Hi I'm Rob I'm a new Glanza v owner from northern Scotland
Car is going to be used on the weekends and for sprint's currently working in Bulgaria so not much will happen this year or next ( need a house ) but I'll potter away to tidy it up etc
Sorry about the lack of pics no laptop in Bulgaria lol - attached the spec from Matthews advert
- 98 Spec Glanza-V non sunroof in 040 white
- 172,000ish KM - not converted so mileage is accurate.
Stock bottom end, recently inspected by Rob Boston Racing and given a clean bill of health along with cambelt change, sump re-seal, crank seals etc all done recently.
RaceTech EWG TD04 kit with SS manifold, 2.5" de-cat downpipe and VTA screamer. Port matched turbo to manifold.
Turbosmart 38mm V-band external wastegate
Braided oil and water lines
RaceTech 2.5" SS exhaust system (single silencer, 3.5" tip)
FMIC with 2.5" alloy piping
Alloy 1/2 rad + 10" slimline fan
Smoothed & polished rocker cover with AN port conversion for breather
RW Developments breather tank with stainless braid and AN8 aeroquip fittings
Oil cooler kit using mocal sandwich plate, AN10 aeroquip fittings and stainless PTFE lined braided hose to 15 row oil cooler mounted behind I/C
Magnecore blue HT leads with matching king lead
Walboro 255lph pump upgrade
Iridium plugs
Apexi boost solenoid
Gizmo IBC-II boost controller set up with three settings
Greddy EMB
Mapped by Ricky at RaceTech to 0.83bar and 1.10bar and made 227bhp @ 1.10bar. Print out will be included.
OEM LSD C52 box in mint condition with recent shaft seal replacement done using genuine Toyota parts.
Comp Clutch Stage 4 paddle clutch (very low mileage/use)
Fidanza lightened flywheel
Hyper Sport quickshift
Millers transmission oil (not cheap!!)
Re-built CV joints with new boots and clips and fresh moly-lith grease
Poly bushed engine and box mounts
Meister-R Zeta CRD Coilovers with pillowball front top mounts and camber adjustability
Coilovers socks - immaculate underneath these
Whiteline anti-lift kit + poly bushes
Cusco adjustable panhard rod
Whiteline adjustable rear ARB
OEM front strut brace
OEM rear 3 point brace
PAS delete with properly looped rack (best thing I ever did to this car!)
ST185 Celica single pot brake conversion using Mk4 Astra grooved discs, Ferodo DS2500 pads and braided lines
Standard rear brakes freshly serviced
Recent replacement of all wheel bearings
Motul RBF brake fluid
Discs recently skimmed and brakes fully stripped and serviced.
Rota Grid 15"x7j ET35 wheels powdercoated in gloss white
Genuine RAYS anodised red alloy wheel nuts with locking nut
Avon ZZR semi-slick tyres fitted all round with plenty of life left for road or track use (although they're quite noisy on the road, sounds like all four wheel bearings have gone at once!)
Full alignment/geo done by Rob Boston at RBR
Varis FRP front bumper fitted with BYC style chassis mounted splitter legs, marine ply front splitter
Bumper secured using locking aero catches and wing ties
Standard 98 Spec skirts and rear bumper
Very VERY clean car with ZERO rust
2x Corbeau Clubsports (XL) mounted using proper T45 welded-in mounts and side mounts with plenty of adjustability/movement.
Genuine OMP suede dished 330mm wheel with Sparco QR boss
ARC Autosport weld-in half cage with harness bars
Cruise shift knob & extension piece
3x Pro-Sport gauges (oil temp/oil pressure/water temp)
HKS 60mm boost gauge mounted on dash
Fully stripped interior no headlining or rear trims but dash intact and still has door cards, electric windows and electric mirrors that retract.
NO STEREO (although I did keep the wiring in place if you wanted to re-fit one and I do have a stereo I can include with the car, not that you'd be able to hear it)
Still has infrared remote central locking too!
Edited by Bopthebear
  • Replies 74
Nice !
Hopefully see you at some sprints with mine 8)
What's your plans with it , is it pretty standard just now?
Hi mate my plans are to get the interior all painted as it's got the cage in unpainted and going to treat it to alot of carbon from Fiske :)
I'm just going to make it my own as I don't plan punting it eventually forge it will be a long term project, edited the first post with the spec
  • 3 months later...
Well been a while since ive updated this now that im home and collected the car!
Started working on it degreasing every inch of it and it's had a full correction to the paintwork by myself and other detailing buddy just going round the entire car tidying it up
Got the foglights working and wired in the turbo timer have been having difficulty with my oil temp gauge sender and gauge work just not getting any temperature registering
More pics soon cheers
  • 5 months later...
Been a while since I updated this so here we go
Sourced a genuine varis carbon bonnet, genuine varis rear bumper and skirts so bonnet is on
Binned the st185 calipers for 6 pot ksports and the rotas have been tossed off for speedline challenges done in white pearl so has a flake threw it
Rear carbon Cusco brace and Cusco front brace
Pictures can do the talking
Few more updates - Ever since I bought it was leaving big blobs of oil on the drive so my mate stripped it all and so far we have replaced
OEM oil pump - old one was severely worn
Timing belt and tensioners and water pump
Crankshaft seal, Camshaft bung, Rear main seal, distributor o ring seal, rocker cover gasket, basically any seal we've replaced, ORC Ogura is going in it soon with miller's gearbox oil
Also bought a carbon spoiler from Fiske which should look good
And relocated the battery
Well it's finally coming together few little things to sort now and hopefully get it MOT'ed
Made a list of what's been changed or updated
16" speedline challenge refubed in pearl white with Nankang NS2-R 50/50
Engine all seals and oil pickup, oil pump, water pump, top end gaskets replaced including timing belt tensioner kit, plugs gapped and replaced
Oil flushed and gearbox oil flushed replaced with miller's oil, ORC Ogura clutch/flywheel kit to go in
Battery relocation to boot
Ksports installed with yellow stuff pads, braided hoses all round, brake fluid flushed and replaced, rear pads replaced
Coolant flushed and replaced
AEM afr installed and bung welded in to exhaust
Hypersport shifter binned replaced with TRD short shifter and genuine varis gearknob
C pillar brace installed
Cusco brake stopper installed
Modified the defi oil temp sender location no reading now solved
Standard door cards binned, track day door card's installed
Looks tidy! Definitely worth having that number plate panel off to clean the number plate lights and behind!
Seem to be having issues with the indiglo dials I can't get either of the sets to illuminate am I being a donkey or missing something and can you hardwire them or what's up
  • 3 weeks later...
Clutch noise sounds like a proper race car now 😎
You must be better than me at sticking on reflective tape , can I get it to stick :fool:
On 6/22/2019 at 11:04 AM, H_D said:
Brilliant clutch and excellent pedal feel, I have the same clutch on my V
Hopefully I'll get to try it out pretty soon been a very long project that wasn't actually meant to turn into this but once I started I thought well - I'm this far in I may as well just do it all properly and once still not fully happy with the car but it's alot better than it was
What power do the oguras handle does anyone know?
Got a gold intercooler for a really good price on eBay to continue the white and gold theme
On 6/22/2019 at 9:40 AM, Timmah said:
That idles so well, I'm jealous!
It didn't when I first got it, would hunt alot and idle really low, adjusted it slightly and it's alot better now
