Yesterday I had my tracking done to hopefully sort out why my car pulls to the left and right. Tracking is all good but still pulls, sometimes to the left, sometimes to the right. Hopefully someone can help
just generally pulls or when your giving it some beans or braking? have you polybushed anything? since i polybushed everything on the car it likes to follow white lines and small holes and what not bit of a pain but good on smooth roads.
Say am at traffic lights and i pull away, it can violently pull to left or right, but if am doing going the speed limits then sometimes it pulls all over the place and i bet people who are behind me must think am drunk lol... When I ent lol
i had it all checked on monday and sais it was just the tracking out alittle, got it back and i could tell the differents but still pulls. never had this problem before
Today I had my tracking check and was spot on, had bushes and track rod ends checked ( all seem fine ), had wheel bearings checked ( all is good ). But still pulling left or right. Am thinking something to do with brakes sticking on and that's makeing it go all over the place steering
  • 4 weeks later...
Am having the same issue with mine at high speeds it's away to a specialist to be set up so interested to see what he says is the problem
What are the engine/ gear box mounts like? because they can cause this problem too! Especially when giving it some boot.
This is my next port of call.
I've got the same problem as you, steering yanks left or right. Either from a standing start or a heavy boot of the right foot even in 4th or 5th at motorway speeds.
Im changing all my steering parts, pòly bushing everything thats not, alignment done, poly engine mounts. Then if its still doing it the cars getting scrapped lol
I've pulled all the joints off the hubs ready to replace them and so far theyve all been tight but im doing them regardless. The inner tie bars are even still tight and hold themselfs up if moved. All it really leaves is rack, column then its mounts and diff.
I've enquired about some polyurethane so just waiting for a price
when you have fixed the problem let me know what it is so i can sort mine out :thumbsup:
mine pulls violently sine i put the 5e and manual steering in. tryed a 2nd rack as the first must of been bent, and its horrible/ unsafe to drive.
it knocks hard on lock when pulling out of junctions and snatches the steering, torque steers right on acceleration, and dives for the hedge on the left when lifting off. only thing im thinking on is the diff (trd lsd) is on its last legs
whats the caster settings of the wheels?
my pas wheel has 0deg and my drivers side has 1deg positive, so while the drivers wheel tries to self-centre the pas wheel stays upright and straight, pulling it to the left pretty strongly when i let go of the wheel (which doesnt happen often obviously) but its very noticeable.
Edited by Ryan_EP82 GT
