Flaminsam Posted February 8, 2016 Posted February 8, 2016 Hey guys and girls. So I am changing a few seals on the gt and the dizzy seems to be leaking in the thermostat housing. So me being my inquisitive self I stripped another dizzy to see what's actually going on in there. I found this....... The bearing is semi sealed, open to the rear. This isn't the problem though as I've found these online. The problem is the seal. The number on the seal reads kcr 175. It measures roughly 20mm OD x 10mm ID x 5mm deep. I'm struggling to find a seal to prevent the dizzy leaking again. The rubber in the seal has gone brittle and hard causing a lack of seal. Any ideas where to get a seal? Quote
morgey Posted February 8, 2016 Posted February 8, 2016 The bearings should come with the seal i would have thought, be doing very well to get a seal separate as toyota like using obscure size bearing so local bearing places cant supply them. Quote
Bean Posted February 8, 2016 Posted February 8, 2016 I've stripped a gt4 dizzy down and replaced the bearing and seal my local industrial bearing place had them in Stock. Quote
Starlet__SR Posted February 8, 2016 Posted February 8, 2016 Just buy a new bearing with the code 6000 2RS. The 2RS denotes 2 rubber shields. Or you can buy them with metal shields. No point putting a new seal on an old bearing. http://www.chainreactioncycles.com/brand-x-sealed-bearing-6000-2rs-bearing/rp-prod119269 Day Quote
Ollieh17 Posted February 8, 2016 Posted February 8, 2016 From looking at the replacement and not hearing anything about this before i dont think this is your issue. That seals sounds like its just there to protect the bearing. Quote
Flaminsam Posted February 8, 2016 Author Posted February 8, 2016 Cheers for the replys people. Just to clarify, the seal is smaller than the sealed bearing. It sits behind the bearing and the bearing is open to the rear. I.e the sealed bearing is only sealed on one side and the "cage" is open towards the smaller seal. If you remove the dizzy from the head you will see two tapered openings on the top of the dizzy. I'm guessing this is to guide oil into the housing to lubericate the shaft. Problem is there's no where for the oil to drain back out of this housing and back to the sump. The easiest way for the oil to go is pool up behind the seal and leak out from the bearing side. So my theory is to drill a small drain hole in the bottom of the housing to allow oil to still lubericate the shaft but instead of pooling it can slowly drain back into the head/sump. I've already replaced the rocket cover seal and the external dizzy 'o' ring. This is the only seal I can see leaking 😕 Quote
morgey Posted February 8, 2016 Posted February 8, 2016 The cam caps can also leak, i had to put some on my 4age caps, bolt them down and then the stuff that splurges out is there to seal the corner of the rocker cover gasket. Quote
Ollieh17 Posted February 8, 2016 Posted February 8, 2016 Have you changed the rubber seal on the shaft? Quote
Bean Posted February 8, 2016 Posted February 8, 2016 the gt4 dizzys are very similar to the starlets and they are known to leak from this internal seal also it could well be the problem. Quote
Flaminsam Posted February 9, 2016 Author Posted February 9, 2016 Last night I cleaned off the suspected area with brake cleaner and found that the cam caps were sealed. (Little half moon piece) also the rocker cover gasket seemed sealed. After 20 mins of running I couldn't find a leak. So turned off and kept watching. I found oil started dripping slowly from the drain hole in the bottom of the dizzy. Found it! Bean, do you have a part number for that seal for the gt4? Also any sizes that you may have wrote down somewhere would be a help 👍🏻Ollie, I think now that the seal that's internal has gone hard/brittle causing the leak. Hopefully I will be able to find a decent replacement and solve another one of the problems with the sieve u have for an engine 😂 Quote
Ollieh17 Posted February 9, 2016 Posted February 9, 2016 Glad you found it, suprised nothing has come up with this before. Shame i gave up on the 4efte seive and have a slightly less sieve like car and engine Quote
fiddlersport Posted May 31, 2016 Posted May 31, 2016 >https://www.youtube.com/watch?v=tKEBvq_u9Dc Quote
RabNo1 Posted June 8, 2016 Posted June 8, 2016 (edited) Check out these, any of them do the trick?http://simplybearings.co.uk/shop/advanced_search_result.php?search_in_description=0&sort=2a&search_3fields=1&keywords1=10&keywords2=20&keywords3=5&osCsid=d942a89320c90fad97a614d277b1648eI always buy "generic" seals and bearings, usually from my local bearings place but I've ordered a few times from simply bearings and theve been spot on.I've paid £3.80 for a bearing KTM wanted £45 for and it was the EXACT same bearing make,etc.. Just didn't come in a KTM pack.If you want to replace the bearing with the single seal just buy a bearing the right size with 2 seals and carefully pry one of the seals out with a tiny screwdriver or something, the rubber seals come out pretty easy,obviously be carefully not to damage the bearing. Edited June 8, 2016 by RabNo1 Quote
5e colin Posted August 7, 2016 Posted August 7, 2016 any updates on this as y dizzy is causing me misfires from oil Quote
fiddlersport Posted August 7, 2016 Posted August 7, 2016 I have split my dizzy apart as i too was suffering this issue (oil leaking from centre of dizzy) £16 delivered for the seal will update photo and details where to buy from once it arrives Quote
Mike84 Posted November 14, 2016 Posted November 14, 2016 Any more news on this ? As I also need to replace mine 😯 Quote
TD04GT Posted November 15, 2016 Posted November 15, 2016 I have split my dizzy apart as i too was suffering this issue (oil leaking from centre of dizzy) £16 delivered for the seal will update photo and details where to buy from once it arrivesHave you a part number for the seal as mine is leaking out the dizzy now too Quote
fiddlersport Posted November 16, 2016 Posted November 16, 2016 Rotary shaft seal...about £14 Just phone up your local bearing suppliersYou have to put all the parts back in same place with same clearances or it wont work Quote
parker85 Posted November 19, 2016 Posted November 19, 2016 mine done the same handy job fitting it too and sorted it Quote
5e colin Posted November 19, 2016 Posted November 19, 2016 Common link to the fucking seal my local supplier is not in Ireland Quote
fiddlersport Posted November 19, 2016 Posted November 19, 2016 http://simplybearings.co.uk/shop/index.php?cPath=19_4462 Quote
