Lukee Posted May 14, 2014 Share Posted May 14, 2014 (edited) Right guys i have decided i want to go a sleeper route and not glanza rep my n/a. basiclly ive been thinking, well i dont have LOTS of money and i cant see my car once behind the wheel anyway so i may aswell FEEL BOOOOOSSSCHHT. I dont want any 'it will not be reliable' etc etc but could people please help me with my list for the parts i will need.THE WAY I WANT TO DO IT IS REQUIRING THE LEAST AMOUNT OF PARTS/MONEY. i only want STANDARD low boost on a ct9 setup. nothing OTT.I appreciate all your input and i know you boys have far better knowledge then me!THE LIST:CT9 Turbo ManifoldGlanza SumpCT9 TurboSome sort of management? (PIGGYBACK!)Sump + matching pickupOil filter housing + oil lines4efte injectorsdownpipe and exhaust (current one won't match up)Front mount (don't use a top mount for a 4efe-t build. Heat= More chance of det)Optional is thermostat housing because you don't HAVE to run water lines.IF YOU HAVE ANY OF THE PARTS ON MY LIST FOR SALE, LET ME KNOW! Edited May 14, 2014 by Lukee Quote Link to post Share on other sites
dangeestarlet Posted May 14, 2014 Share Posted May 14, 2014 Glanza thermostat housing Some sort of managementPossible glanza injectors Quote Link to post Share on other sites
Ollieh17 Posted May 14, 2014 Share Posted May 14, 2014 Ive got a good turbo Quote Link to post Share on other sites
Lukee Posted May 14, 2014 Author Share Posted May 14, 2014 Glanza thermostat housingSome sort of managementPossible glanza injectorsthankyou buddy, ive seen builds where they ran stock ecu , not sure how? im guessing wastegate wouldnt cut it right? and ollie how much buddy Quote Link to post Share on other sites
Ollieh17 Posted May 14, 2014 Share Posted May 14, 2014 £70 posted Quote Link to post Share on other sites
richardc9052 Posted May 14, 2014 Share Posted May 14, 2014 Yes use the 4efe ecu and get a piggyback.Sump + matching pickupOil filter housing + oil lines4efte injectors Mani, turbo, downpipe and exhaust (your current one won't match up)Front mount (don't use a top mount for a 4efe-t build. Heat= More chance of det)Optional is thermostat housing because you don't HAVE to run water lines.I'd also recommend a td04 on the same low boost you planned.. Again because of intake temps. You can then run slightly richer to get charge temps back down. Quote Link to post Share on other sites
Lukee Posted May 14, 2014 Author Share Posted May 14, 2014 Yes use the 4efe ecu and get a piggyback.Sump + matching pickupOil filter housing + oil lines4efte injectorsMani, turbo, downpipe and exhaust (your current one won't match up)Front mount (don't use a top mount for a 4efe-t build. Heat= More chance of det)Optional is thermostat housing because you don't HAVE to run water lines.I'd also recommend a td04 on the same low boost you planned.. Again because of intake temps. You can then run slightly richer to get charge temps back down.Thanks mate very appreciated some good advice coming in ! Quote Link to post Share on other sites
richardc9052 Posted May 14, 2014 Share Posted May 14, 2014 Tbh it will be more expensive than a 4efte conversion but I prefer the higher compression for off boost driving.. Also means the td04 would spool a lot faster than on a 4efte Quote Link to post Share on other sites
Gainzy Posted May 14, 2014 Share Posted May 14, 2014 I have a turbo mani actuator set up in for sale section £100 delivered Quote Link to post Share on other sites
Lukee Posted May 15, 2014 Author Share Posted May 15, 2014 Tbh it will be more expensive than a 4efte conversion but I prefer the higher compression for off boost driving.. Also means the td04 would spool a lot faster than on a 4efte most running 4efte's go got around £650 , that doesnt even include the turbo setup, i belive i could do it for less then that as im basiclly just buying the turbo setup. also i dont have the room for a conversion mate . Quote Link to post Share on other sites
5e colin Posted May 15, 2014 Share Posted May 15, 2014 i ran ct9 setup on a gen1 gi block for ages never failed was 11/12psi Quote Link to post Share on other sites
richardc9052 Posted May 15, 2014 Share Posted May 15, 2014 Luke you will need a piggyback.. 2-300 + mapping if your not doing it your self... Piggyback-250 + fitting Turbo kit - (ct9-150, td04-350)Oil pickup and sump-504efte injectors-30Fmic-100Exhaust- 100Mapping-(200-400 depending)Full 4efte engine, loom and ecu, 500Ct9 kit 150 Exhaust 100 Quote Link to post Share on other sites
Jamie5414 Posted May 15, 2014 Share Posted May 15, 2014 What about clutch? Quote Link to post Share on other sites
Fozzie Posted May 15, 2014 Share Posted May 15, 2014 Surely you don't need a piggyback for a low boost conversion? Can't you just get a standard FTE ECU and splice the extra wires into the N/A loom? Quote Link to post Share on other sites
daniel_g Posted May 15, 2014 Share Posted May 15, 2014 This is the never ending topic haha. Theres many ways to do the conversion and not everyone is gonna agree on how its done. Quote Link to post Share on other sites
richardc9052 Posted May 15, 2014 Share Posted May 15, 2014 What about clutch?I forgot about clutch and flywheel Quote Link to post Share on other sites
richardc9052 Posted May 15, 2014 Share Posted May 15, 2014 Surely you don't need a piggyback for a low boost conversion? Can't you just get a standard FTE ECU and splice the extra wires into the N/A loom?Well you could mess about doing that but then you still need the rest of the connectors so you may aswell get the whole loom..I'm doing it atm, 4efe-t with piggyback Quote Link to post Share on other sites
Fozzie Posted May 15, 2014 Share Posted May 15, 2014 Well you could mess about doing that but then you still need the rest of the connectors so you may aswell get the whole loom..I'm doing it atm, 4efe-t with piggyback Yea using the whole loom would make sense, my thinking was just that it's worth faffing about with the n/a loom etc to save having to lay out £500 for a piggyback that isn't strictly necessary, if you're trying to work to the tightest budget possible that is. I don't doubt that the piggyback would run the best setup and future proof it though. Quote Link to post Share on other sites
Jamie5414 Posted May 15, 2014 Share Posted May 15, 2014 £500? They can be had for £150 Quote Link to post Share on other sites
Fozzie Posted May 15, 2014 Share Posted May 15, 2014 Oh yea for the unit, I was factoring in the cost of fitting/mapping too Quote Link to post Share on other sites
Lukee Posted May 18, 2014 Author Share Posted May 18, 2014 im getting my friends ct9 setup as he is going td04, going to get a sump & try run it 0.5 bar with a 0.4 wastegate spring if all goes well, only one way to find out... BOOOOST! Quote Link to post Share on other sites
richardc9052 Posted May 18, 2014 Share Posted May 18, 2014 If you do it without changing loom and ecu or adding a piggyback the only way you can do it it by running turbo injectors, rrfpr, fully retard the timing on the dizzy and unplug the lambda. It will run well but will be a pig on juice.. Quote Link to post Share on other sites
morgey Posted May 19, 2014 Share Posted May 19, 2014 Didn't that quimbey dude have a mate That modded the map sensor to run a turbo on a stock 4efe ecu. Could do it for like 50 or something daft.Sure I'm not imagining it? :s Quote Link to post Share on other sites
richardc9052 Posted May 19, 2014 Share Posted May 19, 2014 Yeah that's the same principal as an fcd and affects the timing Quote Link to post Share on other sites
Lukee Posted May 19, 2014 Author Share Posted May 19, 2014 all will be figured out guys hehe if worst comes to worst i will get a piggyback:) Quote Link to post Share on other sites
