Safest boost to run on ct9b on my setup?
Zisco Tubular Manifold
Zisco Decat
Longlife Exhaust System
Apexi Air Filter
Still only using the standard top mount intercooler & ECU
First You find fuelcut without adding boost, only exhaust mod should do it. New ecu or fcd is anyway next step if adding boost over that.
I'd like to see a side by side comparison to back this up.
Maybe someone who still runs a TMIC would be nice enough to do a back to back test for you.
Your always going to get cooler air from the frontmount although top mounts do aid spool time but will collect a shit load of heat off the mani, people do run them on one bar set ups. More boost is more heat, heat is the enemy!
Topmount up front ;) win win
Love the response I get from a top mount but for a little bit of lag & front mount looks so much better I think I will go down that route some when :)
So if I bump the ct9 to 0.8 to do 4runs down Quarter mile track it will be fine.
That will most likely creep up to 0.85 fuel cut level doing that mate.
Thought that might of been the case ill just leave it then till I get everything sorted
