Starlet Nath Posted January 25, 2009 Author Posted January 25, 2009 Nice to see a decent update Nath Things certainly seem to be moving better now that you've cleared out the garage.Keep it up mate. Not too long now!Cheers Jozman,Hopefully things will get moving, I'll get the looms off and modified. Take everything off and put to one side that I'm keeping and then I can transfer the engine onto a small pallet. Quote
Galliano Posted January 25, 2009 Posted January 25, 2009 Nice one man Really coming along quick now. How much would you charge - once your project is finished - to un-attatch your garage and send it to me via courier? would love one that size! Quote
Starlet Nath Posted January 26, 2009 Author Posted January 26, 2009 Nice one man Really coming along quick now. How much would you charge - once your project is finished - to un-attatch your garage and send it to me via courier? would love one that size!The only problem with a bigger garage is you fill it with more stuff!!!Once the car is done I should have plenty of room Quote
Starlet Nath Posted January 26, 2009 Author Posted January 26, 2009 Well a quick update for tonight,I'm adding some more labels to the wiring looms, all the connectors are removed from the engine :harhar: I've pulled out the loom that comes out of the passenger side into the engine bay.I've just broken for some tea, but my plan is to remove the loom that comes out of the drivers side into the engine bay and pull the engine loom through the bulkhead tonight Anyway I'll get back to it Quote
Toby@ToyTuning.com Posted January 26, 2009 Posted January 26, 2009 Coming along nicely Nath, are you shortening the loom? Few grams to be saved there keep it up :harhar: Quote
Starlet Nath Posted January 26, 2009 Author Posted January 26, 2009 Coming along nicely Nath, are you shortening the loom? Few grams to be saved there keep it up Yes thats right Toby, I'm slimming down the wiring looms, No A/C, no radio, no ABS and maybe no heaters Anyway I have managed to do what I set out to do this evening, the engine bay loom and fusebox is out and also the engine loom is out.An box full of wiring loomsTomorrows task: dismantle the dash :harhar: Quote
SiCaln Posted January 27, 2009 Posted January 27, 2009 sweet man what car is the loom from 96/97 or 98/99? Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 sweet man what car is the loom from 96/97 or 98/99?Its a 98/99 spec loom mate, I still need both floor looms as yet The one that goes along the drivers side and the one that comes down the middle, so anyone who knows where there is a 98 spec that I can get those bits off I'd be well appreciative :harhar: Quote
SiCaln Posted January 27, 2009 Posted January 27, 2009 98/99 V or UK n/a?the one with climate control or switches?! Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 98/99 V or UK n/a?the one with climate control or switches?!Si are you having a blond moment? I have removed my looms from the front cut which is a 98 spec V, yes it has climate control with switches rather than cables to adjust where the air flow goes to Quote
SiCaln Posted January 27, 2009 Posted January 27, 2009 dont suppose ud swap it with me? because mine has the push buttons, so would save u that job and i wna fit the push buttons, save u doing the trimmage of those parts?! Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 dont suppose ud swap it with me? because mine has the push buttons, so would save u that job and i wna fit the push buttons, save u doing the trimmage of those parts?!Unfortunately mate my loom is damage, where the wires come up for the mirrors some t :harhar: t chopped them off. So would need fixing, but I assume you'll need the loom for the engine bay as there will be additional wiring for powering the electrics that operate the flow flap Quote
SiCaln Posted January 27, 2009 Posted January 27, 2009 i could repair that, u wouldnt want em either would u? ie no leccy mirrorsdya reckon im not sure, think it all goes on in the car? can i have the old heater box and other bits? Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 i could repair that, u wouldnt want em either would u? ie no leccy mirrorsdya reckon im not sure, think it all goes on in the car? can i have the old heater box and other bits?Well I'm gonna start stripping the dash tonight so I'll have a look. Yes you can mate for a reasonable sum :harhar: Gonna replace the heater box with something alot smaller Quote
SiCaln Posted January 27, 2009 Posted January 27, 2009 sweet man, put it all to the side for me please, ill buy em and we may be able to swap dash looms too, ill drive to u and the we can swap Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 sweet man, put it all to the side for me please, ill buy em and we may be able to swap dash looms too, ill drive to u and the we can swapIts fraught with danger, looks like you'll have to stop over at mine We could potentially remove everything, transfer it all across and then it does not work. But I have no problem with you coming up to mine, its just something you'll have to bear in mind :harhar: Quote
SiCaln Posted January 27, 2009 Posted January 27, 2009 the other way is if your gna be a while before getting to the interior, you could send it to me and ill swap it all over then send u mine back Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 the other way is if your gna be a while before getting to the interior, you could send it to me and ill swap it all over then send u mine backI'd rather not do it that way mate :harhar: Anyway here is a couple of pics for youIs this what you were looking for? Quote
Starlet Nath Posted January 27, 2009 Author Posted January 27, 2009 Well I set out to remove the dash tonight.....Which I have :harhar: Here's a few more pictures Quote
Toby@ToyTuning.com Posted January 28, 2009 Posted January 28, 2009 Nath are you cutting out the dash and re-installing or are you removing completely in favour of something like a stack dash?Again loving this project always keeping an eye credit to the forum mate T Quote
Starlet Nath Posted January 28, 2009 Author Posted January 28, 2009 Nath are you cutting out the dash and re-installing or are you removing completely in favour of something like a stack dash?Again loving this project always keeping an eye credit to the forum mate TThere will be nothing left of the orginal dash, the dash bar will go. Not sure whether I will get a carbon fibre dash manufactured, or just make something out of alloy. I will be using a Stack dash display unit, as for the heater I will be ditching the starlet one and getting something smaller, simpler and lighter but still utilising a heater matrix. Quote
Nanglebadger Posted January 28, 2009 Posted January 28, 2009 SWEET! thats some hardcore progress there my friend!!! keep it up!Phil. Quote
Starlet Nath Posted January 28, 2009 Author Posted January 28, 2009 SWEET! thats some hardcore progress there my friend!!! keep it up!Phil.Cheers Philius,am aiming to get the engine out the front cut as soon as I can and then I'll get the scrap man to come and collect whats left So keep your eyes peeledNath Quote
rob_bower Posted January 28, 2009 Posted January 28, 2009 Jesus Christ!! Has alex put a rocket up your arse?? you seem to be motoring at the mo!! Or has your love just been re-ignited??? does the front cut have a shifter in?? Quote
Starlet Nath Posted January 28, 2009 Author Posted January 28, 2009 Jesus Christ!! Has alex put a rocket up your arse?? you seem to be motoring at the mo!! Or has your love just been re-ignited??? does the front cut have a shifter in??Cheeky t t I have 3 gearsticks with cables, why do you need one? Quote
