leak is.im determined to find this but start work soon so dont have long Quote
PaulStarletSR Posted July 30, 2013 Author Posted July 30, 2013 still got it. I've triple checked now, blocked off the throttle body.......still hear air leak somewhere bhind the inlet. pissin me right off now, gave up for today, off to work shortly Quote
