mcleod Posted February 23, 2009 Posted February 23, 2009 SPEC AS IT IS NOW.ENGINESection Engine Damper to go on 550cc Injectors NGK Plugs IridiumRoss Forged PistonsPauter RodsCruise Valve SpringsNST Crank PullyACL BearingsFully race balancedEngine workService cylinder headReplace all valve guidesService and replace (as necc) valves,lap and vacuum test.Surface grind head face 0.005"Strip,prepare,wash and rebuild with new stem seals and springsShort motor assemblyRebore to pistons suppliedSurface grind block face by 0.005",polish crankshaft,race balance to crankshaft/flywheel/clutch/connecting rods and pistonsgap piston rings to rrr turbo specificationprepare, wash and rebuildFit front cover and rear oil pump (supplied)Acl main bearings Acl b/e bearingsAcl thrust washers* brand new ihi vf34 turboheat painted wepr td04 mani with external wastegate plumbed back to decat double heat wrapped decatfront mounted greddy oil cooler and relocation kit (to go on)Emanage ultimateturbosmart external wastegate custom meshed front mounted funnelcustom intercooler kit reflective wrapped2x spal slimline fans 1 suck 1 blow Hks ssqv 2Sard cooling plate (for sale soon)Koyo Ali rad (to go on)custom catch canJapspeed stainless exhaust system double wrapped in thermotec copper wrapNgk grade 7 plugsMagnecore 8.5mm leadssard header tank (to go on)sard thermostat Blitz dsbc type r boost controller (just got it back so it needs setting up soon) NICK!!! lolManual boost controller (temporary until ebc is returned)Set to 0.98 barspeedo converter straight cut gearbox and aftermarket diff fidanza lightweight flywheel exedy paddle clutch SUSPENSION AND CHASSISTein flex coilovers3G/Wilwood 280mm big brake kitFull roll cage with carbon crumple barsWhiteline Front anti roll bar 24mmWhiteline Rear anti roll barWhiteline anti lift kitRSR panhard rodUltra racing front 4 point lower arm barUltra racing rear lower arm barZep c pillar barZep 3 point rear strut braceZep cross bars tanbe front strut brace15" Rota jmags wrapped in yokohama parada spec 2spoly bushes in new lower arms trd engine mountsfully aligned and set up to 2 deg neg camber on frontINTERIORRecaro sport seats (out of an evo 7)semi stripped rearLuke 4 point harnessesMomo steering wheel (advance edition)Razo aluminium gearknobTriple A pillar podDouble dash podStack AFR gaugeStack boost gauge in barStack oil pressure gaugeStack oil temp gaugeStack water temp gaugeClarion cd/mp3 player with hard drive4" Kicker componentsKicker kx75 2 channel ampJbl GT 2 channel amp12" KIcker subCustom boot buildHarmon Kardon Ipod connectivity adapterEXTERIORCustom rear bumper to make a euro plate fit and also smoothed the slats in each side for a more unique look.Cut out and smoothed front bumper so no restrictions are in place of the fmic.Also the whole bottom half of the car has been sprayed a newer and more unique grey colour.Jam reverse scoopToms grill (strengthened)Front carbon splitter custom rear diffuser WHAT I PLAN ON DOINGis making the ultimate handling and powered starlet around well i bought my advance in january 07 and ive been through some rough times of wanting to get rid but ive chose to keep her now and ive ordered some 21st bday prezis for myself so here goes.i bought her with gold volk te37s, apexi exhaust, trd shortshift, tein coilovers,rsr panhard rod and hks air filter.The first thing i bought was a hks recirculating dump valve off an evo 6, not ideal but it does the job i'll be replacing that soon. i then started on the handling so i bought a whiteline antilift kit and front and rear arb off toby on the group buy he did. The next thing on the list was brakes after alot of debating i found the 3g and wilwood combination off dave so i got in on that group buy about 4 months later they arrived and what a piece of kit that was.while daves brake group buy was on i came across a blitz access ecu on ebay so i went for it and what a difference that made i was well impressed with it. one day when i was driving to work i bounced over a unavoidable rock and i dented two of my four wheels (wounded) so i purchased a set of 15'' jmags off dave (marmite wheels. lol) BEFOREAFTERAfter that toby started a ultra racing group buy so i put my name down for the 4 point front lower arm and the 2 point rear lower arm bars. just a few pics of my handling parts that are on.wilwood/3g 4 pots off dave burwashwhiteline 24mm front arb, ultra racing 4 point lower arm bar, and whiteline anti lift kittein coilovers, rsr panhard rod and whiteline rear arbWhile i was waiting for these to arrive i decided to sell the ecu as i was going to need a emanage for the setup i was going for so i sold it for what i paid for it so it was worth the wait. Then it was coming closer to my 21st bday so my other half wanted to know what i wanted for my bday and i thought why not get a number plate so i found the one i wanted and went for it only to find one problem, it only looked right in a line and i coudn't pull myself to get it on a square plate, so to skill customs in marple i went and my car underwent the sides being painted grey again, arches rolled and the rear bumper modified.well i got my car back this week ending in 17th/03/08.so thats the score upto now i'll update soon with pics etc. hope its up to scratch and ididn't pass my engilish gcse if you can tell lol.to come guys and gals speedvision hybrid, autobahn fmic, hks ssqv, blitz dual solenoid ebc,and much more. plus i treated myself to a 8megapixel camera so expect alot more pics lol.i went playing football on sunday the 20/4/08 and sprained my ankle lol so ive not been in work for mon and tues and maybe weds but we'l see. But my dremel arrived so ive finished off my front bumper for now but i'll show pics when its on the car.and also i fitted a sard cooling block after some modding lol here it isit has my pressure sensor and temp sensor plumbed in so i only need to wire them and im done.i discovered this in my back box not so long ago lol i mite just go to powerflow sometime soon and get a full system made up.and a few pics of the front mount finally fitted and runningive not put my plate on yet as it fell off so its gonna be above the right fog light as your looking at the pic. and its a short rectangle plate so it looks ok the gearknob is off a rx7 so i retaped the thread to fit the gt's getting mapped by tuning developments tomorrow (today being 30/05/08) so i'll have another update and a proper spec hopefully.Quite an update today.wednesday the17th september i recieved my jam reverse scoop off ramsey so i sent that to the paint shop and i got that back on friday the 19th.and then with all this stripping of cars going on i've been hunting for a bargain. so when i saw ben-j' stripping his track slag i thought it was christmas. so i first started off with just wanting the header tank, catch can, and low temp thermostat. and then i thought why dont i just buy the gearbox and lsd. but seen as only the back half of a cage is 550 from rhdjapan.heres a lil pic of my recaros finally fittedi just thought sack it i'll get the cage instead lol. so im now a cage owner lol. i'll put pics up soon as i only have the back half in as the front interferes with my gauges. anyway i picked all this stuff up today on the 21st september just for record.front of the cage is now in along with my roll podsoh yeah and i only have one piece of the jigsaw to complete the puzzleheres what shes running at too 183.6bhp at 0.98 bar8/11/08a very big order of parts will be going in on the following wedsneday. including the final part to the jigsaw plus the last of my many handling parts.just ordered exedy paddle clutch, braided clutch line, speedo converter, cruise valve springs, fidanza lightweight flywheel, trd bush set no1 and 2 lower arm and trd twist beam bushes, toytuning uprated engine mount set.most of my parts have arrived for now.finally got my hands on a toms grill but i had a bit of bad luck in a uninsured postage.and heres the finished product i'll fit it tomorrow and put some pics up turbo shat itself last night lol 24/12im on the look out for a forged engine, emanage ultimate, and a massive turbo. oh yeah and a big pot of gold would help too who wants to help me choose the turbo???? pm me with decisionsordered some copper exhaust wrap, oil catch can, heat reflective tape and some mocal oil cooler brackets for the future as i intend on getting a 13 row mocal cooler with lines, thermostat,and temp and pressure housings.8/1/09brand new lower arms have arrived just need to figure out how to remove the brand new oem bushes so i can fit my trd ones.10/01/09just picked up my straight cut gearbox with aftermarket lsd in it. from ben-j13/01/09all seems to be falling in place now. might be finished sooner than i think.ive just ordered some more handling additions, and the final piece of my jigsaw . also a forged engine is in nearly reaching ditance.16/01/09ive been on a mass spending spree in the past few daysjapspeed exhaust turned up today so just waiting on some more copper wrap so i can double wrap it.ordered my turbo today too, aswell as a turbosmart wastegate, turbosmart oil cap, ali rad, mani and downpipe. and about 3 things which i can't unveil yet. one of which i'll update you on the 17th. 17/01/09been at gees all day removing his forged engine which is now mine also picked up his engine damper, and 550 injectors too so this is where it starts.19/01/09dropped engine off at tuning developments yesterday and wrapped most of my japspeed exhaust in copper thermotec heat wrap. im just waiting on another roll so i can double wrap it 24/01/09well fitted my exhaust today after it had been double copper wrapped etc27/01/09a lil sneak peek at a future modand also this turned up today tothe quality is excellent4/2/09not much of an update due to waiting on parts etc but an update none the less. just picked these up from rs electroplatingthey even did all the little bolts that held everything together. but they could get the throttle sensor off the throttle body so when i do then i'll take it back and get it sorted.10/02/09just picked this ball bearing mo fo up 16/02/09this turned up today 23/02/09just got the final piece to the zep jigsaw and had to cut my diffuser down because i measured it with my old apexi backbox which is tiny to the japspeed ones and then i fitted itThought i'd give an update well the engines in now as well as practically most things i have bar a few its mapped to 1.3 bar just wants tweaking to 1.4 soon but it is savage im scared even walking past it on my drive but im back in love with it. heres a few picsforged engine finally fitted and all good 07/09/09hey people not updated in a while just got theseand got this a while back at a good pricethe cars goin to tuning developmetns this weekend to fit sard breather tankgreddy oil cooler and relocation kitcams ali radspark plugsfuel filterlonger hub studsand fix a few oil leaksand mapped to 1.5 bar then all i'll be needing is a custom fuel rail and braided linesfse adjustable fprand some tyres for november. dont think i'll be going for semi slicks though as its in november and no doubt it'll be moistprogress at tuning developments HQhad to get some greddy gauges so the sensors fit into the oil cooler kit____________________________________POWER IS NOTHING-WITHOUT NOISE. (FACT) Quote
ste91 Posted February 23, 2009 Posted February 23, 2009 Nice work, love the details, smoothed bumpers look good too. Quote
Liam_D Posted February 23, 2009 Posted February 23, 2009 Awesome work dude!!! Shes a bit of a beast :) Quote
GAZ@A&G_TUNING Posted February 23, 2009 Posted February 23, 2009 loving it mate, should be a animal when done Quote
glanzaturbo Posted February 23, 2009 Posted February 23, 2009 looking amazing mate, love the cage and rear diffuser Quote
Matt Glanza Posted February 23, 2009 Posted February 23, 2009 Awsome project mate.whered u get that rear difuser from its freckin awsome Quote
Idrees Posted February 23, 2009 Posted February 23, 2009 Wicked project dude hats off to you! We need to see more full pics of the car! :) Quote
Pav Posted February 23, 2009 Posted February 23, 2009 Thats an amazing project mate, love the diffuser idea and the length youve gone to in the handling department! A lot of people are just after huge power figures without much regard to chassis mods. You've gone all out there man, nice one. Quote
mcleod Posted February 24, 2009 Author Posted February 24, 2009 cheers lads. and the rear diffuser is a custom job off a company on ebay who make lotus and vx220 ones. Quote
animal GT Posted February 24, 2009 Posted February 24, 2009 that looks wicked mate what piston ring gaps have you decided on running? would be interested to know.very impressive mate keep it up!!! Quote
Mikey Jay Posted February 24, 2009 Posted February 24, 2009 Really liking thatGood writeup too.Got any pics with the re-done mani and cam cover fitted? Quote
SiCaln Posted February 24, 2009 Posted February 24, 2009 awesome pics man, now thats some time and money spent Quote
Sparky Posted February 24, 2009 Posted February 24, 2009 WOW nice build loving that chromed rocker cover!!More pics of the rear diffuser :) Quote
mcleod Posted February 24, 2009 Author Posted February 24, 2009 i'll get more pics when its sunny.and piston ring gaps as in piston size???? if so there 74.5mm. if not then i dont know mate.the new mani will be unveiled soon enough. and so will the rocker cover when its on my forged engine Quote
crunchynutta Posted February 27, 2009 Posted February 27, 2009 how will you make money back on this??saaad Quote
Sparky Posted February 27, 2009 Posted February 27, 2009 And you are??? ^^^Its not about making money back, everyone knows when modding a car you will never make your money back!!The performance and looks you would get in this thing would more than make up for it!! Quote
mcleod Posted February 27, 2009 Author Posted February 27, 2009 erm in that case mate im not sure lol Quote
Bluebear Posted February 27, 2009 Posted February 27, 2009 Holy shit, right out of the blue!Looks immense, especially the diffuser! Tasty bit of kit there. Quote
Craig_N Posted February 27, 2009 Posted February 27, 2009 Nice build mate Loving the Rocker coverCraig Quote
Markoos Posted March 29, 2009 Posted March 29, 2009 fantastic build mate, when's that hks air filter relocation kit for sale? Quote
Craig_N Posted July 8, 2009 Posted July 8, 2009 Hi mate saw your car today on dummers lane heading towards manchester road looking nice.Craig Quote
