close to giving up!! engine knocking like a bitch!!
  On 10/14/2013 at 6:09 PM, EPnick22 said:
cheers everyone, when i have some time when Im not at work ill rip the engine out and do a full rebuild, (hoping it is just big end shells) when i did my first oil change the magnetic sump plug was pretty furry with specs of metal, maybe the big ends got scored up from bits of metal?
That'll be the piston rings mate bedding in, try sticking a larger magnet in the bottom of the sump, speaker/sub magnet will do the trick :thumbsup:
Edited by AdamB
  On 10/14/2013 at 9:30 PM, mikey4410 said:
loving the speaker magnet trick.such a great bit of advice !!
:thumbsup: I find that the magnetic sump plugs are too small of a surface area to collect everything, dropping the sump and cleaning the magnet after a few hundred miles is also a wise idea :)
  On 10/16/2013 at 2:28 PM, daniel_g said:
Cant see anyone doing it anyway.
The sumps are steel.
Thought they were alloy, my bad. I'll be doing it anyway, may seem excessive but would rather overkill than have piston rings floating round my oil and damaging seals etc.
Besides you get magnets in the gearbox but don't see people complaining about that :p
Edited by AdamB
  • 2 years later...
