Skimmy237 Posted March 11, 2014 Posted March 11, 2014 How do I tell if this is a standard or jam ecu ?? Craig that had the car before me said it's a jam But I thought they had stickers on them ?Is there a way of checking the cereal number or something Quote
_shaun_ Posted March 11, 2014 Posted March 11, 2014 it should have the sticker on it there serial numbers wont help. the seals on the side are a good sign its aftermarket Quote
Jim* Posted March 11, 2014 Posted March 11, 2014 open it up and you will see the daughterboard? Quote
Skimmy237 Posted March 11, 2014 Author Posted March 11, 2014 The seals are intact so that's a good sign but how do I know it's jam ? Craig said it is but I don't wanna sell it to someone if it's not open it up and you will see the daughterboard?Good one. Quote
Jim* Posted March 11, 2014 Posted March 11, 2014 The seals are intact so that's a good sign but how do I know it's jam ? Craig said it is but I don't wanna sell it to someone if it's notGood one.?? Quote
Jim* Posted March 11, 2014 Posted March 11, 2014 http://www.ukstarletowners.com/topic/77641-is-this-a-pp-ecu/ see comments Quote
_shaun_ Posted March 11, 2014 Posted March 11, 2014 some of these ecus have a uv chip on them so if there opened it wipes the map on them, so by opening you run the risk of breaking it. short of it having a jam sticker theres noway to tell if its a jam ecu Quote
TurboTobz Posted March 11, 2014 Posted March 11, 2014 some of these ecus have a uv chip on them so if there opened it wipes the map on them, so by opening you run the risk of breaking it. short of it having a jam sticker theres noway to tell if its a jam ecu^ this. Quote
daniel_g Posted March 11, 2014 Posted March 11, 2014 Dont open the seals, some of these ECUs have UV light sensitive chips that get wiped by light.Also nobody in their right mind would buy an ECU with broken seals.If it does all the things a P&P does, raise RPM limit, remove speed cut, raise/remove fuel cut etc. Then its gotta be a P&P no matter if its got stickers or not. Quote
Skimmy237 Posted March 11, 2014 Author Posted March 11, 2014 Yea I wouldn't open it don't worry, but surely there must be another way of checking it's a jam or not ? You said the seals at the side are a good sign ? Quote
_shaun_ Posted March 11, 2014 Posted March 11, 2014 there a good sign of it being a play and play ecu but again not jam as jam seals said jam on them, Quote
Skimmy237 Posted March 11, 2014 Author Posted March 11, 2014 Does anyone know what kind this is then ? Quote
_shaun_ Posted March 11, 2014 Posted March 11, 2014 have you looked at the otherside to see if theres markings on it Quote
Aamir Posted March 11, 2014 Posted March 11, 2014 Why not contact Craig and ask him what it really is? Quote
_shaun_ Posted March 11, 2014 Posted March 11, 2014 looking at it again i think that it might actualy just been the sticky residue of the tamper prove seals that is left. a close up off the seal going over the join aswell to see if it is a seal or just the remains of one. Quote
mikey4410 Posted March 11, 2014 Posted March 11, 2014 oh dear.well let us all know of any updates dude Quote
Skimmy237 Posted March 11, 2014 Author Posted March 11, 2014 It doesn't hit fuel cut and it has upped the revs and all that other stuff ? It's like Chinese symbols over the seals and there's no stickers on the back Also Craig said it's a jam Quote
JDMfreak Posted March 11, 2014 Posted March 11, 2014 these are called shop special ecu's the go by othe names aswell there built and modded by little tuning shops in japan there basically cheaper than jam/blitz/sard analyse and other brands from the outside they look identical to a stock ecu and some have seals and some have small stickers on them so be wary when you spot them with odd stickers there not stock ecu'sinside of a stock 4efte ep91 ecuinside of a modded ecu as you can see the extra board that's been fittedwhat your ecu might be as the sticker seals look similar size on either side Quote
Glanza-Ben Posted March 11, 2014 Posted March 11, 2014 (edited) As said on Facebook my bets are it's a later jam one Edited March 11, 2014 by Glanza-Ben Quote
Skimmy237 Posted March 11, 2014 Author Posted March 11, 2014 Yea Ben mine looks identical to that one Quote
Gainzy Posted March 11, 2014 Posted March 11, 2014 Looks like Jam to me from the seals, how much value deduction would that make the ecu on market? I had to have a sticker made up for mine so when I come to sell it, I don't expect the £500 mark... Quote
lukEp Posted March 11, 2014 Posted March 11, 2014 It's a JAM ecu I opened it up when Craig had it he asked me to open my JAM ECU up and compared the chips and they looked identical. ;) Quote
