AdamB
    4340
    Everywhere
7238 profile views
AdamB's Achievements
UKSO Elite
UKSO Elite (8/8)
  1. That setup won't make any power beyond 6500rpm.
  2. Usually about 1.7/1.8 bar of boost on a GT30 size turbo will lift the head.
  3. I found the bump & rebound a lot stiffer in BC's, in fact I think they're one of the stiffest I've ever felt. Wasn't a fan.
  4. If compression is good, nothings leaking etc then leave it as it is. Just replace the timing belt, water pump.
  5. Same as the ones here pal http://www.steelconrods.co.uk/product_info.php?cPath=22_46_172&products_id=470 Speak to Abbott, he had Rob put these in his head as far as I know.
  6. I wouldn't know the brand, but the terminals will be all the same (brand) for the parts you're looking for. Make sure you get terminals with the same surface finish as that of the component you're mating to, ie tin plating, silver etc.
  7. Why don't you read what I put properly. The idea is pretty simple, try sucking on a straw which is only 1mm diameter to get a mass flow rate of 20 kg/sec... You can't. Same logic applies to an exhaust valve that's too small and you can't expel X kg of gas.
  8. The E-series cylinder heads were used as the "Eco" range of Toyota engines back in the day, hence why the camshafts are meshed and the valves are small. The exhaust valve is kept small for "internal EGR", whereby you don't get the burnt gas escaping through the valve and therefore burn it again, much like today's EGR except they use a valve and the ECU controls when it opens dependent on driving conditions. EGR is bad on a performance engine as you don't want residue burnt gas left in the cylinder as this takes up room for fresh oxygen! This is no good for those that want to tune the E-series, and I've seen over the years people changing cams and losing 50 ft/lbs in the low-mid range, I don't know if anyones ever driven a Honda, but that's a third of their peak torque and we all know how Honda's lack torque to begin with! The exhaust valve should be as large as you can possibly fit in the E-series head, I worked out it needs to be 2mm oversize to get close to being a decent ratio, intake-exhaust. I don't believe there is even enough meat on the chamber to get 2mm in there, it might just be possible but there would be no flow round the backside of the valve. If you're feeling adventurous you could weld the intake valve to make it smaller. For anyone doing head work, I would recommend the first place to start is at the valves, and only change the exhaust side. I did once design the "ideal" valve for the E-series head, 27mm diameter, 6mm stem, undercut to 5.5mm. I've probably still got the file for it somewhere. For reference, and I spent a long time looking into it before you can use the following parts from Toyota 4AGE 16v - Valve springs - Valve retainers - Stem seals - Valve guides Supertech does aftermarket parts for all of the above. I've said it before and I'll say it again, this engine does not like long duration cams unless it's for drag racing. The best cam for this engine is the stock one. Toyota got this cam pretty bang on the money and I wouldn't see the need to change it. Turbo motors are extremely fussy when it comes to cam specs and 98% of people spec them incorrectly.
  9. I believe you can fit the Supra 7MGTE valves, but the stem needs cut and the collet grooves machined back in place as they are too long to fit the E series head. Supertech do off the shelf valves. Supertech also do Viton stem seals Certain Supertech also do springs Someone does bronze valve guides (can't think of company name) Camshafts:- Speedvision, Ivan Tighe, Tuning Developments are the only ones I know of that are billet. I wouldn't touch regrinds in an E series head due to the meshed camshaft.
  10. If you use the same rings in the same cylinder, you don't need to hone. The ring would have already seated to the cylinder wall.
  11. 1 bar / 14.5 psi is the lowest I'd like to see, any lower and really there's an issue.
  12. Carbone Lorraine RC5 for the weight of a glanza.
  13. That pressure is fine for idle.
  14. Most will be M6x1.0, just take one out and measure the length of what you want to replace. Remember some holes may be blind tapped, others maybe a through hole so length could be important.
  15. Funny thing is, people think the word "forged" refers to a part A OEM piston and a "forged" piston are still made of an aluminum alloy lol. Unfortunately all of it is just marketing, probably gained traction from Need for Speed
