  1. Its british law to have indicators visable from the side of the car whereas in japan it isnt, hence they dont need them. But some glanzas will have them fitted when they are imported. Chances are they are glanza wings mate ;)
  2. I think rob_h had a pic on his build thread of his one stripped down
  3. Glad to hear, did read they sat close but daaayyyyuumm!! Haha
  4. Pressure washing ;)
  5. Hahaha mexican jimmy savile ftw!!
  6. Thats the point though, keep updating your original post with pics thoughout the month so everyone can see it progress An whos morgan spurlock? :s
  7. Feeling like a fool taking photos if myself and also by Making a slow start But this is last years Mo, did cheat as had a bet i couldnt go 4 months without shaving but i was let off to do Movember. But here i am today fresh start no cheating or rule breaking.... Here i am 22 hours growth... Or lack of Day 5/6 Still feeling like a tw*t taking pictures of myself lol 12 days in! 19 days in
  8. morgey
    Movember 2012
    Ok ill probably do it tonight as im at work atm
  9. morgey
    Movember 2012
    Im all shaven reregistered my old account and have got a few of my mates involved this year aswel. I did think about starting a Movember progress thread were we each have single post and keep adding new pictures as the month goes on?
  10. Very impressive figures and what you guys have achieved id be extremely proud of yourselves for pushing the ep world forward!! Now all you gotta do is take me out in one of these animals
  11. Personally Black car. Black - white - gun metal/anthracite - gold - bronze or a smokey silver Im going anthracite on my car soon
  12. Test fitted one this evening, going to have to remove the heat/dust shield as they sit incredibly close to the hub, not sure if the custom work i did to the hub meant it sits closer than normal but they seem central in the caliper so guessing its just how they are! eitherway here it is only hand tight at the moment, but will be fitting them properly friday
  13. Id tell them what it says on every can of spray paint you buy... Test on and inconspicuous area first? They're "professionals" if they knew the car had been resprayed then they should know that the colour match could be off so they should have checked/tested it first. The only thing i would pay for is the new mix of paint out of a good will gesture!
  14. Yeah i can see that, thats why you need to get it back to the original level ideally. Best place to jack it is on the sump, but put a bit of wood between the jack and the sump to spread the load and avoid damaging it.
  15. Still hard too tell whats happened, im guessing the mount has pulled off of the block. The lower bolt looks asif its damaged near the end which might mean its worked loose and hopefully the other bolts may have aswel. Id start by jackng the engine up the the original level, remove the upper timing belt cover and see if you can see where the mount should bolt too the block. Im guessing theres 3 bolts normally so see if thera any damage to the block around where the mount should meet it. If its hard to see whats going on get some more pics of underneath the cover for us to see!
  16. I think keri was looking at making a kit for 14" rims maybe drop em a Pm and see what they say
  17. Yeah i did think about doing it properly but its all money and as my wallet took a hit from the brakes im doing it diy stylee for now. If i get the front end resprayed ill have that finished and done at the same time As for the decals this is the bonnet one which is as it is in this pic (the left one is the OEM sticker) Im having the side ones made with the cut out but with a little fill in to stick on the rub strip, but he can make these without the cut out aswel. He should also be able to do different colours aswel!
  18. I've seen them on there all the time, i thought they were something offered with new toyotas and now someones just flogging them as a starlet accessory?
  19. when i first got my corolla, that whined really bad in 5th on overrun, i put some basic wilco's GL5 75w90 oil in it and for 6 months it was much much better, 3 years and 30k later and its still quieter but is getting noisy again. I would imagine a better quality oil would help even more.
  20. haha I've got more than enough of them, any i can find and get rid of i will!
  21. Right since going on track at the end of august i haven't used my car all that much due to cracking a disc and it making a horrible noise from the RARB all the time. i attended JAE, santa pod for jap show and did the miss banzai tunnel run (thinking about it thats about 600 miles of driving :s) but other than than its barely been used, and this is why. not too bad but, probably not advisable to be driving on! So after a bit of deliberation on whether to just replace what i had or upgrade. I decided that rather than suffering the same fate again i would upgrade, and this is what i ended up with. (along with a hole in my wallet) lol WMS 277x25mm kit ferrodo ds2500 fast road pads earls braided lines should be getting fitted this weekend if all goes to plan I've also got myself a 2nd bonnet for a more direct air feed onto my throttles which currently looks like this. its awaiting a coating of chalkboard paint Its not going to be the prettiest thing in the world but its going to be a function over form bonnet and ill still have my original one for when it needs to look good I've also got a friend making up a replica set of SR decals using an original set i purchased i while back. its costing me but since the OEM ones fade really easily i thought id have it done this is a test one, he should have sorted the spacing between the two tear drops now. So when they're finished ill get a good shot of them up and if need be i can have more made up, if people are interested So for this weekend the list is. Paint bonnet Fit WMS 4 pots Regrease RARB Strip paint off of speedlines ready for respray will Update with progress next week or once the brakes are fitted and bedded in. Have a funny feeling im forgetting something else but for now this will do Edit: remember i had an accident on the way down to the MB tunnel run. quite funny really, my friend just had a mugen lip all flushed onto his EP3 and after less than a day its damaged and he was all grumpy and moaning about having no luck. whereas i have a bump with a car on the m11 and i dont even get a scratch mwhahaha (someone slammed there brakes on infront of me after squeezing in infront of me coming upto a junction) anyway that was it i was rubbing it in my mates face all night comments welcome as always
  22. you shouldnt do, I've got a completely different engined ecu in my car and it never had a problem unless i didnt have a key with the original chip in it that came with the car. might be a silly question, not sure if it would even fit, but the ecu you brought isnt for an auto is it?
  23. Ok cheers fella
  24. Sweet! Ill give them a once over when im sorting my brakes this weekend Cheers
  25. Basically since fitting my whiteline RARB I've been getting knocking and creaking noises coming from it. Now I've given it a jolly good yank and it seems solid as, im just wondering if its just that its 2nd hand and the bushes are dry (no i didnt have any grease at the time!) or if they're worn maybe? Or even if I've drilled the drop link holes in the wrong place (no instructions) i mounted them vertically above the rear most part of the bar? Anybody have the same/similar problems? Thanks for any input in advance
