mikey4410 Posted April 7, 2014 Author Posted April 7, 2014 also had a fresh MOT on the third of this month and it flew through with no issues at all. just shows the high levels of maintenance that go into this car !!!!!! next plans are to change the standard td04 actuator for an hks actuator with a bit more strength.then it will need modifying to fit obviously Quote
mikey4410 Posted April 9, 2014 Author Posted April 9, 2014 (edited) UPDATE...... fitted a ct9 hks actuator that i got from kieran liggins for £20 delivered and its in superb condition.took a few little tweeks and a new hole and here we go... i have fitted this to adjust boost via just the actuator as i feel its the best way,its definatley not the easyiest way to do it because everytime it need loading up to up the boost pressure i need to get under the front of the car and remove the "e" clip and then screw in the arm half a turn each time. maywell take a few days of driving to work etc to get it right but once its done its done then. i have removed the gizzmo boost controller as its fucking wack. kept going over what i set it to with gain only on setting 4.luckily i had always kept a close eye on it and it never went to far past 0.75 bar. my advice is dont by a gizzmo,there shite,spent months trying to get it to work to no avail Edited April 9, 2014 by mikey4410 Quote
mikey4410 Posted April 10, 2014 Author Posted April 10, 2014 they my friend are original vw g60 wheels. Quote
mikey4410 Posted April 10, 2014 Author Posted April 10, 2014 u sound dissapointed lol.they arent banded or anything like that there stock 6.5 inch wide 15"s Quote
Starlet Wayne Posted April 10, 2014 Posted April 10, 2014 (edited) Straight fit.?? Would they be hard to get hold of. Also what sort of price Edited April 10, 2014 by Starlet Wayne Quote
mikey4410 Posted April 10, 2014 Author Posted April 10, 2014 yeap they are a straight fit with no issues.they are very rare and usually around 150 without tyres. Quote
Starlet Wayne Posted April 10, 2014 Posted April 10, 2014 (edited) Also were bouts are you from.in the next few months I've converting a N/A Edited April 10, 2014 by Starlet Wayne Quote
mikey4410 Posted April 10, 2014 Author Posted April 10, 2014 in southend essex.and that sounds awesome dude.converting n/a is fun and different. were bouts u based mate ? Quote
Starlet Wayne Posted April 10, 2014 Posted April 10, 2014 (edited) Your not to far away then. I'm in Ashford Kent. Yes I bet it is. Already had a GT turbo. And Glanza. GT Was 250bhp forged with ct20 hybrid. And Glanza was 190bhp. Spent to much money. But now I want to convert a N/A. Is it hard or not ? I have a rough idea how to do it. What stuff do you need. Just checking make sure I got everything lol Edited April 10, 2014 by Starlet Wayne Quote
mikey4410 Posted April 10, 2014 Author Posted April 10, 2014 its not to bad of a job.just time consuming when doing it thoroughly. I bought a donor car and chucked all that in mine. Quote
littlegreenmonster Posted April 10, 2014 Posted April 10, 2014 ha I live just outside Maidstone and my cousins live in Ashford also Mikey im going to fire you over a pm buddy Quote
mikey4410 Posted April 10, 2014 Author Posted April 10, 2014 right somebody pm me as I feel left out.lol Quote
Starlet Wayne Posted April 10, 2014 Posted April 10, 2014 Oh don't know lol right somebody pm me as I feel left out.lolHahaha Quote
mikey4410 Posted April 14, 2014 Author Posted April 14, 2014 update...... continued to upgrade ignition system after an intermittent misfire issue appeared randomly.not only issues around 2000 rpm but fully cutting out on occasions which is no good. i had a look at the coil pack and found this Quote
mikey4410 Posted April 14, 2014 Author Posted April 14, 2014 ordered up a new coil pack and leads by the company "blueprint".i got trade price and it was £100 for the both. i also cleaned up all the mating surfaces to the main coil meatl and the chassis it sits on. will report back and we will have to see if this fixes my issues. Quote
AlancEP82 Posted April 14, 2014 Posted April 14, 2014 did a new one cure the problem,must off got a bang dropping the engine in or out Quote
AlancEP82 Posted April 14, 2014 Posted April 14, 2014 didn't scroll the whole way down only seen the next part there lol Quote
mikey4410 Posted April 14, 2014 Author Posted April 14, 2014 lol ,eh yeah i mean the car feels alot better and i am hoping thats it now. as for it taking a knock i remember seeing a tiny lil crack last june on the side of it when i did an engine conversion / swap. i defo didnt knock it at all as i took so much care when putting in the turbo engine. its very rusty all around the whole coil so i am guessing the constant hot and cold around engine bay has caused moisture to build up inside it and has gradually split it open. even the little chassis the ignitor and coil sit on was rusty and corroded,took me a good few hours to fit up new coil to chassis as all bolts were seized up bad and i cleaned the chassis up. well worth doing and as i said hopefully its all good now,does pull and rev up noticably better Quote
mikey4410 Posted April 19, 2014 Author Posted April 19, 2014 heres a couple of my pics of the illusive stub axles on my camber adjustable rear.never took any pictures of them and yesterday was tarting rear beam up and took couple of snaps Quote
