My ct9 setup is on its last legs engines standard
Mines ecu (preferably somthing that can be fueled by this)
And need somthing reliable as it's a daily and not too expensive
Anyone who has any reccomendations
Please fire away
Thanks Sam
Can pick up decent TD04 setups for about about 500-600 quid, i ran my old GT with a Mines and it fuelled it nicely.
Personally wouldnt bother with a CT9 setup.
Another vote for td04, though you wont know if the Mines will be safe on the td04 until you try it.
Phil
That seems to be your answer for everything lol.
Piston ring failure = fix it, then TD04
Flat battery = new battery, then TD04
lol
An inconclusive TD04 it is then just need to find a decent second hand kit then(anyone)
What will be needed to make sure the mines ecu is running the setup properly ?
You'll need to keep an eye on air/fuel ratio, but keep in mind that a TD04 at 1 bar will be flowing more air than a CT9 at 1 bar.
lol
NA 5efhe build? kick it, then td04.
thats just the way things get done :)
got move a few things round first, but you goota be aiming for some power for sure :)
yup and AFR and some det cans will tell you what the mines is getting up to, but wont allow you to change anything.
and then well, if its behaving badly you can flog it for 500quid to the next mug :)
Phil
Edited by Philm
A wideband is a must ^^
What boost do you want to run at ?[/quote
I'm not planning on going over a bar as I only have standard internals ATM so to start with probably only .8
See how it behaves then maybe up to a bar mate
Just don't no if I should just get tod of the mines and change ecu aswel but I'm on a pretty tite budget
You have it now, might as well give it a shot see what it does.
just remember wideband AND det cans, those mines are keen on timing advance.
Phil
A Mines will fuel a TD04 @ 0.8 bar, its always advisable to get the fueling checked on a dyno or buy a wideband and keep an eye on fueling yourself.
P&Ps are ok imo but you could sell it for 500ish and get an EMB + mapping for around the same.
