Mike-530 Posted August 23, 2016 Author Share Posted August 23, 2016 I ran one in my old glanza and never had an issue. Then I fitted one to my corolla t sport. Again no issues after 30k on the corolla and 15k on the glanza. You could always play it safe and go for an Exedy 3 paddle.Will the exedy 3 hold the power at 300?Thanks Quote Link to post Share on other sites
richardc9052 Posted August 23, 2016 Share Posted August 23, 2016 (edited) Haven't you seen the other thread regarding td products Edited August 23, 2016 by richardc9052 Quote Link to post Share on other sites
Starlet__SR Posted August 23, 2016 Share Posted August 23, 2016 Will the exedy 3 hold the power at 300?ThanksMight be pushing it at that. Id personally go ORC. Quote Link to post Share on other sites
H_D Posted August 23, 2016 Share Posted August 23, 2016 fyi clutches are rated by how much torque they can handle not HP Quote Link to post Share on other sites
Mike-530 Posted August 23, 2016 Author Share Posted August 23, 2016 Haven't you seen the other thread regarding td productsNo but i would certainly like to lol. Quote Link to post Share on other sites
Mike-530 Posted August 23, 2016 Author Share Posted August 23, 2016 fyi clutches are rated by how much torque they can handle not HPOk boss, didn't know that tbf. Says the orc is rated to 340nm. Im sure thats more than enough lol. Quote Link to post Share on other sites
akyakapotter Posted August 23, 2016 Share Posted August 23, 2016 and orca are about 220 ftlb torque Quote Link to post Share on other sites
H_D Posted August 23, 2016 Share Posted August 23, 2016 Ok boss, didn't know that tbf. Says the orc is rated to 340nm. Im sure thats more than enough lol. yes it will be more than plenty. its one of those things you just fit and forget about they are really strong and can handle some proper abuse Quote Link to post Share on other sites
Vturbo Posted August 23, 2016 Share Posted August 23, 2016 (edited) bite the bullet and go with the ORC. wont ever buy a spec again,shower of shite. also my mate had a brand new comp clutch in his starlet, kept sticking in gear and felt mega vague and orca are about 220 ftlb torqueim running 250ftlbs and its perfect. Edited August 23, 2016 by Vturbo Quote Link to post Share on other sites
Starlet__SR Posted August 23, 2016 Share Posted August 23, 2016 bite the bullet and go with the ORC. wont ever buy a spec again,shower of shite. also my mate had a brand new comp clutch in his starlet, kept sticking in gear and felt mega vagueim running 250ftlbs and its perfect. Chances are the clutch master/slave cylinder will have been passing, mine did the same till they were both renewed. Quote Link to post Share on other sites
Mike-530 Posted August 23, 2016 Author Share Posted August 23, 2016 yes it will be more than plenty. its one of those things you just fit and forget about they are really strong and can handle some proper abuseHmm. Think im going to have to rustle up some cash then lol. Definitely going to go with the ORC. This the one i need?http://www.rhdjapan.com/orc-309d-single-plate-metal-clutch-kit-ae86.htmlCheers Quote Link to post Share on other sites
H_D Posted August 23, 2016 Share Posted August 23, 2016 This one is the one that rattleshttp://www.rhdjapan.com/orc-309d-single-plate-metal-clutch-kit-ep82-ep91.html This is the silent typehttp://www.rhdjapan.com/orc-309d-silent-single-plate-metal-clutch-kit-ep82-ep91.html Quote Link to post Share on other sites
Vturbo Posted August 23, 2016 Share Posted August 23, 2016 Chances are the clutch master/slave cylinder will have been passing, mine did the same till they were both renewed. we both installed orc clutches without touching master or slave cylinders, not a problem to report Quote Link to post Share on other sites
Starlet__SR Posted August 23, 2016 Share Posted August 23, 2016 we both installed orc clutches without touching master or slave cylinders, not a problem to report Unusual. Quote Link to post Share on other sites
Vturbo Posted August 23, 2016 Share Posted August 23, 2016 Unusual. seems like a common problem with both of the said clutches. more so with the spec. Quote Link to post Share on other sites
Starlet__SR Posted August 23, 2016 Share Posted August 23, 2016 seems like a common problem with both of the said clutches. more so with the spec. I know I had a similar issue but this was due to the added stress of the new cover plate causing the cylinder to pass. Once fitted with new it was spot on, gear changes were as if it was factory. Quote Link to post Share on other sites
Vturbo Posted August 23, 2016 Share Posted August 23, 2016 I know I had a similar issue but this was due to the added stress of the new cover plate causing the cylinder to pass. Once fitted with new it was spot on, gear changes were as if it was factory. ah fair enough. Quote Link to post Share on other sites
Mike-530 Posted August 23, 2016 Author Share Posted August 23, 2016 (edited) This one is the one that rattleshttp://www.rhdjapan.com/orc-309d-single-plate-metal-clutch-kit-ep82-ep91.html This is the silent typehttp://www.rhdjapan.com/orc-309d-silent-single-plate-metal-clutch-kit-ep82-ep91.htmlSweet cheers man. Cheapest delivery is DHL for 85 quid 😳. So looking at a 700 spend! Edited August 23, 2016 by Mike-530 Quote Link to post Share on other sites
_shaun_ Posted August 23, 2016 Share Posted August 23, 2016 Exchange rate can't be great right now am sure I paid around 550 delivered for mine Quote Link to post Share on other sites
Starlet__SR Posted August 23, 2016 Share Posted August 23, 2016 Exchange rate can't be great right now am sure I paid around 550 delivered for mine Its took a serious dive right after Brexit. I was due to buy a Caldina till the seller dropped another grand ontop of the sale price lol. Quote Link to post Share on other sites
richardc9052 Posted August 24, 2016 Share Posted August 24, 2016 Exchange rate is awesome for us in the euro lol.. Quote Link to post Share on other sites
Starlet__SR Posted August 24, 2016 Share Posted August 24, 2016 Exchange rate is awesome for us in the euro lol.. Rub it in why don't you lol Quote Link to post Share on other sites
H_D Posted August 24, 2016 Share Posted August 24, 2016 Sweet cheers man. Cheapest delivery is DHL for 85 quid 😳. So looking at a 700 spend!Remember to add an extra 20% to the total. Quote Link to post Share on other sites
akyakapotter Posted August 24, 2016 Share Posted August 24, 2016 Remember to add an extra 20% to the total.Good old import charges. Lol Quote Link to post Share on other sites
Ollieh17 Posted August 24, 2016 Share Posted August 24, 2016 Euro against yen has dropped too?!? Quote Link to post Share on other sites
