Duduglanza Posted June 23, 2014 Posted June 23, 2014 Anyone knows whats the gap for a ngk iridium heat 7 BKR7EIX? And what gap should i do them for 20psi T4 turbo. thanks Quote
Duduglanza Posted June 23, 2014 Author Posted June 23, 2014 is that the gap i should do or the original gap on the plug? Quote
maddox710 Posted June 23, 2014 Posted June 23, 2014 is that the gap i should do or the original gap on the plug?I think they are 0.6mm out the box Quote
richardc9052 Posted June 23, 2014 Posted June 23, 2014 The largest gap you can go without it being blown out on boost.. Quote
akyakapotter Posted June 23, 2014 Posted June 23, 2014 Never gapped a plug always taken it out put it in and off you go never had a problem Quote
Duduglanza Posted June 23, 2014 Author Posted June 23, 2014 http://www.ngk.com/product.aspx?zpid=9352 Quote
Eynonz Posted June 23, 2014 Posted June 23, 2014 Same I just put my Iridiums in the way they came out of the box. Any noticeable benefit of having a wider gap? Quote
Duduglanza Posted June 24, 2014 Author Posted June 24, 2014 I was reading on a ep91 manual that 4efte must have .6mm gapped plugs.. (on a stantard engine). Most of the iridiums plugs have .8mm. Quote
gorganl2000 Posted June 24, 2014 Posted June 24, 2014 at higher boost levels sometimes 0.5mm has been used to avoid spark blowoutyou can try moving from 1.1mm to 0.5mm closing in 0.1mm increments until there is no spark blow out Quote
AdamB Posted June 28, 2014 Posted June 28, 2014 Same I just put my Iridiums in the way they came out of the box. Any noticeable benefit of having a wider gap? Stronger spark, better fuel economy, longer lasting. Quote
gorganl2000 Posted June 29, 2014 Posted June 29, 2014 (edited) i'll also add, i used to buy expensive iridium and platinum plugsnowadays i buy the cheaper ngk copper plugs of the appropriate grade, i've not noticed any drop in performance or economy Edited June 29, 2014 by gorganl2000 Quote
AdamB Posted July 1, 2014 Posted July 1, 2014 Just to add to this, I had a spare set of NGK Iridium's sat in my toolbox and I gapped them today and preset out of the box they were gapped to 0.7mm which is way too tight. Quote
DevonGT Posted July 2, 2014 Posted July 2, 2014 i'll also add, i used to buy expensive iridium and platinum plugs nowadays i buy the cheaper ngk copper plugs of the appropriate grade, i've not noticed any drop in performance or economy Same here. Quote
