Toyota is the only place :)
Will defo pay for it from them rip off merchants haha is it not like 1k for 2 shafts? Extortionate!
Edited by kavan-k
I think i only need the Synchros.. 2nd is a wee bit poorly and 3rd needs doing its fine when warmed up! But wanna do all the synchros anyway
I did see someone say they got a full set from Idrees
cheers guys.. Anyone got an idea of how much of a job it is to replace them?
Worked in a garage for many years but we don't touch gearboxes..
I guess its only nuts and bolts and washers and cogs and seals and bearings and oil in this case haha
Providing you lay everything out the way it comes out the box you should have no problems :)
I'll make sure i have a big table haha
I'll drive it after and it'll probably go... 1st.. 2nd.. 5th.. 3rd.. Reverse.. 4th lol
Edited by Scott-EP
Was there not a guy who had a guide on here? Or was it tgtt? I woildnt tackle it, I would pull it all apart, see every part infront of me and boke. Haha
Theres an aweful lot more to it than fitting the lsd.
You will need gear pullers and a hydraulic press to get the gears off and on. Loads of fiddley parts to go missing. If you do it logically and make note of what goes where it will be fine. Try taking pictures to remind yourself how bits go.
This is the 1st to 4th assembly. The selector arms come out easily enough and the gear sets come out but to remove the gears you need a gear splitter and a puller.
972C8DFF-70F9-4B1E-972D-9B5449B00C01-132
You then have 5th gear that has to be removed before you can even get to this. When can be hard work on it's own. The selector hubs alone consist of about 6 or 7 parts that need to be put together correctly or it won't click into gear properly either lol
Edited by morgey
I do gearboxs occasionally and they can be a bit of a cunt.
If you provide all the parts youre looking about 300 max id say on labour for somewhere decent to do it.
  • 3 years later...
Correct me the right synchro numbers, got mixed part numbers right now..
Synchro ring 1 - 33368‑12082
Synchro ring 2 - 33367‑12101
Synchro ring 3 - 33369‑12030
OR
33367-12070 Synchro gear 1
33367-12101 Synchro gear 2
33368-12060 Synchro gear 3
33368-12082 Synchro gear 4
33369-12030 Synchro gear 5
Only matching number is for the gear 2, but which one is for the gear 1 for example?
Edited by Tomson
