  • Replies 463
  • Created
  • Last Reply
Top Posters In This Topic
How much of the wheel studs did you have to cut off? Im getting the same spacers and was hoping it would clear.
Not too much mate, but they wont clear without cutting them down unless you have recesses in the back of your alloys
Little bit of progress today.
Fitted the manifold, turbo, and oil lines.
Posted Image
Then removed some pipes relating to the air con which I no longer have and decided to mount my FPR in its place.
Posted Image
Posted Image
Need to order some studs for the turbo and then I can mount my downpipe and connect that all up to the exhaust.
Good work bud.
Be careful with the FPR there..theres a fuck off spark coming out of the thing next to it and if you have a small leak or the king lead arks/cracks a clip etc it could get messy!!!
Good work bud.
I was thinking that myself! Maybe I'll move it to a safer location then!
  • 3 weeks later...
Little bit of progress today, picked up yet another bumper just because it was the correct colour and had already been trimmed to fit a large intercooler.
As my intercooler now has a rear entry it required new mounting points so me and my mate set about making some new brackets.
Posted Image
All mounted up nicely, just need to cut a small section away so the rear entry pipe work will fit and connected onto the turbo.
Posted Image
Then we got the bumper mounted up. Love it!
Posted Image
Unfortunately it's a different shade of white so i will get it resprayed at some point or maybe get the hole car done depending on the cost.
Few bits left to do and then I'll start her up and run her in. Not rushing though!
Nice one mate, fair play for carrying on and sticking with it. Bumper looks better too, personally the best front end for these cars by far!
  • 2 weeks later...
Lower ball joints replace, and driveshafts back in!
Posted Image
Just a few little things left to do! Not rushing it as the weathers awful anyway but should be back on the road soon :)
  • 4 weeks later...
Couple of updates
Firstly shes back on all 4
Posted Image
Had problems connecting up my rear entry intercooler onto the turbo, so had to modify it and have my local fabricator weld it for me!
Sorted with a couple of 45 bends :)
Before
Posted Image
During
Posted Image
Mocked up
Posted Image
And welded
Posted Image
Posted Image
Will get that back all together this weekend :)
  • 2 weeks later...
Managed to get some time to spend on the car over the weekend! Finished wiring and plugging in everything to/from the engine and filled her up with fluids! To my surprise there was 0 leaks! Cranked her over and got oil pressure :) but soon after my battery died! So I've stuck that on charge, and will hopefully have her running next weekend!
I have ordered a few bits which should arrive early next week so I'll update when they arrive :)
First of the few updates came today!
Posted Image
Innovate oil pressure and temp gauge! Thought it was worth while investing in one of these! I've also ordered a sandwich plate so will fit and wire up everything this weekend :)
Posted Image
Oil sandwich adapter turned up today. Hoping to start the engine on Saturday so once I've let it warm up and drop the oil I'll get this fitted :)
Posted Image
