glentwenty Posted June 11, 2015 Author Posted June 11, 2015 get engineers hydrolic hose in that size it will work but aint pritty its bendable so no need for silicone couplers tru every corner you will only need 1 coupler to the tb !!! Thanks colin! Will have a look round Quote
morgey Posted June 11, 2015 Posted June 11, 2015 The biggest issue i can see there is making a solid bracket to mount the charger to the engine with for obvious reasons it cant be mounted to the chassis.Id be more inclinded to move the overflow bottle and flip it 180 degrees and mount it above the PS pump as making solid brackets will be much much easier as it wont be as far from the block, shorter mounting = sturdier mounting. Quote
glentwenty Posted June 11, 2015 Author Posted June 11, 2015 The biggest issue i can see there is making a solid bracket to mount the charger to the engine with for obvious reasons it cant be mounted to the chassis.Id be more inclinded to move the overflow bottle and flip it 180 degrees and mount it above the PS pump as making solid brackets will be much much easier as it wont be as far from the block, shorter mounting = sturdier mounting.The overflow bottle in that photo isn't actually connected so it won't be like that usually! But that's a very good idea! Thanks morgey Quote
aleximport25 Posted June 12, 2015 Posted June 12, 2015 i suppose you could make a bracket off the front of the head where the hook for lifting the engine should be Quote
Ep82gi Posted June 12, 2015 Posted June 12, 2015 (edited) Just a suggestion guys i have looked at this before n always thought the best plan of action would be remove the air con (who needs it we have windows) use the air con pump pully and belt as there already there. Mount the turbo to the old a/c bracket relocate filter in the grill to avoid water intake. Then run an intercoler. Thoughts would be grate I'm just throwing an Idear in there on my brake so I haven't totally thought it threw so don't judge hahahaGood luck xEdit -:- damn auto correct. Edited June 12, 2015 by Ep82gi Quote
haggis Posted June 12, 2015 Posted June 12, 2015 There's a point.. you will need an intercooler broski or by by engine Quote
Bussey Posted June 12, 2015 Posted June 12, 2015 There's a point.. you will need an intercooler broski or by by engineWhy? Turbo won't be getting hot will it? Especially not if the superchargers only making like what....less that 0.5 bar? Quote
ROTABOOST Posted June 12, 2015 Posted June 12, 2015 Doesn't matter, it's not the exhaust that makes a turbo require an intercooler, it's the fact that any time you compress air you generate heat Quote
Bussey Posted June 12, 2015 Posted June 12, 2015 Doesn't matter, it's not the exhaust that makes a turbo require an intercooler, it's the fact that any time you compress air you generate heatYeah but surely not at the mega low boost this will be making? Quote
AdamB Posted June 12, 2015 Posted June 12, 2015 Not all superchargers need intercooling, although with that said the only ones I know of that don't need it are the Jackson Racing chargers, what is essentially something along the lines of a Rotrex here it will need cooling due to high rpm. Quote
morgey Posted June 12, 2015 Posted June 12, 2015 The corolla tsport compressors and vw g-ladder didnt have coolers. And the toyotas are running on a stock 11.5-1 comp engine. The lotus exige S is running higher boost than that but not sure if they're I/cooled or not Quote
glentwenty Posted June 13, 2015 Author Posted June 13, 2015 I was thinking about that, I am going to wait to see if this actually makes any power, I'm not to keen to go slapping a few hundred at a fmic and it doesn't actually need it haha I have thought about removing air con and fitting to where that pulley was actually,i may end up going that route we will see Quote
glentwenty Posted June 13, 2015 Author Posted June 13, 2015 Is it possible to just disconnect all the aircon stuff and leave it all in the car? and just use the pulley in the mean time so that if this project ends up being scrapped its all just threre to hook back up again? Quote
AdamB Posted June 13, 2015 Posted June 13, 2015 (edited) Yeah you'll obviously need to re-gas it though lol. That's where I would mount it would be off the air con pulley. Edited June 13, 2015 by AdamB Quote
glentwenty Posted June 13, 2015 Author Posted June 13, 2015 Yeah you'll obviously need to re-gas it though lol. That's where I would mount it would be off the air con pulley. The only thing is the aircon pulley is apart of one belt between the P/S and the crank. But i would need another belt running off the aircon to the shaft of the turbine. But if you remove the belt from the crank and P/S then the aircon wont spin Quote
haggis Posted June 13, 2015 Posted June 13, 2015 Those cars will have been designed without the need for intercooler. A stock starlet with will Def heat up more if you slap a turbo on it ( hence why glanza has intercooler standard) and even that gets pretty hot hence why most people change it out. no offence but this project seems to be more of a gamble every day. your plan is to get boost out a DIY supercharger so why go assumptions like " it will probably only make little if any boost so won't need a,b,c & d. Not hating Bro just think if your going to do something do it right the first time Quote
glentwenty Posted June 13, 2015 Author Posted June 13, 2015 Those cars will have been designed without the need for intercooler. A stock starlet with will Def heat up more if you slap a turbo on it ( hence why glanza has intercooler standard) and even that gets pretty hot hence why most people change it out. no offence but this project seems to be more of a gamble every day. your plan is to get boost out a DIY supercharger so why go assumptions like " it will probably only make little if any boost so won't need a,b,c & d. Not hating Bro just think if your going to do something do it right the first time This whole thing is an experiment so im going to experiment while its here, We don't know what its going to do or what its going to need, Im doing this so other people know either yes it can be done or no might as well just do it how everyone else does it. I'm just doing something different If it turns out yes it actually makes boost and gets hot. Then its not the end of the world to just take the belt off till we get a intercooler or whatever I'm experimenting so everyone knows what is required and what isnt Quote
5e colin Posted June 14, 2015 Posted June 14, 2015 might be a tip ?? ( that is if there is ) can an electric moter be used or aint there any that do 100k ??? probly not in 12v ha ha if there was install would be soooo easy Quote
morgey Posted June 14, 2015 Posted June 14, 2015 They have them in f1 for boost building between gear i think. Quote
haggis Posted June 14, 2015 Posted June 14, 2015 Can buy them on ebay haha mini superchargers that run off battery. They did a test on mighty car mods and a leaf blower attached to induction gave you more power Quote
Bussey Posted June 14, 2015 Posted June 14, 2015 Or last resort, and I know there mega mega mega laggy but still.... Run a ct9? Quote
glentwenty Posted June 15, 2015 Author Posted June 15, 2015 might be a tip ?? ( that is if there is ) can an electric moter be used or aint there any that do 100k ??? probly not in 12v ha ha if there was install would be soooo easy We looked at that Colin as that is what me and my brother were going to do with his turbo to start with but there aren't any strong enough at 12v to spin that fast all the electric turbos that make power that people sell for just as much as a standard turbo setup use 3 battery's haha Quote
FrozenJakalope Posted June 15, 2015 Posted June 15, 2015 What's the current like on those? It'd be a bit of a convoluted way of doing things but if you ran battery power through a chopper to switch to AC, then through a step up transformer with a 3:1 ratio you could triple the voltage by cutting the current by 2/3. Quote
Ethanep82 Posted June 15, 2015 Posted June 15, 2015 Or last resort, and I know there mega mega mega laggy but still....Run a ct9? 3.bar.geeza. Quote
