Content Count
8788 -
Store
Calendar
first thing i would try would be to double check the slack in the shock to hub bolts. See if that makes any improvement you may be surprised how much of a difference that makes. once youve tried that let us know what the results are.
just wanted to see if the cambers and out how far and see if there was any toe out on one side. could be something like the top mount is out 180 degrees, that with the shock to hub bolts could maybe put it that far out. just thinking of various things to check. try swapping the wheels over and see if its still the same or if the problem switches side. (offset is different on both wheels)
Can you get a picture from in front of the car?
Either camber is miles out on one side or you have different offset or width wheels
I'll give this a try later cheers! Fingers crossed
Is 200 or altezza?
yeah pretty much was. just uninstalled it, cleaned the system and reinstalled it. still no luck! looking more and more like ill have to reinstall the O/S! maybe ill just buy a new one haha
paahh not again! Not that it should make a difference but this is a laptop. could it happen because it re-installed itself from its internal memory and somehow doesn't have the files it needs? i don't have a windows disc like i used to have to use on my PC? cheers for the help.
I've tried that, it would seem they're not downloading then, it hasn't worked since downloading it, never managed to open it.
Ok so earlier this year and ever since its had a couple of little issues. the main one being i get this error message when attempting to open certain programs, i.e windows movie maker. ordinal 459 could not be located in the dynamic link library urlmon.dll I've tried googing a solution which I've tried doing, it involved running some commands which I've done. a. Quit all programs that are running. b. Click Start, and then click Run. c. Type regsvr32 urlmon.dll, and then click OK. d. When you receive the "DllRegisterServer in urlmon.dll succeede
RobMacs Forged/Sleeved B18 'Going Turbo' Glanza V
morgey replied to Glanza Mac's topic in EP91 Glanza Progress Blogs
Think he said the weight was going to be similar/same so that would put 4age out the equation. 2zzge or b series Honda engine maybe as they are alloy blocks?! Will be cool either way- 983 replies
- engine conversion
- carbon goodies
- (and 3 more)
41 Days to Japfest!, what you got to do?
morgey replied to Starlet-Joshy's topic in Lifestyle General
Rear wheel bearings Clean and underseal arches Remove, clean and grease coil overs. Fit and bleed brakes Get speedlines sandblasted and painted Buy and Fit tyres. MOT Clean and polish Probably a few extra bits as well lol -
Yeah it will. But that's the main cause of it lol
AE111 Twinpod calipers, discs, pads & brake lines
morgey replied to Toyoloog's topic in Starlet Parts For Sale
Damn. I should really get around to selling mine! Glwts dude great upgrade over stock brakes -
It's a common problem on old corolla gti's people resting on the gearstick when cruising in 5th
Took me a while to spot that haha. V Rear looks loads better
It's not the synchro it's the 5th gear selector arm that's bent. Can still be got at from the end cap on the gearbox and is probably less work than the 5th gear itself
Is it just on the net or the whole O/S? The net you can full screen by pressing f9 I think.
Nope none of that's needed Only other thing that you may have an issue with is there was a different hub and brake setup on a few n/A's if you very are unlucky and have them then you would need to change your front hubs. But 99% of the time you have the normal ones so that won't be an issue
I just searched pipe end caps
http://pages.ebay.com/link/?nav=item.view&id=190892513049
Naa you will need handbrake cables And a set of turbo flexi lines for the rear. May as well get a full braided set
My mate uses this. Great for pod he can adjust things like l/c easily between easy run. Plus monitoring etc. Well worth it
C160's ain't light. I've got one here and it weights more than my early c52 and early c56. The boxes are the same near enough, 1st to 4th are the same thickness gears just different ratios it's only 5th and 6th that are slightly narrower. The 5th (and 6th gear) end casing is bigger on the 160 to accommodate for the extra gear. But as there's more to it they weigh more. The later six speeds on the 2zz engines seem to be stronger c60 and c62 I believe.
