cheers everyone, when i have some time when Im not at work ill rip the engine out and do a full rebuild, (hoping it is just big end shells) when i did my first oil change the magnetic sump plug was pretty furry with specs of metal, maybe the big ends got scored up from bits of metal?
That'll be the piston rings mate bedding in, try sticking a larger magnet in the bottom of the sump, speaker/sub magnet will do the trick :thumbsup:
Edited by AdamB
my mate who builds engines privately for a few people reckons that shouldnt ever happen? once its stripped Im gunna send the block off or find somewhere local to have it properly flushed out
lol what a load of shit. Of course your going to get metal particles its due to friction. Your mate obviously runs his engines in on synthetic oil!
loving the speaker magnet trick.such a great bit of advice !!
:thumbsup: I find that the magnetic sump plugs are too small of a surface area to collect everything, dropping the sump and cleaning the magnet after a few hundred miles is also a wise idea :)
I wouldnt trust having a speaker magnet in my sump incase it dislodged some how and hit the crank. Slim chance i know but thats how starlet ownership luck runs lol
snap lol couldn't agree more..
A magnet won't go on the outside as Aluminium isn't magnetic it would have to go inside, get it welded if your that bothered :)
Cant see anyone doing it anyway.
The sumps are steel.
I would definatley go for a bigger magnet in the sump and would insure its fitted secureley but each to their own.
Thought they were alloy, my bad. I'll be doing it anyway, may seem excessive but would rather overkill than have piston rings floating round my oil and damaging seals etc.
Besides you get magnets in the gearbox but don't see people complaining about that :p
Edited by AdamB
  • 2 years later...
