8788 -
I was driving mine around for 2.5 months including a big meet near london with no mot unaware. Got stopped and I got a £60 fine, I even got to drive my car home. I did have the excuse of 'I have a second car if I'd have know I wouldn't be driving it' Also just been driving around for the last 3 weeks with no MOT completely unaware again! But I live in the sticks so not many old bill around my way
So it needs an exhaust, New bumpers and stripping out or new plastics. That's like £100 and you got a cheap little run about.
Cheers. Still a bit more to come out of her with the EMB when I get it fitted and mapped Thanks and yeah should think so. Drop me a Pm when you're after a set and ill run through the options of what he can do
Damn you! I need to get in with a company like yours. Got so much I need to learn to get upto your level! Last I heard I would be getting some cnc training so I can convert component drawings to various insert parts and electrodes but that's all very slow in a small place like mine! Should make some Turbo trumpets or something.
Injection and blow moulding I believe. But if it's demo stuff for machining purposes it will just be cnc machined parts on mills/lathes. I assume as injection tools cost loads to plan design and produce. Beat me to it lol. And your machine is huge compared to our lil cnc's at my work!
hasn't come through bud, ill drop you one now.
hopefully sorted the brake situation once and for all now. feel like a bit of a tit for not knowing/realizing but it turns out the rubbers react and degrade with normal greases (petroleum based products) google to the rescue, Silicone or synthetic grease was the answer! so now i know whats going on it was straight forward! Turn bedroom in to a micro workshop again! Replace slider boots with new ones, as the old ones had absorbed the old grease and now would always bind. luckily i had a spare rebuild kit laying around. then its just a case of cleaning all the old grease out, applying some new silicone based stuff, winding the caliper back in, new pads and as there was a set up for sale new discs. If any ones had the same issues get some of this stuff! in the mean time, had my front shocks off to clean, plastic arch liner out and replaced, cleaned, wire brushed and waxoyled areas that needed it. Will be doing the rears when im refiting the rear brakes when the discs and pads turn up.
The problem you will have is the inner cv joints. My UK spec starlet shafts rattled around inside my corolla gti box. And they were both C series boxes.
Yeah any 2L non gt four celica should do for the gearbox. Ishaq has put a 3sge in his ae101 corolla and that used to be a 4efte before hand so might be able to shed some light but the person you really want to speak to is Dan3sgte. He did the conversion in an ep82. He's over on tgtt but not sure how active he is these days
Not seen any build threads but there is a couple of them out there. Or at least 3sgte ones. Gearbox would have to be that of a celica (S series I believe). Unless you were to get a conversion plate made up to suit a C series box. The Mr2 box might have the selectors on the wrong side of the box.
Anythings better than steelies lol. Just browse eBay and gumtree. Maybe a couple of Facebook pages that sell stuff local to you. Typically 15" 4x100 with an offset between of et 30-40 and 6 or 6.5" wide will fit problem free
Not text talk but 2 I like are. Dilligaf and fubar
Item For Sale: Cusco LSD, Item Condition & Description: Used originally in a ae111 levin/trueno. im 99% sure this will fit starlets as I've read of people using oem Levin Lsd's This is A very good diff but very aggressive. knocks and clunks at low speeds but is fantastic for track or spirited driving. not sure on the milage on it, I've probably put about 1000 miles on it and im not man enough to handle the harshness of this diff lol Only suitable for turbo boxes with 8 bolt diffs, Will not include ring gear! Price: £360 Posted Pictures: Payment & Shipping Details: paypal or bank transfer. will be shipped tracked next day delivery. contact Paul on 07990708955 or PM on here.
Loop the lines. Fit electric pump. Replace with an non p.s rack (may or may not need column)
Afaik got me for a while. I usually Google text talk that I don't understand lol
Where is this?
Too much fast and furious lol
Ahh yeah that'll be the one. Good choice on wheels by the way
Ep82 interior plastics are different and won't fit ep91 The rear bench is a straight swap and the fronts will need a small bit of modifying to the feet to fit. Run a search for a guide of what needs doing to fit ep82 seats in an ep91
Is this an originally an Sr? Used to have gold ultralite wheels?
The panels are just spot welded in. You could have a go at replacing them yourself? If it's not cost you a lot what have you got to loose? One of the breakers about to scrap a shell should be willing to cut out the panels you need then you just have to work them i'm place and blob some weld in. (Maybe not that simple but that's the jist of it)
Cheers dude. It still makes me grin every time I squeeze the loud pedal Carbon Bonnets going today unfortunately, Probably some other bits as well. All helps fund the starlet so can't be a bad thing! Currently trying to find somewhere cheap to sandblast my speedlines so I can get them all painted up ready for show season
Has anyone upgraded their Meister-R coil springs?
morgey replied to Amjad's topic in Chassis & Suspension
Have you got thicker Arb's? I'd do them as it would mean you can warrant a softer spring. And I love my BC's no issue on road or track. I've never run mine at full stiffness other than when a mate pissed about with them at Jae, then I hated it as I had a hangover lol -
BC's run 6kg front and 4kg rear I believe. I wouldn't want any harder on the rear as there's not much weight over the back.
