Hi guys getting an oil change soon and was wondering whats the best oil and filter to use?
Cheers guys, Bret.
Edited by BJShipley
That would be the one best to pop into local motor factors and pick oil filter up. oil im not sure on people use titan race pro but I've never put expensive stuff in as it's changed so often. I use acdelco get it from my local motor factors very fairly priced. :)
I always thought it was 10w40 Semi-synthetic as that's what i've been putting in my car. But If I'm doing an oil change is 5w40 fully synthetic the better choice? And Mobil/Castrol Magnetic are the two best choices? :)
Bret.
I've always used 10w40 in mine. Slightly thicker when cold but who kicks their cars head in when cold any way? Most oil filter brands are the same inside. Mann, blueprint, bosch they all do the same job.
yes 5w/40w is alot better for a car when cold as its offers better protection.
its not anything to do with not ragging a cold car, its general cold start protection.
Never had any problems with the 10w40 :) I've been putting in Comma Eurolite Semi-synthetic motor oil cost £27 for 5 liters. What oil brand would you recommend I'd rather put some decent stuff in than crap :')
Bret.
i uses the cheapest possible oil i can get hold of ( 10/40) and filter why spend so much extra when it has to come out after 3,100 miles anyways
This is spot on I will be using the same oil I always have even in the forged lump as it's changed so often :)
You say that but the experts seem to disagree. Regardless of how often you change your oil, it's always going to be better to run a higher quality oil for long periods of time, rather than a lower grade oil for any time at all. But by lower grade I'm talking Morrisons own oil or Car Lube or something similar.
For some of you, like Colin, a rebuild might just be one of those things and is second nature. But I'd prefer not to rebuild the engine at this stage. I've been using Magnetec but I think I'm going to bung that on, use Silkolene like I do on my bikes.
But from what I hear, 6 or 1 they're all the same.
Think that's a good bet ^ 5w40 you use mate or the 10w50?
"5W40 - Competition Fully Synthetic Triple Ester Nano Technology formulation. Suitable for fast road/street modified engines, race, rally, sprints and hill climbs. Ideal for engines with hydraulic tappets e.g. Ford Zetec.
10W50 - For race and rally engines, and especially suited to modified, high performance vehicles with or without turbochargers, for fast road/street modified engines and track day use. A performance alternative where the manufacturer specifies a 10w40."
Looks like decent stuff with proven results! £52.03 on Demon Tweeks atm too :)
Bret.
Edited by BJShipley
Millers nano drive oil and Toyota filter
This is what i use.
If i remember correctly Synthetic oils have a better film strength than non synthetics and cling to surfaces better as well so your cold starting is much safer.
Millers again for me.
Go for the best oil you can afford is my advice. Some people like above don't like spending £50-£60+ on oil that ends up drained after a small amount of useage, however oil manufacturers spend millions, probably billions of £££ in R&D to give your engine less friction, more power, better lubrication, better fuel economy, better cooling properties blah blah the list goes on and on.
Mobil, Castrol Edge, Fuchs, Millers in that order :)
