  1. Mitsi cyborg windscreens Are £1200, my mate went though a stint of breaking 3 within the same amount of months, they then limited him to 1 a year
  2. So some random person had work done on a car and some random video crew has filmed bens car to use in a tv program? Even though its nothing to do with his actual car?
  3. Check out www.extraefi.com Not much they cant do. Even have an android app so you can bring up any gauge for monitoring on you phone, as well as tweeking maps and All other settings from it. The software is easy to use and theres heaps of how2's on the above websites forum
  4. They are ellectric folding mate
  5. Thank you and indeed it is. If my corolla bonnets any comparison then its easily half the weight when lifted, even though its fully skinned with a fiberglass frame
  6. Non folding are just colour coded uk mirrors, only came on poverty spec models of both 96 and 98 spec cars
  7. Cusco lsds clunk like mad! This is mine >http://youtu.be/LD7ycptXi0o
  8. different mirrors, white dials. im sure i read there were rumors they also had different cams as 98's seemed to make better power on TD's dyno?
  9. just roll down in the rolla if not dude, JAE isnt just about the cars
  10. yeah im aware, i will bare it in mind mate cheers
  11. looking for one a bit cheaper if possible mate. theyre about £10 on ebay. if i have to ill pop to a scrappy and borrow one
  12. these are the OEM recaro's
  13. after one of these and a few inches of wiring if possible, think only uk cars have them as imports dont need rear fogs. ideally posted for as little as possible, let me know what you got cheers
  14. rumours have it Type R's have thinner glass than normal models. whether its true or not isn't know and most people joke about it lol
  15. the pattern is but they have wider seats, these are really tight in comparison. the G6 has the same seats as my other corolla with the SR interior but the pattern again is different on the SR interior lol cheers, well happy with it! yeah really nice, i would consider swapping them to the OEM SR3 recaro's if a set were to pop up though ;)
  16. theres a small amount of movement where the shocks bolt to the hubs, if the hubs haven't been lifted when the bolts were tightened when they were fitted then the camber can be all over the shop. hence the different readings even when the top mounts are in the same position
  17. other than being set for mad camber, thats fine.
  18. *cough* twin charged *cough*
  19. indeed it does, proper comfy too these ones i assume you mean?
  20. coolant system full?
  21. So happy with it, drives beautifully, so tight and precise, the box is solid, seating position is great, engine is nice and quiet, more so than the starlets 4age. cant wait to get it insured properly, get the fuelling checked out and start enjoying it properly as for pictures, unfortunately i lost my phone again! so photos are currently Gopro ones so aren't the best. but ill get a few more up in a few mins!
  22. honda b18c4's use a similar system to the acis system anyway. what you are on about its possible but it would be a complete redesign of the head, cams, camgears, timing belt setup. due the the system needing a pair of rocker arms the cams or valves will no longer be directly cam driven. both toyotas 2zzge vvtLi and mitsibushis Mivec system uses the 4 big and 4 small lobes system. the 2zzge also have vvti which makes it identical to I-vtec. e-vtec is basically vtec in reverse, you have 12 valves in use 90% of the time then when you boot it it locks in the final 4 valves, but there is no differences in cam profiles on these engines. ie no agressive cam lobe. then easiest and least work to make a system like this would be impliment fiats multi air system. controllable oil filled tappets. you put in a really agressive cam but only half fill the tappet making it run like a normal cam at low revs, when up in the higher rpms you open a oil valve allowing the tappets to fill completely to make use of the agressive cam and continue to make power at higher rpms
  23. i remember this without the kit but with a HUGE sun strip. this was the car that made me want a black SR
